I have this wifi adapter Amazon.com: EDUP USB 3.0 WiFi 6E Adapter for PC, AXE3000, Mt7921au, 802.11ax, Tri-Band 6GHz/5GHz/2.4GHz, USB Wi-Fi Dongle Wireless Network Card, Support Windows 11/10 (Install Driver) & Linux (Plug and Play) : Electronics and it has worked for me for a year or so perfectly with good speed but after trying everything under the sun to fix this weird drop in speed i may have a made it worse than it was so any help would be appreciated. ive changed kernels ive updated a million times im kinda lost at this point and would love some help. Thank you! ^-^
Kernel: 6.18.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=4076ab94-73b0-40e1-8701-24fcc928a03e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
Mobo: ASUSTeK model: ROG STRIX B850-A GAMING WIFI v: Rev 1.xx
Firmware: UEFI vendor: American Megatrends v: 1001 date: 01/11/2025
Device-1: apple_mfi_fastcharge_5-13 model: N/A serial: N/A charge: N/A
status: N/A
Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB404023
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 2985 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 2985 2: 2985 3: 2985
4: 2985 5: 2985 6: 2985 7: 2985 8: 2985 9: 2985 10: 2985 11: 2985 12: 2985
13: 2985 14: 2985 15: 2985 16: 2985 bogomips: 150399
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: XFX driver: amdgpu v: kernel arch: RDNA-3
code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1,
Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-2 empty: DP-4,Writeback-2 bus-ID: 0d:00.0
chip-ID: 1002:13c0 class-ID: 0300 temp: 46.0 C
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
gpu: amdgpu d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-3 pos: primary,top-left model: Dell AW3423DWF
serial: <filter> built: 2023 res: mode: 3440x1440 hz: 165 scale: 100% (1)
dpi: 109 gamma: 1.2 size: 800x337mm (31.5x13.27") diag: 868mm (34.2")
modes: max: 3440x1440 min: 720x400
Monitor-2: HDMI-A-2 pos: bottom-r model: Dell SE2717H/HX serial: <filter>
built: 2017 res: mode: 1920x1080 hz: 50 scale: 100% (1) dpi: 82 gamma: 1.2
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 21.1.6 DRM 3.64 6.18.2-zen2-1-zen) device-ID: 1002:744c
memory: 19.53 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 25.3.2-arch1.1
device-ID: 1002:744c surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 7 9800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 25.3.2-arch1.1 device-ID: 1002:13c0 surfaces: N/A
device: 2 type: cpu name: llvmpipe (LLVM 21.1.6 256 bits)
driver: mesa llvmpipe v: 25.3.2-arch1.1 (LLVM 21.1.6)
lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
chip-ID: 0b05:1b9b class-ID: 0300
API: ALSA v: k6.18.2-zen2-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0 chip-ID: 8086:125c
Device-2: MediaTek Wireless_Device driver: mt7921u type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1:2 chip-ID: 0e8d:7961
IF: wlan0 state: up mac: <filter>
Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
wpa_supplicant
Local Storage: total: 5.63 TiB used: 2.97 TiB (52.7%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211210WD temp: 48.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 49.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:6 vendor: Crucial model: CT2000P310SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: V8CR000 temp: 45.9 C
ID-4: /dev/nvme3n1 maj-min: 259:8 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 953.87 GiB block-size: physical: 512 B
fw-rev: VB421D65 temp: 36.9 C scheme: GPT
ID-5: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 072 scheme: GPT
ID-6: /dev/sdb maj-min: 8:16 vendor: Apple model: iPod size: 148.86 GiB
block-size: physical: 4096 B logical: 4096 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.62
scheme: MBR
ID-1: / raw-size: 102.01 GiB size: 102.01 GiB (100.00%)
used: 75.67 GiB (74.2%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
used: 1.5 MiB (1.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 102.01 GiB size: 102.01 GiB (100.00%)
ID-4: /var/log raw-size: 102.01 GiB size: 102.01 GiB (100.00%)
ID-5: /var/tmp raw-size: 102.01 GiB size: 102.01 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.9 C mobo: 46.0 C
GPU: device: amdgpu temp: 46.0 C device: amdgpu temp: 52.0 C mem: 68.0 C
fan: 622 watts: 63.00
Memory: total: 32 GiB note: est. available: 30.49 GiB used: 6.39 GiB (21.0%)
Processes: 516 Power: uptime: 19m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.17 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1790 libs: 410 tools: gnome-software, octopi,
paru, trizen Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9
default: fish v: 4.3.1 running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2025-10-07
Garuda release: 240428
Last full system update: 2025-12-29 ↻
Relevant software: snapper NetworkManager dracut nvidia-utils garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
Failed units: run-media-yukina-RX-0011.mount
