Hey! So today morning after a fresh install(Not a bug it was working flawlessly yesterday) the WIFI symbol turned yellow signifying no internet connection but the WIFI is working totally fine on other devices even on the same PC! i am making this topic from that pc itself and a reboot didn't help i cant update system because seemingly pacman/paru thinks i dont have a working internet connection.
System: Kernel: 5.13.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e8ce5208-37d5-4260-9f6a-50ef36f757b6
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 80TJ v: Lenovo ideapad 110-15ACL serial: <filter> Chassis:
type: 10 v: Lenovo ideapad 110-15ACL serial: <filter>
Mobo: LENOVO model: Nano 5A8 v: SDK0J40679 WIN serial: <filter> UEFI: Lenovo v: 1QCN32WW
date: 08/18/2016
Battery: ID-1: BATT charge: 3.9 Wh (100.0%) condition: 3.9/23.8 Wh (16.5%) volts: 12.2 min: 10.8
model: LENOVO LCFC type: Unknown serial: <filter> status: Full
CPU: Info: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64 type: MCP
arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1 microcode: 7030105 cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 17566
Speed: 2127 MHz min/max: 1000/2200 MHz boost: enabled Core speeds (MHz): 1: 2127 2: 2168
3: 1736 4: 2096
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Lenovo driver: radeon v: kernel
alternate: amdgpu bus-ID: 00:01.0 chip-ID: 1002:9851 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile]
vendor: Lenovo driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0 chip-ID: 1002:6660
class-ID: 0380
Device-3: IMC Networks EasyCamera type: USB driver: uvcvideo bus-ID: 2-1.2:4 chip-ID: 13d3:a745
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: ati,radeon
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.13.4-zen1-1-zen LLVM 12.0.1) v: 4.5 Mesa 21.1.5
direct render: Yes
Audio: Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.13.4-zen1-1-zen running: yes
Network: Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo
driver: ath10k_pci v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo driver: r8169 v: kernel
port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 2-1.1:3 chip-ID: 0cf3:e360
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 223.58 GiB used: 9.04 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS240G2G0A-00JH30 size: 223.58 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 0000 scheme: GPT
Partition: ID-1: / raw-size: 74.98 GiB size: 74.98 GiB (100.00%) used: 9.01 GiB (12.0%) fs: btrfs
dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 38.3 MiB (7.5%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 74.98 GiB size: 74.98 GiB (100.00%) used: 9.01 GiB (12.0%) fs: btrfs
ID-4: /var/log raw-size: 74.98 GiB size: 74.98 GiB (100.00%) used: 9.01 GiB (12.0%) fs: btrfs
ID-5: /var/tmp raw-size: 74.98 GiB size: 74.98 GiB (100.00%) used: 9.01 GiB (12.0%) fs: btrfs
ID-1: swap-1 type: zram size: 6.69 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 62.2 C mobo: N/A
GPU: device: radeon temp: 45.0 C device: radeon temp: 65.0 C
Info: Processes: 204 Uptime: 41m wakeups: 1 Memory: 6.69 GiB used: 2.59 GiB (38.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1124 lib: 288
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.05
NOte - I can install packages
