Wine wont launch anything and some other programs wont launch
Cannot launch anything from wine here is my garuda-inxi
Kernel: 6.3.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b4b9aa4f-1c46-4bb5-a068-2dd00c020715 rw rootflags=subvol=@
resume=UUID=f450710d-d16e-495b-b573-065a44d7ecee loglevel=3 ibt=off
Type: Laptop System: Micro-Star product: GP66 Leopard 11UH v: REV:1.0
Mobo: Micro-Star model: MS-1543 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E1543IMS.320 date: 10/28/2021
ID-1: BAT1 charge: 53.4 Wh (100.0%) condition: 53.4/63.2 Wh (84.4%)
volts: 16.7 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: full
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
microcode: 0x44
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1643 high: 2300 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 2300 3: 800
4: 2300 5: 800 6: 800 7: 800 8: 2300 9: 2300 10: 2300 11: 2300 12: 800
13: 800 14: 2300 15: 2300 16: 2300 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9a60
Device-2: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: Micro-Star MSI driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:249c class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting unloaded: nouveau
failed: nvidia alternate: fbdev,intel,nv,vesa dri: iris gpu: i915
Monitor-1: eDP-1 model: Sharp LQ156M1JW03 built: 2021 res: 1920x1080
hz: 240 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: Mesa Intel UHD Graphics (TGL GT1)
direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.3.5-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz vendor: Rivet Networks
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 06:00.0 chip-ID: 8086:2725 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:4 chip-ID: 8087:0032
Local Storage: total: 1.84 TiB used: 17.73 GiB (0.9%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731030WD temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: SK Hynix model: HFM001TD3JX013N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 44.9 C
ID-1: / raw-size: 914.35 GiB size: 914.35 GiB (100.00%)
used: 17.73 GiB (1.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 914.35 GiB size: 914.35 GiB (100.00%)
ID-4: /var/log raw-size: 914.35 GiB size: 914.35 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.35 GiB size: 914.35 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.86 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.33 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 378 Uptime: 4m wakeups: 1 Memory: available: 15.33 GiB
used: 3.72 GiB (24.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1807
libs: 520 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date:     2023-05-30
Last full system update: 2023-05-31
Note: I am not dualbooting it is just an leftover partition from another drive
here is what happens when I try to run anything through wine
002c:fixme:winediag:LdrInitializeThunk wine-staging 8.8 is a testing version containing experimental patches.
002c:fixme:winediag:LdrInitializeThunk Please mention your exact version when filing bug reports on winehq.org.
0084:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type 00000005
0084:fixme:wineusb:query_id Unhandled ID query type 0x5.
00e0:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
00e0:err:winediag:nodrv_CreateWindow L"The explorer process failed to start.
Please list which wine apps you're having trouble with. Also please list which native apps you're having trouble with.
Also, try launching one of the apps from the command line and post the output here. That will be the biggest help.
i.e.
$ gimp
or
$ wine 'C:\Program Files (x86)\Bejeweled 3\Bejeweled3.exe'
basically everything wont launch like some setup files and heres notepad.exe
[🔍] × wine notepad.exe
0084:fixme:xinput:pdo_pnp IRP_MN_QUERY_ID type 5, not implemented!
00f0:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
00f0:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
and something like NPS.exe
Application could not be started, or no application associated with the specified file.
ShellExecuteEx failed: File not found.
all say the same thing
also if I try to do prime-run glxgears it does this
prime-run glxgears
X Error of failed request:  BadValue (integer parameter out of range for operation)
Major opcode of failed request:  152 (GLX)
Minor opcode of failed request:  3 (X_GLXCreateContext)
Value in failed request:  0x0
Serial number of failed request:  26
Current serial number in output stream:  27
here is glxinfo
name of display: :0
display: :0  screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Intel (0x8086)
Device: Mesa Intel(R) UHD Graphics (TGL GT1) (0x9a60)
Version: 23.1.1
Accelerated: yes
Video memory: 15696MB
Unified memory: yes
Preferred profile: core (0x1)
Max core profile version: 4.6
Max compat profile version: 4.6
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) UHD Graphics (TGL GT1)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 23.1.1
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6 (Compatibility Profile) Mesa 23.1.1
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 23.1.1
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
Apologies, but I'm in over my head. Seems like a driver issue except you seem to have the right driver correctly installed afaict.
Someone smarter than me will be along soon. :smiley:
