I don’t know how to write about a glitch in the kde bug report, but when you click switch user (and I have only one) in the running garuda and on another distribution, Arch also checked, you don’t change the login, but you change the Wayland interface to X11 or vice versa, then no Having managed to log into the system, the login window freezes and only resetting the PC helps.
Kernel: 6.8.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8d024738-0c86-44cf-8e50-cf9b720d6939 rw rootflags=subvol=@
quiet resume=UUID=4cad94ff-4c56-4c19-8602-e2f6b377d041 loglevel=3 ibt=off
Type: Desktop System: Micro-Star product: MS-7B89 v: 1.0
Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
Megatrends LLC. v: 2.H0 date: 07/27/2022
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2550 high: 3600 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3600
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 3600 9: 2200 10: 2200 11: 3600
12: 2200 bogomips: 86400
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: ASUSTeK
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none off: HDMI-A-2 empty: DP-1, DP-2, HDMI-A-1,
Unknown-2 bus-ID: 26:00.0 chip-ID: 10de:1f47 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: HDMI-A-2 res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.76
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060
SUPER/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2060 SUPER driver: nvidia v: 550.76 device-ID: 10de:1f47
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.6-arch1.2 (LLVM 17.0.6)
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
bus-ID: 26:00.1 chip-ID: 10de:10f9 class-ID: 0403
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0951:16a4 class-ID: 0300
API: ALSA v: k6.8.8-zen1-1-zen status: kernel-api with: aoss
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.47 TiB used: 518.95 GiB (34.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: AMD Radeon model: R5MP120G8
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: T1103F0L temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WD BLACK SN750 SE 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 711250WD temp: 38.9 C scheme: GPT
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
used: 37.37 GiB (76.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
ID-2: /boot/efi raw-size: 1.47 GiB size: 1.46 GiB (99.80%)
used: 584 KiB (0.0%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-3: /home raw-size: 399.84 GiB size: 399.84 GiB (100.00%)
used: 340.19 GiB (85.1%) fs: btrfs dev: /dev/nvme1n1p4 maj-min: 259:9
ID-4: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-2: swap-2 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8
System Temperatures: cpu: 44.4 C mobo: N/A
Memory: total: 16 GiB available: 15.54 GiB used: 3.94 GiB (25.4%)
Processes: 375 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,
Packages: 2026 pm: pacman pkgs: 2010 libs: 523
tools: octopi,pamac,paru,yay pm: flatpak pkgs: 16 Compilers: clang: 17.0.6
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date: 2024-02-21
Last full system update: 2024-05-01
