I cannot check Enable GTK3 Theming as it is grayed out. How can I enable it?
wine-6.0 (Staging)
inxi -Fxxxza
Thanks.
wine-6.0 (Staging)
inxi -Fxxxza
Thanks.
$ pacman -Si wine-staging
Repository : multilib
Version : 6.0-1
Optional Deps : giflib
lib32-giflib
gtk3
lib32-gtk3
Validated By : MD5 Sum SHA-256 Sum Signature
Do you have both gtk3 and lib32-gtk3 installed?
Yes, all the Optional Deps you mentioned here.
OK, so before I install wine-staging and do a web search, what have you already looked at or tried before asking here?
I didn't do any tweak to Wine. I just read it here but didn't understand the last post ( 2021-01-13 19:24:02)
I've had a look and it just doesn't seem to work. It might be a bug in wine-staging or something missing from the packaging process...
