Sorry if this issue has been addressed somewhere before, but I wasn’t able to find my exact issue. My wifi seems to work fine on public networks, but will not connect with a password. It gets stuck on “Configuring Interface”. I previously tried OpenSUSE, and it would accept the password and connect. I’m not sure what the issue might be. Any help would be appreciated.
root=UUID=8e06d636-3102-4c39-8fc1-6d55e0fb8a43 rw rootflags=subvol=@
Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-E43C1C25D4880AD6
Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1
serial: <superuser required> uuid: <superuser required> UEFI: Apple
v: 486.0.0.0.0 date: 08/03/2023
ID-1: BAT0 charge: 60.6 Wh (99.8%) condition: 60.7/74.8 Wh (81.2%)
volts: 12.9 min: 11.4 model: SMP bq20z451 type: Li-ion serial: N/A
status: full cycles: 589
Info: model: Intel Core i5-5287U bits: 64 type: MT MCP arch: Broadwell
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 500/3300 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 23199
Device-1: Intel Iris Graphics 6100 vendor: Apple driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:162b
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: Apple Color LCD built: 2013 res: mode: 2560x1600
hz: 60 scale: 100% (1) dpi: 227 gamma: 1.2 size: 286x179mm (11.26x7.05")
diag: 337mm (13.3") ratio: 16:10 modes: 2560x1600
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Graphics 6100 (BDW
GT3) device-ID: 8086:162b memory: 7.58 GiB unified: yes
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: integrated-gpu name: Intel
Iris Graphics 6100 (BDW GT3) driver: N/A device-ID: 8086:162b
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api tools: N/A
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-1: Apple Bluetooth Host Controller driver: btusb,hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
chip-ID: 05ac:8290 class-ID: fe01
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 233.76 GiB used: 88.45 GiB (37.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3A0Q scheme: GPT
ID-1: / raw-size: 233.47 GiB size: 233.47 GiB (100.00%)
used: 88.45 GiB (37.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 233.47 GiB size: 233.47 GiB (100.00%)
ID-4: /var/log raw-size: 233.47 GiB size: 233.47 GiB (100.00%)
ID-5: /var/tmp raw-size: 233.47 GiB size: 233.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
System Temperatures: cpu: 65.0 C pch: 60.0 C mobo: N/A
Memory: total: 16 GiB available: 15.52 GiB used: 2.75 GiB (17.7%)
Processes: 269 Power: uptime: 4h 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1949 libs: 422
tools: gnome-software,octopi,paru pm: flatpak pkgs: 0 Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date: 2025-03-23
Last full system update: 2025-03-24
