Wine Application keeps freezing
Hey!
I’m currently trying to run FL-Studio 21 on Garuda and while it’s technically open and running, everytime I hover over a menu so that a dropdown appears the whole application just rapidly get’s slower and slower until it’s frozen completly for a whole minute (or longer if the menu is still there). Once it resolves it makes all the clicks I did while it was frozen.
I couldn’t find anything about having problems with running it through wine and I don’t remember having this issue back in Fedora.
I tried using:
- normal wine command and installation via terminal
- 64bit wine command and installation via terminal
- Installation via Lutris
- using different wine versions
all with the same issue.
What’s also strange for me is the fact that it’s using 150% CPU in Htop but when actually lagging it rises beyond 200%.
Currently I have wine-8.17 installed. If you need any other information please let me know and I’ll make sure to add it.
If anyone knows anything else, that could help me resolving the issue, I’d greatly appreciate pointing it out.
  Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=43b24c17-d93b-422c-86a9-512969a67d2a rw rootflags=subvol=@
  Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
    serial: <filter> UEFI: American Megatrends v: 3601 date: 05/26/2021
  Device-1: ps-controller-battery-1c:66:6d:b3:b3:42 model: N/A serial: N/A
    charge: N/A status: full
  Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3800 min/max: 2200/4850 boost: enabled
    base/boost: 3800/4850 scaling: driver: acpi-cpufreq governor: performance
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 3800 2: 3800 3: 3800 4: 3800
    5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800
    13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121589
  Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] driver: nvidia v: 535.113.01
    alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 0a:00.0 chip-ID: 10de:17c8 class-ID: 0300
  Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2
    chip-ID: 046d:08e5 class-ID: 0102
  Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
    s-diag: 1102mm (43.38")
  Monitor-1: DP-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
  Monitor-2: DP-3 pos: right res: 1920x1080 hz: 60 dpi: 92
  API: EGL Message: No EGL data available.
  API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 980 Ti/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.3.264 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 980 Ti driver: nvidia v: 535.113.01 device-ID: 10de:17c8
    surfaces: xcb,xlib
  Device-1: NVIDIA GM200 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:0fb0
  Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
  Device-4: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
    driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 5-2:3 chip-ID: 1235:8202 class-ID: 0102
  API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.80 status: n/a (root, process) with:
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 8087:0029
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
  Local Storage: total: 5.68 TiB used: 582.43 GiB (10.0%)
    fw-rev: 3B2QEXM7 temp: 42.9 C scheme: GPT
  SMART: yes health: PASSED on: 289d 16h cycles: 947
    read-units: 29,463,436 [15.0 TB] written-units: 126,981,013 [65.0 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: Q300. size: 223.57 GiB
    block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 12.3 temp: 27 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 3y 52d 2h cycles: 3448
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
    family: based SSDs size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 1B6Q temp: 27 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 359d 14h cycles: 946
    written: 6.84 TiB Pre-Fail: reallocated sector: 98 threshold: 10
  ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 QVO 4TB
    family: based SSDs size: 3.64 TiB block-size: physical: 512 B logical: 512 B
    sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2B6Q
    temp: 29 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 17d 21h cycles: 1002
    written: 22.41 TiB
    used: 487.16 GiB (52.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2
    used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
    maj-min: 259:2
    maj-min: 259:2
    maj-min: 259:2
  ID-1: swap-1 type: zram size: 31.25 GiB used: 1.2 MiB (0.0%) priority: 100
  System Temperatures: cpu: 43.0 C mobo: 30.0 C gpu: nvidia temp: 51 C
  Fan Speeds (rpm): cpu: 0 gpu: nvidia fan: 22%
  Processes: 499 Uptime: 12h 45m wakeups: 1 Memory: total: 32 GiB
  available: 31.25 GiB used: 8 GiB (25.6%) Init: systemd v: 254
  pm: pacman pkgs: 1491 libs: 505 tools: pamac,paru Shell: garuda-inxi (sudo)
  default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.30
  System install date:     2023-09-23
  Last full system update: 2023-10-03 ↻
  • Which specific Lutris install script did you choose? Can you provide a link like this?
  • Which Wine versions did you try, were they different or the same as specified in the install script?
  • SMART is not reported due to missing package, you can get it with sudo pacman -S smartmontools
  • Can you run lutris -d from the command line and post debug information in a code block?
  • I see partially upgraded, please run update and restart before continuing.
There was no specific install script for lutris. I just added it to lutris using the “install wine application with installer” option.
The specific Wine versions I tried were 8.17 and ge-8.17
I’ve updated the inxi message in my initial post
I don’t really see anything that could be useful here but.
╭─ayes@IO in ~ as 🧙 took 20s
 ╰─λ lutris -d
INFO     2023-10-03 23:02:10,869 [startup.init_lutris:209]:Starting Lutris 0.5.13
INFO     2023-10-03 23:02:10,871 [startup.check_driver:65]:Using NVIDIA drivers 535.113.01 for x86_64
INFO     2023-10-03 23:02:10,871 [startup.check_driver:69]:GPU: NVIDIA GeForce GTX 980 Ti
INFO     2023-10-03 23:02:10,872 [startup.check_driver:85]:GPU: 10DE:17C8 10DE:1151 (nvidia drivers)
INFO     2023-10-03 23:02:10,872 [startup.check_driver:85]:GPU:   (simple-framebuffer drivers)
DEBUG    2023-10-03 23:02:11,047 [lutris.get_missing_game_ids:191]:Checking for missing games
done
I also ran the program through the terminal and add the log in here. While I don’t know if there’s anything of value here, it sure can’t hurt to be able to look at.
╭─ayes@IO in ~ took 6m30s
[⚡] × wine64 ~/.wine/drive_c/Program\ Files/Image-Line/FL\ Studio\ 21/FL64.exe
0394:fixme:cryptasn:CryptDecodeObjectEx Unsupported decoder for lpszStructType 1.3.6.1.4.1.311.2.1.4
0394:fixme:cryptasn:CryptDecodeObjectEx Unsupported decoder for lpszStructType 1.3.6.1.4.1.311.2.1.12
0394:fixme:thread:GetThreadUILanguage : stub, returning default language.
0394:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 00007FFFFE1FCB9C, 0000000000000000 00007FFFFE1FCBF8
0394:fixme:nls:get_dummy_preferred_ui_language (0x38 0x409 00007FFFFE1FCB9C 0000000000000000 00007FFFFE1FCBF8) returning a dummy value (current locale)
0394:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 00007FFFFE1FCB9C, 00007FFFFFBEA690 00007FFFFE1FCBF8
0394:fixme:nls:get_dummy_preferred_ui_language (0x38 0x409 00007FFFFE1FCB9C 00007FFFFFBEA690 00007FFFFE1FCBF8) returning a dummy value (current locale)
0394:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 00007FFFFE1FC27C, 0000000000000000 00007FFFFE1FC2D8
0394:fixme:nls:get_dummy_preferred_ui_language (0x38 0x409 00007FFFFE1FC27C 0000000000000000 00007FFFFE1FC2D8) returning a dummy value (current locale)
0394:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 00007FFFFE1FC27C, 00007FE345593360 00007FFFFE1FC2D8
0394:fixme:nls:get_dummy_preferred_ui_language (0x38 0x409 00007FFFFE1FC27C 00007FE345593360 00007FFFFE1FC2D8) returning a dummy value (current locale)
0394:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 00007FFFFE1FC1AC, 0000000000000000 00007FFFFE1FC208
0394:fixme:nls:get_dummy_preferred_ui_language (0x38 0x409 00007FFFFE1FC1AC 0000000000000000 00007FFFFE1FC208) returning a dummy value (current locale)
0394:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 00007FFFFE1FC1AC, 00007FE34544A690 00007FFFFE1FC208
0394:fixme:nls:get_dummy_preferred_ui_language (0x38 0x409 00007FFFFE1FC1AC 00007FE34544A690 00007FFFFE1FC208) returning a dummy value (current locale)
0394:fixme:dwmapi:DwmGetCompositionTimingInfo (0000000000000000 00007FFFFE1FE7AC)
0394:fixme:nls:get_dummy_preferred_ui_language (0x8 0x409 00007FFFFE1FF3FC 0000000000000000 00007FFFFE1FF3F8) returning a dummy value (current locale)
0394:fixme:nls:get_dummy_preferred_ui_language (0x8 0x409 00007FFFFE1FF3FC 00007FFFFFBD2330 00007FFFFE1FF3F8) returning a dummy value (current locale)
0394:fixme:wtsapi:WTSRegisterSessionNotification Stub 0000000000040554 0x00000000
0394:fixme:uxtheme:BufferedPaintInit Stub ()
0438:fixme:dwmapi:DwmFlush () stub
0394:fixme:nls:get_dummy_preferred_ui_language (0x8 0x409 00007FFFFE1FDF1C 0000000000000000 00007FFFFE1FDF18) returning a dummy value (current locale)
0394:fixme:nls:get_dummy_preferred_ui_language (0x8 0x409 00007FFFFE1FDF1C 00007FE3431FDB50 00007FFFFE1FDF18) returning a dummy value (current locale)
03fc:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE3424AFD4C): stub
0444:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE34239FD4C): stub
0430:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE3429FFD4C): stub
0414:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE3426CFD4C): stub
0410:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE34217FD4C): stub
0400:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE3425BFD4C): stub
0410:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
040c:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE3427DFD4C): stub
03fc:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0428:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE3428EFD4C): stub
0444:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0430:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0414:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0400:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
040c:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0428:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0434:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE34206FD4C): stub
0434:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0424:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE341F5FD4C): stub
0424:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0448:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE341E4FD4C): stub
0448:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0440:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE34228FD4C): stub
0440:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0454:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE341D3FD4C): stub
0454:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
041c:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE341A1FD4C): stub
041c:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0468:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE34190FD4C): stub
0468:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0394:fixme:win:NtUserLockWindowUpdate (0x50b76), partial stub!
0394:fixme:win:NtUserLockWindowUpdate ((nil)), partial stub!
0394:fixme:powrprof:PowerGetActiveScheme (0000000000000000,00007FFFFE1FD938) stub!
0450:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE3416EFD0C): stub
0450:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(2) stub
0418:fixme:avrt:AvSetMmThreadCharacteristicsW (L"P",00007FE33A3FFD4C): stub
0418:fixme:avrt:AvSetMmThreadPriority (0000000012345678)->(1) stub
0394:fixme:resource:GetGuiResources (FFFFFFFFFFFFFFFF,0): stub
0394:fixme:dwmapi:DwmEnableMMCSS (-1) stub
0394:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0394:fixme:explorerframe:taskbar_list_SetProgressState iface 00007FFFFEA95650, hwnd 0000000000050B76, flags 2 stub!
0394:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 00007FFFFE1FA9FC, 0000000000000000 00007FFFFE1FAA58
0394:fixme:nls:get_dummy_preferred_ui_language (0x38 0x409 00007FFFFE1FA9FC 0000000000000000 00007FFFFE1FAA58) returning a dummy value (current locale)
0394:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 00007FFFFE1FA9FC, 00007FE339463360 00007FFFFE1FAA58
0394:fixme:nls:get_dummy_preferred_ui_language (0x38 0x409 00007FFFFE1FA9FC 00007FE339463360 00007FFFFE1FAA58) returning a dummy value (current locale)
03e4:fixme:wininet:InternetSetOptionW INTERNET_OPTION_SEND/RECEIVE_TIMEOUT/DATA_SEND_TIMEOUT 60000
03e4:fixme:secur32:get_cipher_algid unknown algorithm 23
03e4:fixme:secur32:get_mac_algid unknown algorithm 200, cipher 23
03e4:fixme:wininet:set_cookie secure not handled
03e4:fixme:wininet:set_cookie Unknown additional option L"SameSite=None"
0394:fixme:dwmapi:DwmExtendFrameIntoClientArea (000000000005041A, 00007FFFFE1FE930) stub
0458:fixme:dwmapi:DwmFlush () stub
0394:fixme:dwmapi:DwmExtendFrameIntoClientArea (000000000006041A, 00007FFFFE1FE930) stub
0394:fixme:dwmapi:DwmExtendFrameIntoClientArea (000000000007041A, 00007FFFFE1FE930) stub
0394:fixme:dwmapi:DwmExtendFrameIntoClientArea (000000000008041A, 00007FFFFE1FE930) stub
Unfortunately, I don’t see anything useful to solving the problem in that log. You do not appear to have failing disks, luckily. I wish I was able to be more help debugging.
Another thing that recently popped up is this:
Which may be the cause my problems after all.
I’ll see if I can find anything about it.
EDIT: Apparently this hasn’t fixed the dropdown menu issue. But well another issue off the road too.
Can you find some way to get ASIO drivers? Maybe this is helpful?!
Well the Asio driver issue has just something todo with pipewire since it can’t actually find some devices. Just disabling them (as they are not being used anyway by me) resolved that.
So quick update. I’ve decided to look on lutris for an install script since you mentioned those too back then. I did end up finding 3 actually and I’ve just picked the most up to date one which also fixed the issue with those menus aswell!
Not sure what else there is that I didn’t do with manual installing, but it fixed it.
This is the script I used:
description: Compatible with winetricks 20230212
game_slug: fl-studio
gogslug: ''
humblestoreid: ''
installer_slug: fl-studio-gui-v21-installer
notes: ''
runner: wine
script:
  files:
  - powershell:
      filename: install_pwshwrapper.exe
      url: https://github.com/PietJankbal/powershell-wrapper-for-wine/blob/9205ad0033faa3183ffe1cac8947639b2b31004e/install_pwshwrapper.exe?raw=true
  - setup:
      filename: flstudio_win_installer.exe
      url: https://support.image-line.com/redirect/flstudio_win_installer
  game:
    arch: win64
    args: /unix "C:\Program Files\Image-Line\FL Studio 21\FL64.exe"
    exe: $GAMEDIR/drive_c/windows/system32/start.exe
    prefix: $GAMEDIR
  installer:
  - task:
      arch: win64
      prefix: $GAMEDIR
  - task:
      description: Installing Powershell Wrapper
      executable: powershell
      prefix: $GAMEDIR
  - task:
      description: Installing FL Studio. The default settings should be fine, Please
        do not change the install location.
      executable: setup
      prefix: $GAMEDIR
      return_code: 50944
  - task:
      app: gdiplus
      description: Adding winetrick packages.
      prefix: $GAMEDIR
  wine:
    overrides:
      d2d1: disabled
steamid: null
version: GUI v21 Installer
year: 1997
Either way! I appreciate your continued willingness to help :slight_smile:
