Hello!
Recently I’ve received a new computer keyboard (Logitech G 915 TKL) to my birthday and it doesn’t seem to correctly work on linux.
While connected with a cable every button works as normal and I can do everything I’d need to.
When connected via the Logitech Lightspeed Connection however, all buttons are basically randomly assigned. For example:
S => A
C => E
Enter => M
Return => E
I also can’t connect it via bluetooth I’d like to check if the issue persists there too but I can’t seem to be able to properly connect it. When trying I press the pairing button and connect it to my system. Shortly after it just disconnects.
This happens with my PS4 Controller too so this appears to be a different issue.
Anyway.
I don’t have a way to test this keyboard on windows sadly. Could it work via VM maybe?
If there’s anything else I can try please just let me know and I’ll do my best to help
Thanks for your read.
P.S.: These are some articles I’ve had a read through but they appear to be about lightning issues mostly which is not a concern for me rn:
- 20.10 - How to control Logitech G915 TKL keyboard lighting in Linux Ubuntu? - Ask Ubuntu
- Reddit - Dive into anything
- Logitech Gaming Keyboards - ArchWiki
- Logitech G915 TKL with Ubuntu
Kernel: 6.6.1-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=43b24c17-d93b-422c-86a9-512969a67d2a rw rootflags=subvol=@
amd_pstate=active
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Garuda Linux base: Arch Linux
Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 4702 date: 10/20/2023
ID-1: hidpp_battery_0 charge: 99% condition: N/A volts: 4.2 min: N/A
model: Logitech G915 TKL LIGHTSPEED Wireless RGB Mechanical Gaming Keyboard
type: N/A serial: <filter> status: full
Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 927 high: 3599 min/max: 550/4851 base/boost: 3800/4850
scaling: driver: amd-pstate-epp governor: powersave volts: 1.1 V
ext-clock: 100 MHz cores: 1: 550 2: 550 3: 550 4: 550 5: 550 6: 550
7: 3541 8: 3599 9: 550 10: 550 11: 550 12: 550 13: 550 14: 550 15: 550
16: 550 bogomips: 121633
Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] driver: nvidia v: 545.29.02
alternate: nvidia_drm non-free: 545.xx+ status: current (as of 2023-10;
EOL~2026-12-xx) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 0a:00.0 chip-ID: 10de:17c8 class-ID: 0300
Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2
chip-ID: 046d:08e5 class-ID: 0102
Display: server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DP-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
Monitor-2: DP-3 pos: right res: 1920x1080 hz: 60 dpi: 92
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 980 Ti/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 980 Ti driver: nvidia v: 545.29.02 device-ID: 10de:17c8
surfaces: xcb,xlib
Device-1: NVIDIA GM200 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:0fb0
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
Device-4: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 5-2:3 chip-ID: 1235:8202 class-ID: 0102
API: ALSA v: k6.6.1-AMD-znver3 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.84 status: n/a (root, process) with:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:7 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 5.68 TiB used: 1.33 TiB (23.4%)
fw-rev: 3B2QEXM7 temp: 39.9 C scheme: GPT
SMART: yes health: PASSED on: 290d 23h cycles: 993
read-units: 31,485,603 [16.1 TB] written-units: 128,605,460 [65.8 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 4TB
family: based SSDs size: 3.64 TiB block-size: physical: 512 B logical: 512 B
sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2B6Q
temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 29d 8h cycles: 1048
written: 23.89 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 371d 2h cycles: 992
written: 6.84 TiB Pre-Fail: reallocated sector: 98 threshold: 10
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: Q300. size: 223.57 GiB
block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 12.3 temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 61d 6h cycles: 3494
ID-5: /dev/sdd maj-min: 8:48 vendor: Verbatim model: STORE N GO
size: 7.47 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.0
used: 343.52 GiB (36.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
System Temperatures: cpu: 48.4 C mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 22%
Processes: 430 Uptime: 55m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 6.83 GiB (21.8%) Init: systemd v: 254
pm: pacman pkgs: 1493 libs: 507 tools: pamac,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.2.15 running-in: gnome-terminal inxi: 3.3.31
Garuda (2.6.18-1):
System install date: 2023-09-23
Last full system update: 2023-11-09
