Hey @tbg I too have a wifi issue. I made a dual boot with windows and kde lite but when ever I open windows and back to linux the wifi is not recognised. I have to wait or restart a no. of times to get my wifi back on linux. I do not find any toggle button for wifi as no wifi icon there.
I don't have this issue on windows and I have updated the system.
Can you please help me here.
❯ inxi -Fxxxza ⇣0 B/s ⇡0 B/s 192.168.42.4 223.230.149.177 65% ─╯
System: Kernel: 5.8.14-zen1-1-zen x86_64 bits: 64 compiler: N/A
root=UUID=4adb250b-7c24-48b8-a1c6-5dc57c849ede rw [email protected] quiet splash loglevel=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Laptop System: ASUSTeK product: VivoBook 15_ASUS Laptop X507UF v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X507UF v: 1.0 serial: <filter> UEFI: American Megatrends v: X507UF.305
date: 07/17/2019
Battery: ID-1: BAT0 charge: 13.8 Wh condition: 21.3/33.3 Wh (64%) volts: 11.1/11.1
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging cycles: 681
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 8E (142) stepping: A (10) microcode: D6 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 1596 MHz min/max: 400/1600 MHz Core speeds (MHz): 1: 1596 2: 1577 3: 1586 4: 1577
5: 1593 6: 1543 7: 1580 8: 1575
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce MX130] vendor: ASUSTeK driver: nouveau v: kernel
bus ID: 01:00.0 chip ID: 10de:174d
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus ID: 1-6:3
chip ID: 13d3:5a11
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0 screens: 1
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.2.0 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.8.14-zen1-1-zen
Network: Device-1: Intel Wireless 8265 / 8275 driver: N/A modules: iwlwifi port: e000 bus ID: 02:00.0
chip ID: 8086:24fd
IF-ID-1: enp0s20f0u1 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 16.92 GiB (1.8%)
ID-1: /dev/sda vendor: Samsung model: ST1000LM035-1RK172 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: SDM4
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus ID: 00:17.0 chip ID: 8086.282a rev: 21
Partition: ID-1: / raw size: 230.00 GiB size: 230.00 GiB (100.00%) used: 16.92 GiB (7.4%) fs: btrfs
dev: /dev/sda7
ID-2: /home raw size: 230.00 GiB size: 230.00 GiB (100.00%) used: 16.92 GiB (7.4%) fs: btrfs
dev: /dev/sda7
ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda4
ID-2: swap-2 type: zram size: 244.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 244.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 244.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 244.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 244.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 244.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 244.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 244.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3000
Info: Processes: 302 Uptime: 3m Memory: 7.65 GiB used: 1.76 GiB (23.0%) Init: systemd v: 246
Compilers: gcc: 10.2.0 Packages: pacman: 1210 lib: 296 flatpak: 0 Shell: Zsh v: 5.8
running in: konsole inxi: 3.1.06
@kunalgaurav4 Please use ~~~ in first and last raw of terminal output if </> not work correct.
