Wine/proton sometimes breaks my wireless mouse
Sometimes when doing stuff with wine/proton, launching games, installing apps, etc. My mouse will stop working until I reboot or plug it in with usb. It is a logitech g502 x lightspeed connected to a logitech powerplay mouse pad. This never happened when I was using pop os, it only started after switching to garuda.
I have not been using linux for long and have no idea how to troubleshoot this problem. Any help will be appreciated.
╭─lii@lii in ~ as πŸ§™
╰─λ garuda-inxi
Kernel: 6.4.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=19fb6e90-b65c-4509-bd2a-e526bf36a930 rw rootflags=subvol=@
Type: Desktop System: Micro-Star product: MS-7B61 v: 1.0
Mobo: Micro-Star model: Z370 GAMING PLUS (MS-7B61) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.A0
date: 06/08/2020
Device-1: gip0.0 model: Microsoft X-Box One pad serial: N/A
charge: 50% (should be ignored) rechargeable: yes status: not charging
Device-2: hidpp_battery_2 model: Logitech G502 X LIGHTSPEED
serial: <filter> charge: 92% rechargeable: yes status: discharging
Info: model: Intel Core i5-9600KF bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
desc: 1x9 MiB
Speed (MHz): avg: 4400 min/max: 800/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 4400 2: 4400 3: 4400 4: 4400 5: 4400 6: 4400
bogomips: 44398
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2504
Device-2: HTC (High Tech ) Vive driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11.1.2:26
chip-ID: 0bb4:2c87 class-ID: 0102
Device-3: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.3:9
chip-ID: 1532:0e03 class-ID: 0102
Device-4: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 534d:2109
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: DP-2 pos: primary,right res: 1920x1080 hz: 60 dpi: 93
Monitor-2: HDMI-0 pos: left res: 1920x1080 hz: 60 dpi: 96
size: 510x287mm (20.08x11.3") diag: 585mm (23.04") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.98 renderer: NVIDIA GeForce RTX
3060/PCIe/SSE2 direct-render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
Device-2: NVIDIA GA106 High Definition Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Device-3: HTC (High Tech ) Vive driver: snd-usb-audio,uvcvideo type: USB
Device-4: HTC (High Tech ) Vive driver: hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11.1.5:22
chip-ID: 0bb4:2c87 class-ID: 0300 serial: <filter>
Device-5: Logitech G432 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 046d:0a9c class-ID: 0300
Device-6: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-7: MacroSilicon USB Video
API: ALSA v: k6.4.10-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-1: HTC (High Tech ) Vive Hub Bluetooth 4.1 (Broadcom BCM920703)
driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 1-11.2:14 chip-ID: 0bb4:0306 class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 5.92 TiB used: 3.75 TiB (63.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX920 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: SVN139B temp: 53.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST6000VN0033-2EE110
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
used: 429.08 GiB (90.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.29 GiB used: 367.5 MiB (1.1%)
System Temperatures: cpu: 44.5 C mobo: 41.0 C gpu: nvidia temp: 43 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1797 fan-3: 1511 fan-4: 1464 fan-5: 1478
fan-6: 1078 gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.07
Processes: 265 Uptime: 3m wakeups: 19 Memory: total: 32 GiB
available: 31.29 GiB used: 5.17 GiB (16.5%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 2179 pm: pacman pkgs: 2140 libs: 559 tools: octopi,pamac,paru
pm: flatpak pkgs: 39 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.28
System install date:     2023-06-27
Last full system update: 2023-08-15
Failed units:            preload.service'
Copy paste error? β†’ ’ ←
Check in terminal status preload.service
systemctl status preload.service
Unit preload.service could not be found.
╰─λ systemctl status preload.service
Γ— preload.service - Adaptive readahead daemon
Loaded: loaded (/usr/lib/systemd/system/preload.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Tue 2023-08-15 14:21:15 CDT; 2h 52min ago
Duration: 239ms
Process: 642 ExecStart=/usr/bin/preload --foreground $PRELOAD_OPTS (code=exited, status=1/FAILURE)
Main PID: 642 (code=exited, status=1/FAILURE)
CPU: 168ms
Aug 15 14:21:14 lii-ms7b61 systemd[1]: Started Adaptive readahead daemon.
Aug 15 14:21:15 lii-ms7b61 systemd[1]: preload.service: Main process exited, code=exited, status=1/FAILURE
Aug 15 14:21:15 lii-ms7b61 systemd[1]: preload.service: Failed with result 'exit-code'.
Edit:I might have fixed the preload.service. It turned out my preload.state file may have been corrupt and renaming it fixed the error. But I don't think that had anything to do with my mouse.
╭─lii@lii in ~ as πŸ§™ took 3s
● preload.service - Adaptive readahead daemon
Active: active (running) since Wed 2023-08-16 07:48:17 CDT; 1min 18s ago
Main PID: 644 (preload)
Tasks: 1 (limit: 38289)
Memory: 3.8M
CPU: 111ms
CGroup: /system.slice/preload.service
└─644 /usr/bin/preload --foreground --verbose 1
So, no one has any idea how to troubleshoot this?
