Hello,
i am recently install garuda linux in my laptop . I have wifi problem in my laptop wifi adapter name Qualcomm Atheros AR9287 and tell me how to fix it.
garuda-inxi output:
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a6bb07ff-d7e2-424c-ae46-90d01cc4b955 rw [email protected]
resume=UUID=f5d9e4c4-0c89-40da-a50c-11eafe3df865 loglevel=3 ibt=off
Type: Laptop System: Acer product: Aspire 4752 v: V2.19
Mobo: Acer model: Aspire 4752 v: V2.19 serial: <superuser required>
UEFI: Phoenix v: 2.19 date: 03/19/2012
ID-1: BAT0 charge: 24.5 Wh (100.0%) condition: 24.5/48.8 Wh (50.1%)
volts: 12.5 min: 11.1 model: SANYO AS10D31 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i3-2350M bits: 64 type: MT MCP arch: Sandy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 high: 800 min/max: 800/2300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 798 4: 800
bogomips: 18358
vulnerable
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-6
process: Intel 32nm built: 2011 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0116
Device-2: Sunplus 1.3M HD WebCam type: USB driver: uvcvideo
bus-ID: 1-1.5:3 chip-ID: 04fc:2801 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.5 with: Xwayland v: 22.1.6
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: Chi Mei Opto 0x1459 built: 2008 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 3.3 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 3000 (SNB
GT2) direct render: Yes
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
Device-1: Qualcomm Atheros AR9287 Wireless Network Adapter
vendor: Foxconn T77H167.00 driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:002e class-ID: 0280
Device-2: Broadcom NetLink BCM57785 Gigabit Ethernet PCIe
vendor: Acer Incorporated ALI driver: tg3 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 14e4:16b5
IF: enp3s0f0 state: down mac: <filter>
IF-ID-1: bnep0 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Foxconn / Hon Hai Acer Module type: USB driver: btusb v: 0.8
bus-ID: 2-1.4:3 chip-ID: 0489:e033 class-ID: fe01 serial: <filter>
Local Storage: total: 465.76 GiB used: 32.64 GiB (7.0%)
model: WD5000BPVT-22A1YT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: GPT
ID-1: / raw-size: 457.44 GiB size: 457.44 GiB (100.00%)
used: 32.64 GiB (7.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 457.44 GiB size: 457.44 GiB (100.00%)
ID-4: /var/log raw-size: 457.44 GiB size: 457.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 457.44 GiB size: 457.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.64 GiB used: 256 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 8.02 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 210 Uptime: 21m wakeups: 1 Memory: 3.65 GiB
used: 2.17 GiB (59.6%) Init: systemd v: 252 default: graphical
pkgs: 1461 libs: 430 tools: octopi,pamac,paru Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.10-1):
System install date: 2022-12-14
Last full system update: 2022-12-15
Failed units: nmb.service systemd-vconsole-setup.service
rfkill list:
0: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
1: acer-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
