Iv'e tried two different apps to navigate around my laptop gui's. Libinput and touchegg are both promising yet lately neither of them enables me o switch desktop screens. When I used the inputs in libinput, I get the following popup from kdialog
The window manager is configured to consider the screen with the mouse on it as active one.
Therefore it is not possible to switch to a screen explicitly.
How do I change the window manager configuration to resolve this issue?
$ inxi -Faz
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=5b233270-aca9-43fa-875a-f2202c89bf97
systemd.unified_cgroup_hierarchy=1 resume=UUID=00f1ca0e-479b-4a10-a69f-981212334128 loglevel=3
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503QS_GA503QS v: 1.0 serial:
Mobo: ASUSTeK model: GA503QS v: 1.0 serial: UEFI: American Megatrends LLC.
v: GA503QS.408 date: 05/11/2021
Battery: ID-1: BAT0 charge: 67.8 Wh (79.5%) condition: 85.3/90.0 Wh (94.8%) volts: 15.9 min: 15.9
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 50 (80) stepping: 0 microcode: A50000C cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 105402
Speed: 1394 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz): 1: 1394 2: 1958
3: 1397 4: 1396 5: 1999 6: 1395 7: 1394 8: 1396 9: 1395 10: 1394 11: 1396 12: 1396 13: 1405
14: 1395 15: 1397 16: 1397
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics: Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB] vendor: ASUSTeK
driver: nvidia v: 470.74 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:249c
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 07:00.0
chip-ID: 1002:1638 class-ID: 0300
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0") s-diag: 777mm (30.6")
Monitor-1: eDP-1 res: 2560x1440 hz: 165 dpi: 189 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.14-zen1-1-zen LLVM 12.0.1) v: 4.6 Mesa 21.2.4
direct render: Yes
Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: down mac:
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0 chip-ID: 8086:2723
IF: wlp4s0 state: up mac:
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3 chip-ID: 8087:0029
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Drives: Local Storage: total: 2.75 TiB used: 446.43 GiB (15.8%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: SK Hynix model: HFM001TD3JX013N size: 953.87 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: 41000C20 temp: 24.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial:
rev: 2B2QGXA7 temp: 29.9 C scheme: GPT
Partition: ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 446.43 GiB (24.4%) fs: btrfs
dev: /dev/nvme1n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 547 KiB (0.2%) fs: vfat
dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 446.43 GiB (24.4%) fs: btrfs
ID-4: /var/log raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 446.43 GiB (24.4%) fs: btrfs
ID-5: /var/tmp raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 446.43 GiB (24.4%) fs: btrfs
ID-1: swap-1 type: partition size: 33.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p3 maj-min: 259:3
ID-2: swap-2 type: zram size: 30.77 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 416 Uptime: 1m wakeups: 3 Memory: 30.77 GiB used: 3.07 GiB (10.0%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1732 pacman: 1723
lib: 520 snap: 9 Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.08
