Wireless Interface (wlp3s0 down) borked by VPN uninstall
Happy New Year Garuda gods & realm dwellers.
Kindly note the affected computer is offline so details are copy-pasted from the other machine. Formatting may not be as desired.
After a brief but failed experiment using Mullvadvpn that started well but turned out to be ill-fated, I can no longer open the network connection after uninstalling the vpn pkg.
I tried a few suggestions found in previous relevant posts, but still not getting anywhere. I also got btrfs errors trying to roll back to a previous image (I don’t know how to get to a snapshot older than 1 week old if it exists)
As advised by @Yada in a now closed similar troubleshooting issue, I restarted systemd-resolved, flushed the resolvectl flush-caches, and got errors trying to restart the dnsmasq:
Job for dnsmasq.service failed because the control process exited with error code. See β€œsystemctl status dnsmasq.service” and β€œjournalctl -xeu dnsmasq.service” for details.
That is as far as I got so far.
╰─λ garuda-inxi
  Kernel: 6.12.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=2116b848-241e-479d-a6c8-0ef9cb6f6bb5 rw single
    rootflags=subvol=@
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.9.0
    wm: kwin_wayland tools: avail: lxlock vt: 1 dm: SDDM Distro: Garuda
  Type: Laptop System: LENOVO product: 6473PVU v: ThinkPad T400
  Mobo: LENOVO model: 6473PVU serial: <superuser required>
    uuid: <superuser required> BIOS: LENOVO v: 7VET77WW (3.07 ) date: 09/02/2009
  ID-1: BAT0 charge: 34.5 Wh (100.0%) condition: 34.5/84.2 Wh (40.9%)
    volts: 12.4 min: 10.8 model: SANYO 42T4644 type: Li-ion serial: <filter>
    status: full
  Info: model: Intel Core2 Duo P8700 bits: 64 type: MCP arch: Penryn level: v1
    built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
    stepping: 0xA (10) microcode: 0xA0B
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 2 smt: <unsupported> cache:
    L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2022 min/max: 800/2534 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2022 2: 2022
    bogomips: 10107
  Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3
  Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Lenovo
    driver: i915 v: kernel arch: Gen-5 process: Intel 45nm built: 2008 ports:
    active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:2a42 class-ID: 0300
  Device-2: Lenovo Integrated Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-6:4 chip-ID: 17ef:1004
    alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: 0
  Monitor-1: LVDS-1 res: 1280x800 size: N/A modes: N/A
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
    drv: crocus x11: drv: crocus
  API: OpenGL v: 4.5 compat-v: 2.1 vendor: intel mesa v: 24.3.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Mobile Intel GM45 Express (CTG)
    device-ID: 8086:2a42 memory: 1.46 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 4 device: 0 type: cpu name: llvmpipe (LLVM
    18.1.8 128 bits) driver: N/A device-ID: 10005:0000
  Device-1: Intel 82801I HD Audio vendor: Lenovo ThinkPad T400
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e
  API: ALSA v: k6.12.8-zen1-1-zen status: kernel-api tools: N/A
  Device-1: Intel 82567LF Gigabit Network vendor: Lenovo driver: e1000e
    v: kernel port: 1820 bus-ID: 00:19.0 chip-ID: 8086:10bf class-ID: 0200
  Device-2: Intel PRO/Wireless 5100 AGN [Shiloh] Network driver: iwlwifi
    chip-ID: 8086:4237 class-ID: 0280
  Device-1: Broadcom BCM2045B (BDC-2.1) [Bluetooth Controller] driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-2:4
    chip-ID: 0a5c:2145 class-ID: fe01
  Report: btmgmt ID: hci0 rfk-id: 3 state: down bt-service: disabled
    rfk-block: hardware: no software: no address: N/A
  Local Storage: total: 298.09 GiB used: 55.35 GiB (18.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS723232L9SA60
    size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: C50B scheme: MBR
  ID-1: / raw-size: 298.09 GiB size: 298.09 GiB (100.00%)
    used: 55.35 GiB (18.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 298.09 GiB size: 298.09 GiB (100.00%)
  ID-3: /var/log raw-size: 298.09 GiB size: 298.09 GiB (100.00%)
  ID-4: /var/tmp raw-size: 298.09 GiB size: 298.09 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 2
  System Temperatures: cpu: 48.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 1925 fan-2: 1925
  Memory: total: 8 GiB available: 7.65 GiB used: 1.36 GiB (17.8%)
  Processes: 183 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.03 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1321 libs: 372 tools: octopi,paru Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
    inxi: 3.3.36
  System install date:     2024-09-06
  Last full system update: 2025-01-07
 ╭─___@___ in ~ took 12s
 ╰─λ
Also,
╰─λ systemctl status
● namoparvati
    State: degraded
    Units: 319 loaded (incl. loaded aliases)
     Jobs: 0 queued
   Failed: 1 units
    Since: Wed 2025-01-08 09:07:35 EST; 3h 22min ago
  systemd: 257.1-1-arch
   CGroup: /
           β”œβ”€init.scope
           β”‚ └─1 /usr/lib/systemd/systemd --switched-root --system --deserialize=47
           β”œβ”€system.slice
           β”‚ β”œβ”€ModemManager.service
           β”‚ β”‚ └─638 /usr/bin/ModemManager
           β”‚ β”œβ”€NetworkManager.service
           β”‚ β”‚ └─652 /usr/bin/NetworkManager --no-daemon
           β”‚ β”œβ”€avahi-daemon.service
           β”‚ β”‚ β”œβ”€586 "avahi-daemon: running [namoparvati.local]"
           β”‚ β”‚ └─623 "avahi-daemon: chroot helper"
           β”‚ β”œβ”€dbus-broker.service
           β”‚ β”‚ β”œβ”€583 /usr/bin/dbus-broker-launch --scope system --audit
           β”‚ β”‚ └─584 dbus-broker --log 4 --controller 9 --machine-id 4778d77504b34144b94e4427907f4769 --max-bytes 536870912 ->
           β”‚ β”œβ”€firewalld.service
           β”‚ β”‚ └─639 /usr/bin/python /usr/bin/firewalld --nofork --nopid
           β”‚ β”œβ”€polkit.service
           β”‚ β”‚ └─590 /usr/lib/polkit-1/polkitd --no-debug --log-level=err
           β”‚ β”œβ”€power-profiles-daemon.service
           β”‚ β”‚ └─708 /usr/lib/power-profiles-daemon
           β”‚ β”œβ”€rtkit-daemon.service
           β”‚ β”‚ └─1833 /usr/lib/rtkit-daemon
           β”‚ β”œβ”€sddm.service
           β”‚ β”‚ β”œβ”€709 /usr/bin/sddm
           β”‚ β”‚ └─717 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_YefymX -noreset -disp>
           β”‚ β”œβ”€systemd-journald.service
           β”‚ β”‚ └─355 /usr/lib/systemd/systemd-journald
           β”‚ β”œβ”€systemd-logind.service
           β”‚ β”‚ └─591 /usr/lib/systemd/systemd-logind
           β”‚ β”œβ”€systemd-oomd.service
           β”‚ β”‚ └─359 /usr/lib/systemd/systemd-oomd
           β”‚ β”œβ”€systemd-resolved.service
           β”‚ β”‚ └─3032 /usr/lib/systemd/systemd-resolved
           β”‚ β”œβ”€systemd-timesyncd.service
           β”‚ β”‚ └─399 /usr/lib/systemd/systemd-timesyncd
           β”‚ β”œβ”€systemd-udevd.service
           β”‚ β”‚ └─udev
           β”‚ β”‚   β”œβ”€  405 /usr/lib/systemd/systemd-udevd
           β”‚ β”‚   └─18021 "(udev-worker)"
           β”‚ β”œβ”€systemd-userdbd.service
           β”‚ β”‚ β”œβ”€ 383 /usr/lib/systemd/systemd-userdbd
           β”‚ β”‚ β”œβ”€5820 "systemd-userwork: waiting..."
           β”‚ β”‚ β”œβ”€5860 "systemd-userwork: waiting..."
           β”‚ β”‚ └─5861 "systemd-userwork: waiting..."
           β”‚ β”œβ”€udisks2.service
           β”‚ β”‚ └─1599 /usr/lib/udisks2/udisksd
           β”‚ β”œβ”€upower.service
           β”‚ β”‚ └─1613 /usr/lib/upowerd
           β”‚ └─wpa_supplicant.service
           β”‚   └─705 /usr/bin/wpa_supplicant -u -s -O /run/wpa_supplicant
           └─user.slice
             └─user-1000.slice
               β”œβ”€session-2.scope
               β”‚ β”œβ”€1231 /usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth-d2dc842f-3b9e-443e-8651-841212823b28 --id 1 --start>
               β”‚ β”œβ”€1289 /usr/bin/kwalletd6 --pam-login 12 13
               β”‚ └─1290 /usr/bin/startplasma-wayland
               └─user@1000.service
                 β”œβ”€app.slice
                 β”‚ β”œβ”€app-conky@autostart.service
                 β”‚ β”‚ └─2298 conky -c "/home/namoparvati/.conky/TeejeeTech/Process Panel"
                 β”‚ β”œβ”€app-dbus\x2d:1.18\x2dorg.a11y.atspi.Registry.slice
                 β”‚ β”‚ └─dbus-:1.18-org.a11y.atspi.Registry@0.service
                 β”‚ β”‚   └─1827 /usr/lib/at-spi2-registryd --use-gnome-session
                 β”‚ β”œβ”€app-firewall\x2dapplet@autostart.service
                 β”‚ β”‚ └─2033 /usr/bin/python /usr/bin/firewall-applet
                 β”‚ β”œβ”€app-garuda\x2dsystem\x2dmaintenance@autostart.service
                 β”‚ β”‚ └─2036 /usr/bin/garuda-system-maintenance
                 β”‚ β”œβ”€app-geoclue\x2ddemo\x2dagent@autostart.service
                 β”‚ β”‚ └─2071 /usr/lib/geoclue-2.0/demos/agent
                 β”‚ β”œβ”€app-kmix_autostart@autostart.service
                 β”‚ β”‚ └─2084 /usr/bin/kmix --keepvisibility
                 β”‚ β”œβ”€app-org.flameshot.Flameshot@autostart.service
                 β”‚ β”‚ └─2045 /usr/bin/flameshot
                 β”‚ β”œβ”€app-org.kde.discover.notifier@autostart.service
                 β”‚ β”‚ └─2077 /usr/lib/DiscoverNotifier
                 β”‚ β”œβ”€app-org.kde.dolphin@f5edcb4fd956418e8b0db420a1d37506.service
                 β”‚ β”‚ β”œβ”€ 5709 rga -j2 --line-buffered -L --hidden --no-ignore --files-with-matches --null --no-messages -e dns>
                 β”‚ β”‚ β”œβ”€ 5714 rg --no-line-number --smart-case --pre /usr/bin/rga-preproc --pre-glob "*.{epub,EPUB,odt,ODT,doc>
                 β”‚ β”‚ β”œβ”€ 5733 rga -j2 --line-buffered -L --hidden --no-ignore --files-with-matches --null --no-messages -e dns>
                 β”‚ β”‚ β”œβ”€ 5738 rg --no-line-number --smart-case --pre /usr/bin/rga-preproc --pre-glob "*.{epub,EPUB,odt,ODT,doc>
                 β”‚ β”‚ β”œβ”€ 5755 rga -j2 --line-buffered -L --hidden --no-ignore --files-with-matches --null --no-messages -e dns>
                 β”‚ β”‚ β”œβ”€ 5760 rg --no-line-number --smart-case --pre /usr/bin/rga-preproc --pre-glob "*.{epub,EPUB,odt,ODT,doc>
                 β”‚ β”‚ β”œβ”€ 5765 rga -j2 --line-buffered -L --hidden --no-ignore --files-with-matches --null --no-messages -e dns>
                 β”‚ β”‚ β”œβ”€ 5770 rg --no-line-number --smart-case --pre /usr/bin/rga-preproc --pre-glob "*.{epub,EPUB,odt,ODT,doc>
                 β”‚ β”‚ β”œβ”€ 5774 rga -j2 --line-buffered -L --hidden --no-ignore --files-with-matches --null --no-messages -e dns>
                 β”‚ β”‚ β”œβ”€ 5779 rg --no-line-number --smart-case --pre /usr/bin/rga-preproc --pre-glob "*.{epub,EPUB,odt,ODT,doc>
                 β”‚ β”‚ β”œβ”€ 5864 rga -j2 --line-buffered -L --hidden --no-ignore --files-with-matches --null --no-messages -e dns>
                 β”‚ β”‚ β”œβ”€ 5867 rg --no-line-number --smart-case --pre /usr/bin/rga-preproc --pre-glob "*.{epub,EPUB,odt,ODT,doc>
                 β”‚ β”‚ β”œβ”€ 5894 rga -j2 --line-buffered -L --hidden --no-ignore --files-with-matches --null --no-messages -e dns>
                 β”‚ β”‚ β”œβ”€ 5899 rg --no-line-number --smart-case --pre /usr/bin/rga-preproc --pre-glob "*.{epub,EPUB,odt,ODT,doc>
                 β”‚ β”‚ β”œβ”€18317 /usr/bin/rga-preproc ./lib64/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-tscs454.k>
                 β”‚ β”‚ β”œβ”€18318 /usr/bin/rga-preproc ./lib/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-uda1334.ko.>
                 β”‚ β”‚ β”œβ”€18332 /usr/bin/rga-preproc ./lib/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-uda1334.ko.>
                 β”‚ β”‚ β”œβ”€18339 /usr/bin/rga-preproc ./lib64/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-tscs454.k>
                 β”‚ β”‚ β”œβ”€18341 /usr/bin/rga-preproc ./lib/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-uda1334.ko.>
                 β”‚ β”‚ β”œβ”€18353 /usr/bin/rga-preproc ./lib/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-uda1334.ko.>
                 β”‚ β”‚ β”œβ”€18357 /usr/bin/rga-preproc ./lib64/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-tscs454.k>
                 β”‚ β”‚ β”œβ”€18367 /usr/bin/rga-preproc ./lib64/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-tscs454.k>
                 β”‚ β”‚ β”œβ”€18370 /usr/bin/rga-preproc ./lib64/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-tscs454.k>
                 β”‚ β”‚ β”œβ”€18386 /usr/bin/rga-preproc ./lib64/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-tscs42xx.>
                 β”‚ β”‚ β”œβ”€18394 /usr/bin/rga-preproc ./lib64/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-tscs42xx.>
                 β”‚ β”‚ └─18400 /usr/bin/rga-preproc ./lib/modules/6.12.8-zen1-1-zen/kernel/sound/soc/codecs/snd-soc-tscs454.ko.>
                 β”‚ β”œβ”€app-org.kde.konsole-16100.scope
                 β”‚ β”‚ β”œβ”€main.scope
                 β”‚ β”‚ β”‚ └─16100 /usr/bin/konsole
                 β”‚ β”‚ └─tab(16916).scope
                 β”‚ β”‚   β”œβ”€16916 /usr/bin/fish
                 β”‚ β”‚   β”œβ”€18398 systemctl status
                 β”‚ β”‚   └─18402 less
                 β”‚ β”œβ”€app-org.kde.xwaylandvideobridge@autostart.service
                 β”‚ β”‚ └─2048 /usr/bin/xwaylandvideobridge
                 β”‚ β”œβ”€app-variety@autostart.service
                 β”‚ β”‚ └─2052 /usr/bin/python /usr/bin/variety --profile /home/namoparvati/.config/variety/
                 β”‚ β”œβ”€dconf.service
                 β”‚ β”‚ └─1884 /usr/lib/dconf-service
                 β”‚ β”œβ”€libinput-gestures.service
                 β”‚ β”‚ β”œβ”€2053 python3 /usr/bin/libinput-gestures
                 β”‚ β”‚ └─2142 libinput-debug-events --device /dev/input/by-path/platform-i8042-serio-1-event-mouse
                 β”‚ └─xdg-desktop-portal-gtk.service
                 β”‚   └─1588 /usr/lib/xdg-desktop-portal-gtk
                 β”œβ”€background.slice
                 β”‚ β”œβ”€kde-baloo.service
                 β”‚ β”‚ └─1540 /usr/lib/kf6/baloo_file
                 β”‚ β”œβ”€plasma-gmenudbusmenuproxy.service
                 β”‚ β”‚ └─1899 /usr/bin/gmenudbusmenuproxy
                 β”‚ β”œβ”€plasma-kaccess.service
                 β”‚ β”‚ └─1900 /usr/bin/kaccess
                 β”‚ β”œβ”€plasma-kactivitymanagerd.service
                 β”‚ β”‚ └─1889 /usr/lib/kactivitymanagerd
                 β”‚ β”œβ”€plasma-polkit-agent.service
                 β”‚ β”‚ └─1901 /usr/lib/polkit-kde-authentication-agent-1
                 β”‚ β”œβ”€plasma-powerdevil.service
                 β”‚ β”‚ └─1902 /usr/lib/org_kde_powerdevil
                 β”‚ └─plasma-xembedsniproxy.service
                 β”‚   └─1904 /usr/bin/xembedsniproxy
                 β”œβ”€init.scope
                 β”‚ β”œβ”€1237 /usr/lib/systemd/systemd --user
                 β”‚ └─1239 "(sd-pam)"
                 └─session.slice
                   β”œβ”€at-spi-dbus-bus.service
                   β”‚ β”œβ”€1789 /usr/lib/at-spi-bus-launcher
                   β”‚ β”œβ”€1800 /usr/bin/dbus-broker-launch --config-file=/usr/share/defaults/at-spi2/accessibility.conf --scope >
                   β”‚ └─1807 dbus-broker --log 4 --controller 9 --machine-id 4778d77504b34144b94e4427907f4769 --max-bytes 1000>
                   β”‚ β”œβ”€1515 /usr/bin/dbus-broker-launch --scope user
                   β”‚ └─1525 dbus-broker --log 4 --controller 10 --machine-id 4778d77504b34144b94e4427907f4769 --max-bytes 100>
                   β”œβ”€pipewire-pulse.service
                   β”‚ └─1932 /usr/bin/pipewire-pulse
                   β”œβ”€pipewire.service
                   β”‚ └─1620 /usr/bin/pipewire
                   β”œβ”€plasma-kded6.service
                   β”‚ β”œβ”€1841 /usr/bin/kded6
                   β”‚ └─1968 /usr/bin/xsettingsd
                   β”œβ”€plasma-ksmserver.service
                   β”‚ └─1839 /usr/bin/ksmserver
                   β”œβ”€plasma-kwin_wayland.service
                   β”‚ β”œβ”€1538 /usr/bin/kwin_wayland_wrapper --xwayland
                   β”‚ β”œβ”€1542 /usr/bin/kwin_wayland --wayland-fd 7 --socket wayland-0 --xwayland-fd 8 --xwayland-fd 9 --xwaylan>
                   β”‚ └─1770 /usr/bin/Xwayland :1 -auth /run/user/1000/xauth_RwuOeh -listenfd 84 -listenfd 85 -displayfd 76 -r>
                   β”œβ”€plasma-plasmashell.service
                   β”‚ └─1858 /usr/bin/plasmashell --no-respawn
                   β”œβ”€plasma-xdg-desktop-portal-kde.service
                   β”‚ └─1903 /usr/lib/xdg-desktop-portal-kde
                   β”œβ”€wireplumber.service
                   β”‚ └─1621 /usr/bin/wireplumber
                   β”œβ”€xdg-desktop-portal.service
                   β”‚ └─1568 /usr/lib/xdg-desktop-portal
                   β”œβ”€xdg-document-portal.service
                   β”‚ β”œβ”€1573 /usr/lib/xdg-document-portal
                   β”‚ └─1584 fusermount3 -o rw,nosuid,nodev,fsname=portal,auto_unmount,subtype=portal -- /run/user/1000/doc
                   └─xdg-permission-store.service
                     └─1577 /usr/lib/xdg-permission-store
lines 145-179/179 (END)
I still have my live usb so perhaps it is easier to try to reinstall garuda???
Thanks if anyone can advise the best way out of this! :pray:t3: :pray:t3: :pray:t3:
p.s. I also tried rolling back to an older cached version of networkmanager but that also didn’t work.
Okay finally SOLVED it very easily by deleting the network connection from the network manager. :innocent: :melting_face:
Leaving this post intact in case someone else faces this.
P.s. Mullvad vpn installed easily and worked well until I made the mistake of turning on the β€œbecome notified of beta program updates” and mullvad said they only support a certain arch distro that is not garuda. They also said the update notification should not have affected anything. However I had already noticed that updates executed automatically in the past. (those not related to Beta editions worked without incident although the updating itself took the vpn offline during the process)
P.s.s. In the meantime, someone has published a new pvpn suite on AUR!
