Wine Config Changed Automatically After System Upgrade
Hello all,
In the desktop integration of wine cfg . All available folders were linked to my folders there . But today when I upgraded my system and rebooted , the links for all folders except downloads were disabled in wine cfg . What could have caused this ? And Is this normal ?
inxi:
root=UUID=1a3d0a6e-7ed0-49ad-9764-325911ffd2cd rw rootflags=subvol=@
Type: Desktop System: HP product: HP All-in-One 22-df0xxx v: N/A
serial: <superuser required> Chassis: type: 13 serial: <superuser required>
Mobo: HP model: 87A4 v: 10100 serial: <superuser required> UEFI: AMI
v: F.36 date: 08/07/2023
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBC
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2832 high: 3400 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1960 2: 3199 3: 2769
4: 3400 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:8a56 class-ID: 0300
Device-2: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:6
chip-ID: 30c9:0013 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP1 model: HP ALL-in-One serial: <filter>
built: 2019 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 546mm (21.5") ratio: 16:9
modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
device-ID: 8086:8a56 memory: 7.35 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: integrated-gpu name: Intel
UHD Graphics (ICL GT1) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:8a56 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:5 chip-ID: 0bda:b00a
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 946.04 GiB used: 303.08 GiB (32.0%)
model: WD10EZEX-60WN4A1 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A03 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer Blade
size: 14.53 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 243.1 GiB size: 243.1 GiB (100.00%) used: 19.61 GiB (8.1%)
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 243.1 GiB size: 243.1 GiB (100.00%)
used: 19.61 GiB (8.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 243.1 GiB size: 243.1 GiB (100.00%)
ID-5: /var/tmp raw-size: 243.1 GiB size: 243.1 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.53 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 206 Uptime: 1h 22m wakeups: 0 Memory: total: 8 GiB note: est.
available: 7.53 GiB used: 2.74 GiB (36.4%) Init: systemd v: 254
pm: pacman pkgs: 1433 libs: 415 tools: pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.2.15 running-in: konsole inxi: 3.3.31
Garuda (2.6.18-1):
System install date:     2023-11-07
Last full system update: 2023-11-10 ↻
