Wireless interface issue
Wifi networks show but can’t connect. The issue began at the end of trying to update Garuda. The terminal showed this error “Can’t update: signature from *** is marginal trust” or “invalid or corrupted package” and I pressed Y in all of them, then the Wifi stopped working. I’m wondering if reinstalling Garuda will fix this problem.
Kernel: 6.5.9-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/a/boot/vmlinuz-linux-zen root=UUID=9ad899ae-3ae8-43ec-a5b6-24e4270ff3e4 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin x11 vt: 2
Type: Laptop System: Apple product: MacBookAir6, 1 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-35C1E88140C3E6CF
Mobo: Apple model: Mac-35C1E88140C3E6CF v: MacBookAir6,1
serial: <superuser required> UEFI: Apple v: 429.0.0.0.0 date: 12/02/2020
ID-1: BATO charge: 7.7 Wh (21.9%) condition: 35.1/35.1 Wh (100.0%)
volts: 6.9 min: 7.5 model: SMP bq20z451 type: Li-ion serial: N/A
status: discharging cycles: 12
Info: model: Intel Core i5-4250U bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0×45 (69) stepping: 1 microcode: 0x26
L1: 128 KiB desc: d-2x32 KiB; 1-2x32 KiB L2: 512 KiB desc: 2x256 KiB
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/2600 scaling: driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 15201 Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4 1 sse4_2 ssse3 vmx
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Apple driver: 1915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a26
alternate: fbdev, intel, vesa dri: crocus gpu: 1915 display-ID: :0
Screen-1: 0 s-res: 1366×768 s-dpi: 96 s-size: 361×203mm (14.21×7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: Apple Color LCD built: 2011 res: 1366×768 hz: 60
dpi: 136 gamma: 1.2 size: 256×144mm (10.08×5.67") diag: 294mm (11.6")
ratio: 16:9 modes: 1366×768
API: EGL v: 1.5 hw: drv: intel crocus platforms: device : 0 drv: crocus device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
inactive: gbm,wayland
: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
API
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5000 (HSW GT3) device-ID: 8086:0a26 memory: 1.46 GiB unified: yes
API:
Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 5000 (HSW GT3) driver: mesa intel v: 23.2.1-arch1.2 device-ID: 8086:0a26 surfaces: xcb, xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
| Device-1: Intel Haswell-ULT HD Audio vendor: Apple driver: snd_hda_intel
Device-2: Intel 8 Series HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
4: Network:
pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp3s0 state: dormant mac: <filter>
Device-1: Apple [] driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3.3:6 chip-ID: 05ac:828f class-ID: fe01
Report: btmgmt ID: hcio rfk-id: 1 state: down bt-service: enabled, running rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 113 GiB used: 4.75 GiB (4.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD TS0128F size: 113 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0704 scheme: GPT
ID-1:/raw-size: 112.7 GiB size: 112.7 GiB (100.00%) used: 4.75 GiB (4.2%)
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) dev/sda1 maj-min: 8:1
used: 576 KiB (0.2%) fs: vfat dev: / ID-3: /home raw-size: 112.7 GiB size: 112.7 GiB (100.00%)
used: 4.75 GiB (4.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 112.7 GiB size: 112.7 GiB (100.00%) used: 4.75 GiB (4.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 112.7 GiB size: 112.7 GiB (100.00%) used: 4.75 GiB (4.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 3.77 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo, lzo-rle, lz4, lz4hc, 842 max-streams: 4 dev: /dev/zramo
System Temperatures: cpu: 70.0 C mobo: N/A
Processes: 190 Uptime: Om wakeups: 2 Memory: total: 4 GiB available: 3.77 GiB used: 1.41 GiB (37.3%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: pm: pacman pkgs: 1186 libs: 350 tools: octopi, paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2023-09-27
Last full system update: 2023-09-27
Is partially upgraded:
Relevant software:
Windows dual boot:
No
No/Undetected
snapper NetworkManager dracut
Welcome :slight_smile:
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
Did you search in forum?
Did you use garuda-update in terminal?
Did you use the last working snapshot?
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
Without garuda-inxi this request will be moved to 412 Precondition Failed
Reinstalling Garuda and updating it worked.
