I’m getting painfully slow wifi speeds on this Garuda installation. For the details,
- I haven’t changed any settings, installed any apps or packages that might hamper with the wifi.
- I had updated it twice by now from the Garuda Assistant. The issue appeared much before that.
- I only have Garuda installed on this machine.
- This issue occurs only on the wifi and not on ethernet/USB tethering from my phone.
- The speeds I could get before wire within the range of 6.5MiB/s to 7.3 MiB/s. Now it is maximum at 280KiB/s
- I have been searching about the issue for 6 days now, but none of them worked.
- I can ping google.com, 8.8.8.8, 1.1.1.1, etc. I can open only several websites. Also, Youtube doesn’t actually open but other websites that I can open and that contain Youtube videos playing in them can be played.
- Connection strength is full.
Now the inxi
Kernel: 6.9.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=dcbe7884-5cef-4a80-a184-d5b621600b37 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: N/A model: ZRD1105 v: REV V52.9 serial: N/A
uuid: 03000200-0400-0500-0006-000700080009
UEFI-[Legacy]: American Megatrends v: 5.12 date: 02/15/2023
Info: model: Intel Core i3-7100 socket: LGA1151 (U3E1) note: check bits: 64
type: MT MCP arch: Kaby Lake gen: core 7 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
microcode: 0xF8
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3899 high: 3901 min/max: 800/3900 base/boost: 3900/8300
scaling: driver: intel_pstate governor: powersave volts: 1.0 V
ext-clock: 100 MHz cores: 1: 3899 2: 3901 3: 3898 4: 3900 bogomips: 31199
Device-1: Intel HD Graphics 630 driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1
empty: DP-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5912 class-ID: 0300
Display: server: X.Org v: 24.1 with: Xwayland v: 24.1.0
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 model-id: GVE 0x2513 serial: <filter> built: 2023
res: 1920x1080 hz: 75 dpi: 83 gamma: 1.2 size: 590x330mm (23.23x12.99")
diag: 676mm (26.6") ratio: 16:9 modes: max: 1920x1080 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.7-arch1.3
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:5912 memory: 7.5 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 630 (KBL GT2) driver: mesa intel v: 24.0.7-arch1.3
device-ID: 8086:5912 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170
API: ALSA v: k6.9.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: n/a (root, process) with:
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
IF-ID-1: wlan1 state: up mac: <filter>
Info: services: iwd, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Realtek RTL8723BU 802.11b/g/n WLAN Adapter driver: btusb,rtl8xxxu
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:7
chip-ID: 0bda:b720 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.0
Local Storage: total: 762.83 GiB used: 211.22 GiB (27.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 256GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 11004101 temp: 41.9 C
SMART: yes health: PASSED on: 56d 7h cycles: 2,121
read-units: 68,877,639 [35.2 TB] written-units: 56,301,830 [28.8 TB]
model: WD5000LPVX-22V0TT0 family: Blue Mobile size: 465.76 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 1A01 temp: 34 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 300d 22h cycles: 7461
Old-Age: g-sense error rate: 110
ID-3: /dev/sdb maj-min: 8:16 model: USB Disk 2.0 size: 58.59 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00 scheme: MBR
ID-1: / raw-size: 160 GiB size: 160 GiB (100.00%) used: 69.53 GiB (43.5%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /home raw-size: 160 GiB size: 160 GiB (100.00%)
used: 69.53 GiB (43.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-3: /var/log raw-size: 160 GiB size: 160 GiB (100.00%)
maj-min: 259:5
ID-4: /var/tmp raw-size: 160 GiB size: 160 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 7.68 GiB used: 208.8 MiB (2.7%)
System Temperatures: cpu: 44.0 C pch: 52.0 C mobo: N/A
Memory: total: 8 GiB available: 7.68 GiB used: 3.92 GiB (51.1%) igpu: 32 MiB
Processes: 259 Power: uptime: 1h 8m states: freeze,mem,disk
suspend, test_resume image: 3.06 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1758 libs: 519 tools: octopi,pamac,paru,yay
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi (sudo) default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
System install date: 2024-04-24
Last full system update: 2024-05-23
Is partially upgraded: Yes
Please inform if any information is missing.
