Windows Partitions Fat32 or NTFS break after system freezes or screens go black to due static electricity or power interruption when using Steam (tested multiple times)
Encrypted bitlocker paritions turn into basic partitions & no longer are accessible sometimes for no reason at all.
Error:
An error occurred while accessing 'Basic data partition', the system responded: The requested operation has failed: Error mounting /dev/dm-1 at /run/media/fe90iopjkfe/SteamOffline: wrong fs type, bad option, bad superblock on /dev/mapper/bitlk-211e2486-1f79-4d5a-b50f-ff990ad06c12, missing codepage or helper program, or other error
Much appreciated
Kernel: 6.12.9-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=b6e93bc3-d0c3-4263-be4b-58fee48d267c rw rootflags=subvol=@
quiet rd.luks.uuid=3f3b4f50-3273-4243-9a54-f15b65d318e3 loglevel=3
Type: Desktop System: ASRock product: B650E PG-ITX WiFi v: N/A
Mobo: ASRock model: B650E PG-ITX WiFi serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 3.15
date: 12/10/2024
Device-1: ps-controller-battery-41:42:ae:08:af:9c model: N/A serial: N/A
charge: N/A status: full
Device-2: ps-controller-battery-7c:66:ef:30:b2:4d model: N/A serial: N/A
Info: model: AMD Ryzen 7 8700G w/ Radeon 780M Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705206
Speed (MHz): avg: 2744 min/max: 400/5176 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2744 2: 2744 3: 2744
4: 2744 5: 2744 6: 2744 7: 2744 8: 2744 9: 2744 10: 2744 11: 2744 12: 2744
13: 2744 14: 2744 15: 2744 16: 2744 bogomips: 134441
Device-1: Advanced Micro Devices [AMD/ATI] Vega 10 XL/XT [Radeon RX 56/64]
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 03:00.0
chip-ID: 1002:687f class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4, DP-5, DP-6, DP-7, HDMI-A-2, Writeback-1, eDP-1
bus-ID: 12:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 47.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5360x1440
display-ID: 0
Monitor-1: DP-3 pos: primary,left model: Samsung S34CG50 serial: <filter>
built: 2024 res: mode: 3440x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 3440x1440
min: 720x400
Monitor-2: HDMI-A-1 pos: right model: Sharp HDMI built: 2008 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 59 gamma: 1.2
size: 820x460mm (32.28x18.11") diag: 940mm (37") ratio: 16:9 modes:
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX Vega (radeonsi vega10
LLVM 19.1.6 DRM 3.59 6.12.9-hardened1-1-hardened) device-ID: 1002:687f
API: Vulkan v: 1.4.303 layers: 8 device: 0 type: discrete-gpu name: AMD
Radeon RX Vega (RADV VEGA10) driver: N/A device-ID: 1002:687f
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV GFX1103_R1) driver: N/A device-ID: 1002:15bf
19.1.6 256 bits) driver: N/A device-ID: 10005:0000
Device-1: Advanced Micro Devices [AMD/ATI] Vega 10 HDMI Audio [Radeon 56/64]
bus-ID: 03:00.1 chip-ID: 1002:aaf8 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Sony DualShock 4 [CUH-ZCT2x]
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3.1:8 chip-ID: 054c:09cc class-ID: 0300
Device-5: Sony DualSense wireless controller (PS5)
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 054c:0ce6 class-ID: 0300
API: ALSA v: k6.12.9-hardened1-1-hardened status: kernel-api tools: N/A
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak]
vendor: Rivet Networks Killer driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2725 class-ID: 0280
Device-2: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Sony DualSense wireless controller (PS5)
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:7 chip-ID: 8087:0032
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 1.82 TiB used: 24.16 GiB (1.3%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 45.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Transcend model: N/A size: 1.87 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: TS37 scheme: MBR
ID-1: / raw-size: 292.97 GiB size: 292.97 GiB (100.00%)
used: 23.77 GiB (8.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-3f3b4f50-3273-4243-9a54-f15b65d318e3
used: 31.3 MiB (32.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 292.97 GiB size: 292.97 GiB (100.00%)
ID-4: /var/log raw-size: 292.97 GiB size: 292.97 GiB (100.00%)
ID-5: /var/tmp raw-size: 292.97 GiB size: 292.97 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.9 C mobo: 40.8 C
GPU: device: amdgpu temp: 52.0 C mem: 46.0 C fan: 408 watts: 17.00
device: amdgpu temp: 46.0 C watts: 38.09
Memory: total: 32 GiB note: est. available: 30.45 GiB used: 5.12 GiB (16.8%)
Processes: 483 Power: uptime: 15m states: freeze,mem suspend: deep
avail: s2idle wakeups: 0 services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1503 libs: 461 tools: octopi,paru Compilers:
clang: 19.1.6 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date:     2025-01-11
Last full system update: 2025-01-15
That looks like a Mini-ITX desktop, meaning it should be in a case that is grounded, and ESD should be a rare problem, even if you regularly zap the case or USB peripherals. If you have a bad ground, that’s a potentially bigger problem, and should be fixed in the building itself.
Seems like checking out your grounds may be in order, and possibly adding a UPS, if power failures are a regular thing.
Use the forum search, your keyword is ntfsfix.
Also, we do not recommend using NTFS partitions excessively on Linux. Do this at your own risk.
Created a BTRFS partition with LUKS2 which is not not available as an option.
This partition is not readable by Steam Client.
This partition is also not able to be deleted.
Happened in another case with another board as well and it is not often.
A correctly mounted and decrypted BTRFS partition should also be readable by steam without any problems. And if not, then use ext4.
EDIT: Oh, you mean steam on windows…I misunderstood that^^.
The very first step should be to ensure that you have a stable system. Then you won’t have the problem that a mounted NTFS partition is not unmounted correctly.
Have you tried ntfsfix?
