Hello guys. I started using Garuda about 4 days ago and everything worked great. Until I booted my pc after hibernating it for the first time while ProtonVPN (proton-vpn-gtk-app from the extra repo) was active. Since then my wifi stopped working. It seems no driver is active anymore. I tried rebooting, modprobing iwlwifi, reinstalling linux-firmware, the linux-lts kernel and nothing seems to solve it. Wifi doesn’t even work on live-usb’s anymore when I boot from those.
Here are some terminal outputs that might be helpful:
Kernel: 6.16.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=47a12b3a-92cd-4eb2-84ba-4312eb72020b rw rootflags=subvol=@
loglevel=3 quiet
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Desktop System: LENOVO product: 90RC0061MH v: Legion T5 26AMR5
Mobo: LENOVO model: 3716 v: SDK0J40709 WIN 3259676077159
serial: <superuser required> part-nu: LENOVO_MT_90RC_BU_Lenovo_FM_Legion T5
26AMR5 uuid: <superuser required> UEFI: LENOVO v: O4MKT1CA
date: 03/24/2021
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 2
desc: 8x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3609 min/max: 560/4427 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3609 2: 3609 3: 3609
4: 3609 5: 3609 6: 3609 7: 3609 8: 3609 9: 3609 10: 3609 11: 3609 12: 3609
13: 3609 14: 3609 15: 3609 16: 3609 bogomips: 114984
ssse3 svm
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Micro-Star MSI
driver: nvidia v: 580.76.05 alternate: nouveau,nvidia_drm
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 06:00.0 chip-ID: 10de:2484 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nv_platform,nvidia,nvidia-nvswitch
display-ID: 0
Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2020 res: mode: 2560x1440 hz: 100 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.76.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
API: Vulkan v: 1.4.321 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 580.76.05
device-ID: 10de:2484 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.1-arch1.5 (LLVM
Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 06:00.1 chip-ID: 10de:228b class-ID: 0403
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.16.4-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp2s0f0u2 state: unknown speed: -1 duplex: half mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0029
Local Storage: total: 953.87 GiB used: 389.32 GiB (40.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-1T00-1001 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11170101 temp: 47.9 C scheme: GPT
ID-1: / raw-size: 936.55 GiB size: 936.55 GiB (100.00%)
used: 389.32 GiB (41.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 936.55 GiB size: 936.55 GiB (100.00%)
ID-4: /var/log raw-size: 936.55 GiB size: 936.55 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.55 GiB size: 936.55 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 32 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.02 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 58.5 C mobo: N/A
Memory: total: 16 GiB available: 15.47 GiB used: 4.71 GiB (30.5%)
Processes: 441 Power: uptime: 42m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2340 libs: 573 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3
default: fish v: 4.0.2 running-in: konsole inxi: 3.3.39
Garuda (2.8.2-2):
System install date: 2025-08-31
Last full system update: 2025-09-04
22/23 checks run in 1.01 seconds ⌛
Powered by garuda-health 🦅
lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
Subsystem: Advanced Micro Devices, Inc. [AMD] Device 1453
Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Subsystem: Lenovo Device 3716
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 7
01:00.0 Non-Volatile memory controller: Sandisk Corp SanDisk Extreme Pro / WD Black SN750 / PC SN730 / Red SN700 NVMe SSD
Subsystem: Sandisk Corp SanDisk Extreme Pro / WD Black SN750 / PC SN730 / Red SN700 NVMe SSD
Kernel driver in use: nvme
Kernel modules: nvme
02:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset USB 3.1 XHCI Controller
Kernel driver in use: xhci_hcd
02:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset SATA Controller
Kernel driver in use: ahci
02:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset Switch Upstream Port
Subsystem: ASMedia Technology Inc. Device 0201
03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset Switch Downstream Port
Subsystem: ASMedia Technology Inc. Device 3308
03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset Switch Downstream Port
04:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
DeviceName: RTL8111E Giga LAN
Subsystem: Intel Corporation Device 0080
Kernel modules: iwlwifi
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Kernel driver in use: r8169
Kernel modules: r8169
06:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3070] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 3906
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
06:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
07:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
08:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
08:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Kernel driver in use: ccp
Kernel modules: ccp
08:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
08:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
DeviceName: Realtek ALC1220
sudo dmesg | grep iwlwifi
[ 5.110886] iwlwifi 0000:04:00.0: enabling device (0000 -> 0002)
[ 5.211723] iwlwifi 0000:04:00.0: CSR_RESET = 0x10
[ 5.211728] iwlwifi 0000:04:00.0: Host monitor block 0x0 vector 0x0
[ 5.211734] iwlwifi 0000:04:00.0: value [iter 0]: 0x3f7f0c32
[ 5.211740] iwlwifi 0000:04:00.0: value [iter 1]: 0x3f7f0c30
[ 5.211744] iwlwifi 0000:04:00.0: value [iter 2]: 0x3f7f8430
[ 5.211749] iwlwifi 0000:04:00.0: value [iter 3]: 0x3f7f8030
[ 5.211753] iwlwifi 0000:04:00.0: value [iter 4]: 0x3f7f0830
[ 5.211758] iwlwifi 0000:04:00.0: value [iter 5]: 0x3f7f0830
[ 5.211762] iwlwifi 0000:04:00.0: value [iter 6]: 0x3f7f0830
[ 5.211767] iwlwifi 0000:04:00.0: value [iter 7]: 0x3f7f8c30
[ 5.211771] iwlwifi 0000:04:00.0: value [iter 8]: 0x3f7f0c30
[ 5.211776] iwlwifi 0000:04:00.0: value [iter 9]: 0x3f7f0c30
[ 5.211780] iwlwifi 0000:04:00.0: value [iter 10]: 0x3f7f8030
[ 5.211785] iwlwifi 0000:04:00.0: value [iter 11]: 0x3f7f0030
[ 5.211790] iwlwifi 0000:04:00.0: value [iter 12]: 0x3f7f8830
[ 5.211794] iwlwifi 0000:04:00.0: value [iter 13]: 0x3f7f0c30
[ 5.211799] iwlwifi 0000:04:00.0: value [iter 14]: 0x3f7f0430
[ 5.211801] iwlwifi 0000:04:00.0: Host monitor block 0x0 vector 0x1
[ 5.211806] iwlwifi 0000:04:00.0: value [iter 0]: 0x044466c2
[ 5.211811] iwlwifi 0000:04:00.0: value [iter 1]: 0x044466c2
[ 5.211816] iwlwifi 0000:04:00.0: value [iter 2]: 0x044466c2
[ 5.211821] iwlwifi 0000:04:00.0: value [iter 3]: 0x044466c2
[ 5.211825] iwlwifi 0000:04:00.0: value [iter 4]: 0x044466c2
[ 5.211830] iwlwifi 0000:04:00.0: value [iter 5]: 0x044466c2
[ 5.211834] iwlwifi 0000:04:00.0: value [iter 6]: 0x044466c2
[ 5.211839] iwlwifi 0000:04:00.0: value [iter 7]: 0x044466c2
[ 5.211978] iwlwifi 0000:04:00.0: value [iter 8]: 0x044466c2
[ 5.212038] iwlwifi 0000:04:00.0: value [iter 9]: 0x044466c2
[ 5.212042] iwlwifi 0000:04:00.0: value [iter 10]: 0x044466c2
[ 5.212047] iwlwifi 0000:04:00.0: value [iter 11]: 0x044466c2
[ 5.212051] iwlwifi 0000:04:00.0: value [iter 12]: 0x044466c2
[ 5.212057] iwlwifi 0000:04:00.0: value [iter 13]: 0x044466c2
[ 5.212062] iwlwifi 0000:04:00.0: value [iter 14]: 0x044466c2
[ 5.212065] iwlwifi 0000:04:00.0: Host monitor block 0x0 vector 0x6
[ 5.212070] iwlwifi 0000:04:00.0: value [iter 0]: 0xb00c4471
[ 5.212074] iwlwifi 0000:04:00.0: value [iter 1]: 0xf00c4471
[ 5.212079] iwlwifi 0000:04:00.0: value [iter 2]: 0xf00c4471
[ 5.212084] iwlwifi 0000:04:00.0: value [iter 3]: 0xa00c4471
[ 5.212088] iwlwifi 0000:04:00.0: value [iter 4]: 0xa00c4471
[ 5.212093] iwlwifi 0000:04:00.0: value [iter 5]: 0xe00c4471
[ 5.212098] iwlwifi 0000:04:00.0: value [iter 6]: 0xe00c4471
[ 5.212102] iwlwifi 0000:04:00.0: value [iter 7]: 0xb00c4471
[ 5.212107] iwlwifi 0000:04:00.0: value [iter 8]: 0xf00c4471
[ 5.212112] iwlwifi 0000:04:00.0: value [iter 9]: 0xf00c4471
[ 5.212117] iwlwifi 0000:04:00.0: value [iter 10]: 0xa00c4471
[ 5.212122] iwlwifi 0000:04:00.0: value [iter 11]: 0xa00c4471
[ 5.212127] iwlwifi 0000:04:00.0: value [iter 12]: 0xa00c4471
[ 5.212132] iwlwifi 0000:04:00.0: value [iter 13]: 0xf00c4471
[ 5.212137] iwlwifi 0000:04:00.0: value [iter 14]: 0xb00c4471
[ 5.212139] iwlwifi 0000:04:00.0: Host monitor block 0x22 vector 0x0
[ 5.212145] iwlwifi 0000:04:00.0: value [iter 0]: 0x00000000
[ 5.212464] iwlwifi 0000:04:00.0: probe with driver iwlwifi failed with error -110
Any help is greatly appreciated because I’m totally stumped.
