I have a Dell T5810 with Intel Xeon E5-1650 v3 processor (6 core, 12 thread) and Nvidia 1060 6 GB GPU. I am interested in upgrading the CPU to the Xeon E5-2687W v4 (12 core, 24 thred) to look at improving performance in games. The processor is only about $40. I suspect that upgrading the gpu will also be needed, but I would like to see how the performance does after each step. Anyway, in reading about this, it was recommended to updated the bios before the cpu is changed. I found instructions for this on linux Dell systems: Update the Dell BIOS in a Linux or Ubuntu environment | Dell US . In other reading, I noted that there were comments about the need to turn off Bitlocker (I gather this is disk encryption in Windows systems) before updating or there might be problems in booting after BIOS updating (disk not identified, etc). Since I have two drives (one bootable for the Garuda OS, the other only data–no dual booting) that are both passphrase protected and encrypted, I wondered if there would be issues with doing a BIOS update in Garuda OS/linux. Does anyone have experience with BIOS updating with protected encrypted drives in Garuda OS? Thanks in advance.
Kernel: 6.9.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=73b3631e-3dec-4209-9c71-4928bd70fb46 rw rootflags=subvol=@
quiet rd.luks.uuid=a8e40cc9-41be-4434-8bf9-423936703f72
rd.luks.uuid=f79a930f-07d4-4043-878d-b926518407cc
resume=/dev/mapper/luks-f79a930f-07d4-4043-878d-b926518407cc loglevel=3
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop System: Dell product: Precision Tower 5810 v: 01
serial: <superuser required> Chassis: type: 7 serial: <superuser required>
Mobo: Dell model: 0K240Y v: A01 serial: <superuser required>
part-nu: Precision Tower 5810 uuid: <superuser required> UEFI-[Legacy]: Dell
v: A02 date: 09/05/2014
Info: model: Intel Xeon E5-1650 v3 bits: 64 type: MT MCP arch: Haswell
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3F (63) stepping: 2 microcode: 0x49
L3: 15 MiB desc: 1x15 MiB
Speed (MHz): avg: 3441 high: 3800 min/max: 1200/3800 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3800 2: 3800 3: 3800
4: 3800 5: 3800 6: 1950 7: 3800 8: 3800 9: 3800 10: 1348 11: 3800 12: 3800
bogomips: 83804
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: eVga.com.
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1
bus-ID: 02:00.0 chip-ID: 10de:1c03 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: HDMI-A-1 res: 3440x1440 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 6GB driver: nvidia v: 555.58.02 device-ID: 10de:1c03
Device-1: Intel C610/X99 series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20 class-ID: 0403
Device-2: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-3: NVIDIA GP106 High Definition Audio vendor: eVga.com.
bus-ID: 02:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.9.8-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f020 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-9:4 chip-ID: 8087:0029
Hardware-1: Intel SATA Controller [RAID Mode] driver: ahci v: 3.0 port: f000
bus-ID: 00:1f.2 chip-ID: 8086:2826 rev: N/A class-ID: 0104
Local Storage: total: 1.03 TiB used: 951.57 GiB (90.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: THNSNJ128GCSU
tech: SSD serial: <filter> fw-rev: 0101 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS721010KLA330
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: A9CA scheme: GPT
ID-1: / raw-size: 84.84 GiB size: 84.84 GiB (100.00%) used: 27.8 GiB (32.8%)
mapped: luks-a8e40cc9-41be-4434-8bf9-423936703f72
ID-2: /home raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
used: 27.8 GiB (32.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-3: /var/log raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
ID-4: /var/tmp raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
mapped: luks-f79a930f-07d4-4043-878d-b926518407cc
ID-2: swap-2 type: zram size: 31.27 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): cpu: 1015
Memory: total: 32 GiB available: 31.27 GiB used: 4.44 GiB (14.2%)
Processes: 402 Power: uptime: 3h 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2114 libs: 600
tools: gnome-software,octopi,paru Compilers: clang: 18.1.8 gcc: 14.1.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-07-08
Last full system update: 2024-07-09
