Wine ,Lutris and bottle wont work on X11 (no driver could be loaded)
Hello I’m relatively new to those stuff, but I know the basics I try every thing I can but wine it’s not working on my Garuda Linux also bottle and Lutris, and I ran some tests with wine but when I try to run a program with wine the laptop freeze for 2 minutes and then nothing happen.
This issue is only if I use X11 while on Wayland every thing work fine beside some glitches on the screen from time to time
BTW, my laptop is Razer blade 15 mid-2019 base model
On the Konsole, I get this error.
After running:
wine prgrame.exe
I get this:
007c:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type 00000005
00ec:fixme:file:server_get_file_info Unsupported info class e
00fc:err:winediag:nodrv_CreateWindow Application tried to create a window, but no
driver could be loaded. 00fc:err:winediag:nodrv_CreateWindow L"The explorer process
failed to start." ^C0100:fixme:console:default_ctrl_handler Terminating process d0 on
event 0 00ec:fixme:font:find_matching_face Untranslated charset 255
00ec:err:winediag:nodrv_CreateWindow Application tried to create a window, but no
driver could be loaded. 00ec:err:winediag:nodrv_CreateWindow L"The explorer
process failed to start." 00ec:fixme:file:NtFsControlFile FSCTL_GET_REPARSE_POINT
semi-stub 00ec:fixme:file:NtFsControlFile FSCTL_GET_REPARSE_POINT semi-stub
I attempted several fixes, including reinstalling wine, upgrading the system, and setting the display = 0 , but it appears that none of these solutions resolved my issue.
Help me please if you know what’s my issue. Thank you.
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7df7844e-7ff3-4c2a-b0de-d3c6f5bb2ea0 rw rootflags=subvol=@
quiet resume=UUID=1f9d92e3-7a56-449b-9b48-5fb668c245be loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
Type: Laptop System: Razer product: Blade 15 Mid 2019-Base v: 3.04
serial: <filter> Chassis: type: 10 serial: N/A
Mobo: Razer model: DA530 serial: N/A UEFI: Razer v: 1.03 date: 06/06/2019
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1024 high: 1100 min/max: 800/4500 base/boost: 2475/8300
ext-clock: 100 MHz cores: 1: 1099 2: 1100 3: 1100 4: 1100 5: 1100 6: 800
7: 1100 8: 1100 9: 800 10: 1100 11: 1100 12: 800 bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Razer USA
ports: active: eDP-1 empty: DP-4,DP-5 bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Razer USA
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none empty: DP-1, DP-2, DP-3, HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-3: IMC Networks USB Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 13d3:56bd
Display: server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
Monitor-1: eDP-1 model: BOE Display 0x0804 built: 2019 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
GT2) device-ID: 8086:3e9b memory: 15.15 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:3e9b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 545.29.06
device-ID: 10de:1f11 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-1: Intel Cannon Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel
Device-2: NVIDIA TU106 High Definition Audio vendor: Razer USA
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.0 status: n/a (root, process) with:
vendor: Razer USA driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
rfk-block: hardware: no software: no address: <filter> bt-v: 5.1 lmp-v: 10
Local Storage: total: 1.34 TiB used: 64.73 GiB (4.7%)
model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size: physical: 512 B
fw-rev: EXA7301Q temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 200d 15h cycles: 3,117
read-units: 90,924,534 [46.5 TB] written-units: 65,000,348 [33.2 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK000960GWCFA
size: 894.25 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: HPG3 temp: 29 C
SMART: yes state: enabled health: PASSED on: 58d 21h
ID-1: / raw-size: 283.54 GiB size: 283.54 GiB (100.00%)
used: 64.73 GiB (22.8%) fs: btrfs block-size: 4096 B dev: /dev/sda4
maj-min: 8:4
used: 576 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 283.54 GiB size: 283.54 GiB (100.00%)
maj-min: 8:4
ID-4: /var/log raw-size: 283.54 GiB size: 283.54 GiB (100.00%)
maj-min: 8:4
ID-5: /var/tmp raw-size: 283.54 GiB size: 283.54 GiB (100.00%)
maj-min: 8:4
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 15.96 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 45.0 C pch: 54.0 C mobo: N/A
Processes: 346 Uptime: 6m wakeups: 0 Memory: total: 16 GiB
available: 15.52 GiB used: 4.43 GiB (28.6%) igpu: 32 MiB Init: systemd
v: 254 default: graphical tool: systemctl Compilers: gcc: 13.2.1
Packages: 1948 pm: pacman pkgs: 1928 libs: 536 tools: octopi,paru,yay
pm: flatpak pkgs: 20 Shell: garuda-inxi (sudo) default: Bash v: 5.2.21
Garuda (2.6.19-2):
System install date:     2023-11-25
Last full system update: 2023-12-01
Windows dual boot:       Yes
Your Display Server (x11) won’t start:
Display: "empty"
How did you install the nvidia driver?
I didn’t install it manually, it comes with Garuda automatically installed.
Also, I ran those if that may help.
echo $DISPLAY
:0
and
xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080    144.00*+  60.01    60.00    59.97    59.96    59.93
1680x1050     59.95    59.88
1400x1050     74.76    59.98
1600x900      59.99    59.94    59.95    59.82
1280x1024     85.02    75.02    60.02
1400x900      59.96    59.88
1280x960      85.00    60.00
1440x810      60.00    59.97
1368x768      59.88    59.85
1280x800      59.99    59.97    59.81    59.91
1152x864      75.00
1280x720      60.00    59.99    59.86    59.74
1024x768      85.00    75.05    60.04    85.00    75.03    70.07    60.00
1024x768i     86.96
960x720       85.00    75.00    60.00
928x696       75.00    60.05
896x672       75.05    60.01
1024x576      59.95    59.96    59.90    59.82
960x600       59.93    60.00
832x624       74.55
960x540       59.96    59.99    59.63    59.82
800x600       85.00    75.00    70.00    65.00    60.00    85.14    72.19    75.00    60.32    56.25
840x525       60.01    59.88
864x486       59.92    59.57
700x525       74.76    59.98
800x450       59.95    59.82
640x512       85.02    75.02    60.02
700x450       59.96    59.88
640x480       85.09    60.00    85.01    72.81    75.00    59.94
720x405       59.51    58.99
720x400       85.04
684x384       59.88    59.85
640x400       59.88    59.98    85.08
576x432       75.00
640x360       59.86    59.83    59.84    59.32
640x350       85.08
512x384       85.00    75.03    70.07    60.00
512x384i      87.06
512x288       60.00    59.92
416x312       74.66
480x270       59.63    59.82
400x300       85.27    72.19    75.12    60.32    56.34
432x243       59.92    59.57
320x240       85.18    72.81    75.00    60.05
360x202       59.51    59.13
360x200       85.04
320x200       85.27
320x180       59.84    59.32
320x175       85.27
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-4 disconnected (normal left inverted right x axis y axis)
DP-1-5 disconnected (normal left inverted right x axis y axis)
Restart your PC, new kernel and KDE :slight_smile:
mhwd-kernel -li
Currently running: 6.6.3-AMD-znver3 (linux-amd-znver3)
The following kernels are installed in your system:
local/linux-amd-znver3 6.6.v.3-1
local/linux-zen 6.6.3.zen1-1
I did reboot but nothing changed also why AMD I don’t have AMD processor or graphics card in my laptop what should I do ?
mhwd-kernel -li
Currently running: 6.6.2-zen1-1-zen (linux-zen)
local/linux-zen 6.6.2.zen1-1
wine prgrame.exe
00f4:fixme:file:server_get_file_info Unsupported info class e
0104:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
0104:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
00f4:fixme:font:find_matching_face Untranslated charset 255
00f4:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
00f4:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
00f4:fixme:file:NtFsControlFile FSCTL_GET_REPARSE_POINT semi-stub
00f4:fixme:file:NtFsControlFile FSCTL_GET_REPARSE_POINT semi-stub ...
That’s just my Notebook.
But you use not the last zen kernel.
I’ll upgrade and see, thank you.
I upgraded my kernel, but nothing changed.
mhwd-kernel -li
Currently running: 6.6.3-zen1-1-zen (linux-zen)
Same problem before. Thanks for your time
Are you using the dGPU with Wine?
If so, this bug could be applicable:
https://bugs.winehq.org/show_bug.cgi?id=55633
I don’t know which one I use rn with wine , but I want to use the dGpu because I want to run some games.
winecfg
0164:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
0164:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
I did fix it by removing NVIDIA DEFAULT Driver “NVIDIA-dkms” installed by Garuda then I install it from scratch by installing driver called just ‘Nvidia’ without the dkms and everything work fine now thanks to every one who try to help.
