Hi, still in the process of setting my Garuda system up.
For some progs I need I want to install Wine (not gaming, but photo editing and MyHeritage ...) Using the GUI tool to manage software I try to install Wine. The installation routine hangs in an eternal loop for 30 minutes. I cancel and do an uninstall. Then I try to install Wine -next. Same loop.
Confused what is wrong. Also confused by the long list if options I get when I search for wine. Not sure what to install.
Who can enlighten me?
Please, post your garuda-inxi from terminal as text.
Sorry. I don't really know how to use Inxi.
I just see the message "installing wine-stable" for literally hours .... in the window of the install/deinstall program.
For you again, the template you delete.
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
You are right, there are a lot of options and possible configurations; going in blind is bound to be confusing.
I suggest reading through this document for the enlightenment you seek: Wine - ArchWiki
"But I don't really love learning and typing commands, prefer GUI apps and distros."
Maybe you'd better choose another operating system.
But also for garuda-inxi there is the foolproof variant thanks to our great developer.
Ok guys. I understand you are loosing patience. That's ok. I shouldn't try to offload all my transition problems here.
I have, in the meantime, been able to uninstall 'wine' and install 'wine-stable'. That doesn't mean that my old wine-installed program really work, but that's a wine issue and I will find ways to deal with that.
I will continue to use Gui tools as much as possible, but I understand the need to provide information if you want competent assistance.
Thanks for the hints pointing me to good sources of information.
Never.
The topic close tomorrow.
καληνύχτα!
This topic was automatically closed after 10 hours. New replies are no longer allowed.
