Hi there. i’ve recently made a switch from windows 11 and I am new to how things work here.
I wanted to play warcraft 3, but when opening it with wine, it crashes.
The game opens
Screen goes black
Game minimizes
Wine crashes
The color of the whole screen turns grey-ish.
In the wine output it says this.
(wine:4547): GStreamer-CRITICAL **: 07:47:05.096: gst_object_unref: assertion'object != NULL' failed
winegstreamer error: decodebin1: Your GStreamer installation is missing a plug-in.
winegstreamer error: decodebin1: ../gstreamer/subprojects/gst-plugins-base/gst/playback/gstdecodebin2.c(4701): gst_decode_bin_expose (): /GstBin:bin2/GstDecodeBin:decodebin1:
no suitable plugins found:
Missing decoder: Audio Video Interleave (AVI) (video/x-msvideo)
How do I go about installing these plugins? How do I fix this error?
It may help if we have your
as stated in the forum template
Probably try installing from aur
lib32-gst-plugins-bad
lib32-gst-plugins-ugly
lib32-gst-libav
filo
14 July 2022 12:05
4
Hi there, welcome to the forum!
Instead of launching directly from wine, maybe you'd better leverage on a frontend app like Lutris.
In general, give a look here:
Kayo
14 July 2022 12:31
5
Speaking of frontend apps, bottles just got updated with a new default runner that uses Proton, GE, and TKG patches called "Soda" Release Day 2022.7.14 ⋅ Bottles
Blizzard's Battle net is listed as Gold in its app list, btw AppStore ⋅ Bottles
HI, thanks for the fast replies! Much appreciated.
Here is my inxi file log
Kernel: 5.18.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=ea07dd1f-2cbd-470f-81c7-8fa5c58d3792 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: Dell product: Vostro 15 3510 v: N/A
Mobo: Dell model: 0V799W v: A00 serial: <superuser required> UEFI: Dell
v: 1.12.1 date: 04/27/2022
ID-1: BAT0 charge: 39.9 Wh (99.0%) condition: 40.3/40.0 Wh (100.7%)
volts: 13.2 min: 11.2 model: SWD DELL FH3K216 type: Li-poly
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 863 high: 1073 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 729 2: 741 3: 843
4: 1006 5: 862 6: 1073 7: 712 8: 941 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
Device-2: NVIDIA GP107M [GeForce MX350] vendor: Dell driver: nouveau
v: kernel non-free: 515.xx+ status: current (as of 2022-06) arch: Pascal
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c94 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0c45:6d1a class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 model: BOE Display 0x097d built: 2020 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.18.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 238.47 GiB used: 26.92 GiB (11.3%)
model: PC SN530 NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
rev: 21113012 temp: 30.9 C scheme: GPT
used: 26.92 GiB (11.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.37 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nouveau temp: 44.0 C
Processes: 242 Uptime: 1h 22m wakeups: 4294 Memory: 15.37 GiB
used: 2.83 GiB (18.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages:
note: see --pkg apt: 0 pacman: 2921 lib: 461 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
error: could not register 'chaotic-aur' database (database already registered)
Garuda (2.6.5-1):
System install date: 2022-07-12
Last full system update: 2022-07-14
Oh yes, I wanted to do that, but I didn't know how to. This doesn't find the package.
sudo pacman -S lib32-gst-plugins-bad
filo
14 July 2022 13:08
8
It is an AUR package, so you need an AUR helper (paru is the default):
paru lib32-gst-plugins-bad
You'll be presented with a PKGBUILD preview: check it, and quit with 'q', then confirm that you want to install the package(s)
I am greeted with this error when trying to run that command.
mooninorbit@mooninorbit in /home🔒 as 🧙 took 2ms
╰─λ paru lib32-gst-plugins-bad
error: failed to initialize alpm: root=/ dbpath=/var/lib/pacman/: database already registered
Sorry for being a total newby
Also, I am constantly getting this error when running any pacman command
filo
14 July 2022 13:27
11
No need to be sorry, this is all strange.
Do you happen to have other terminal sessions open with pacman? Or have you tried after a reboot?
If this persists, I think you should try resetting your pacman configuration with:
garuda-update remote fix
The pacman and paru issues seem to have been fixed after running that command and rebooting the PC. I will try to install the missing packaged now as instructed.
Oh my God fellas. I really felt like I wouldn't be able to fix this, ever, since I've been tinkering on my own for the past 2 days.
Everything works now
Thanks a lot! I really hope to stick with garuda for the coming days.
<3
Also, one question. Where can i learn more about using linux, how it works, etc..?
Or do I learn like this, by resolving the encountered issues. Do you have any good channels to recommend / guides?
SGS
14 July 2022 14:27
15
You mean years, right
Start with reading the Garuda Wiki.
Learn to search, start in whoogle questions with, Arch Linux.
BTW, do not post like in a chat, you can edit your last post until somebody answers.
filo
14 July 2022 14:37
17
Start familiarizing with:
https://wiki.garudalinux.org/en/home
and (especially) with:
https://forum.garudalinux.org/t/faq-and-tutorials-table-of-contents/2962
Then, step-by-step, depending on the topics you want to better understand (or learn from scratch):
https://wiki.archlinux.org/
Warning: the latter is addictive
system
Closed
16 July 2022 14:56
20
