Hello.
I'm having a strange problem with this.
I have two wireguard connections defined in my computer (to two different places) One of them works ok. I just imported the .conf file, and it worked ok.
The second says that is connected, but I cannot reach any machine in the remote place nor the internet.
The more strange thing for me is that same configuration file (I mean the same peer.conf file) is working in a Windows machine and in an Android 12 phone. So the wireguard remote server is working, and the file is correct (no keys errors etc).
The wg0.conf for this server is
[Interface]
Address = 10.13.13.1
ListenPort = 51820
PrivateKey = ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZz=
PostUp = iptables -A FORWARD -i %i -j ACCEPT; iptables -A FORWARD -o %i -j ACCEPT; iptables -t nat -A POSTROUTING -o eth+ -j MASQUERADE
PostDown = iptables -D FORWARD -i %i -j ACCEPT; iptables -D FORWARD -o %i -j ACCEPT; iptables -t nat -D POSTROUTING -o eth+ -j MASQUERADE
[Peer]
# peer1
PublicKey = yLP6Pr0vuOtmXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx0M=
PresharedKey = FYYYYYYYYYYYYYYYYYYYYYYYYYYYYYncHpOc=
AllowedIPs = 10.13.13.2/32
and more peers
What can be happening?
Kernel: 6.1.9-arch1-2 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=b4ca416f-530b-4ae4-bf0b-835736bc4fe7 rw [email protected]
loglevel=3 ibt=off
Type: Desktop Mobo: MACHINIST model: X99Z V102 v: IENGINEER
serial: <superuser required> UEFI: American Megatrends v: C612RD24
date: 11/02/2020
Info: model: Intel Xeon E5-2670 v3 bits: 64 type: MT MCP arch: Haswell
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3F (63) stepping: 2 microcode: N/A
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 3 MiB desc: 12x256 KiB
L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 1833 high: 3100 min/max: 1200/3100 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1200 2: 3100 3: 1200
4: 1200 5: 3100 6: 1200 7: 1200 8: 3100 9: 3100 10: 1200 11: 1201 12: 1200
13: 1200 14: 1200 15: 1200 16: 3100 17: 1201 18: 3100 19: 3100 20: 1200
21: 1200 22: 1202 23: 3100 24: 1199 bogomips: 110435
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nvidia
v: 470.161.03 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Fermi 2 code: GF119/GK208
process: TSMC 28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 8
bus-ID: 03:00.0 chip-ID: 10de:128b class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: DVI-I-1 pos: primary,right res: 1920x1080 hz: 60 dpi: 92
Monitor-2: HDMI-0 pos: left res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 470.161.03 renderer: NVIDIA GeForce GT
710/PCIe/SSE2 direct render: Yes
Device-1: Intel C610/X99 series HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8d20 class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
bus-ID: 03:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound API: ALSA v: k6.1.9-arch1-2 running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br-0230801b624c state: down mac: <filter>
IF-ID-2: br-96c3f4053d28 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-a539ad42d9b3 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-ab3483bdfeed state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: br-e28deef329de state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-6: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-7: vboxnet0 state: down mac: <filter>
IF-ID-8: veth33cd690 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: veth69f8b91 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: veth6e9a7b1 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: veth85fba8b state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: veth871127d state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: vetha88f13c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: vethabc020d state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: vethac1b9fd state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: vethaf54b43 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: vethba15604 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-18: vethe99d681 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-19: vethfe7160a state: up speed: 10000 Mbps duplex: full
mac: <filter>
Local Storage: total: 953.87 GiB used: 386.33 GiB (40.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T9
lanes: 4 type: SSD serial: <filter> rev: 001C temp: 43.9 C scheme: GPT
ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 80.99 GiB (41.5%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 600 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 758.06 GiB size: 758.06 GiB (100.00%)
used: 305.34 GiB (40.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 263.8 MiB (0.8%)
System Temperatures: cpu: 0.0 C mobo: 48.0 C gpu: nvidia temp: 55 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1252 fan-3: 0 fan-4: 0 fan-5: 0
gpu: nvidia fan: 56%
Power: 12v: N/A 5v: N/A 3.3v: 3.20 vbat: 3.28
Processes: 540 Uptime: 1d 3h 40m wakeups: 0 Memory: 31.25 GiB
used: 8.08 GiB (25.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1987
pm: pacman pkgs: 1979 libs: 405 tools: octopi,paru,yay pm: rpm pkgs: 0
pm: flatpak pkgs: 8 Shell: fish v: 3.6.0 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2022-04-12
Last full system update: 2023-02-13
Failed units: bluetooth-autoconnect.service shadow.service
