WIFI Option Not Showing in ASUS TUF A15
There is no Wifi Options Available I cannot look for the wifi or scan any devices there is literally no option for wifi please can you help me regarding this issue I tried all possible ways, I tried using IWCTL also but it didn't worked, Can someone please Help me I am using internet connecting my mobile as a Ethernet and my work is all pending behind this wifi problem
Hey! Can you please post the output of
ifconfig and what did you mean iwctl didn't work? what was the error?
enp2s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 3c:7c:3f:59:c7:18 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp5s0f4u2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.181.240 netmask 255.255.255.0 broadcast 192.168.181.255
inet6 fe80::ac4b:5a95:c5ff:e258 prefixlen 64 scopeid 0x20
inet6 2409:4041:2d1d:acb8:d836:29f3:ae0c:6e80 prefixlen 64 scopeid 0x0
ether 5e:1e:dd:63:ff:35 txqueuelen 1000 (Ethernet)
RX packets 3533 bytes 2110551 (2.0 MiB)
TX packets 2732 bytes 855200 (835.1 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 10 bytes 1594 (1.5 KiB)
TX packets 10 bytes 1594 (1.5 KiB)
Here is my ifconfig output and iwctl is not showing up any devices when i try to list all devices using iwd
Yep, As i expected.
I would need a little more info
lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU
Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
Kernel driver in use: pcieport
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
Subsystem: ASUSTeK Computer Inc. Device 1e21
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M (rev a1)
Subsystem: ASUSTeK Computer Inc. Device 18bf
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Co
ntroller (rev 15)
Subsystem: ASUSTeK Computer Inc. Device 208f
Kernel modules: r8169
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
Subsystem: Lite-On Communications Inc Device 0810
Kernel modules: rtw88_8822ce
04:00.0 Non-Volatile memory controller: Sandisk Corp WD Blue SN550 NVMe SSD (rev 01)
Subsystem: Sandisk Corp WD Blue SN550 NVMe SSD
Kernel driver in use: nvme
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c7)
Kernel driver in use: amdgpu
Kernel modules: amdgpu
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 1637
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Securit
y Processor
Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Kernel driver in use: ccp
Kernel modules: ccp
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
Subsystem: ASUSTeK Computer Inc. Device 201f
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Process
or (rev 01)
Subsystem: Device 1e21:1043
Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
DeviceName: HD Audio Controller
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
Kernel driver in use: ahci
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
So your card does load in.
Also check the output of the ip link command to see if a wireless interface was created; usually the naming of the wireless network interfaces starts with the letter “w”, e.g. wlan0 or wlp2s0. Then bring the interface up with:
ip link set *interface* up
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp5s0f4u2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group defa
ult qlen 1000
link/ether 5e:1e:dd:63:ff:35 brd ff:ff:ff:ff:ff:ff
It does shows like this when i put ip link command now what can i do to set the interface up and make my wifi run
Can you run this
modprobe r8169
If you get a permission error, just use sudo
Yes I used sudo and it runned but no output
Alrighty, Try iwctl and
ip link
again
ult qlen 1000
3: enp2s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default q
len 1000
link/ether 3c:7c:3f:59:c7:18 brd ff:ff:ff:ff:ff:ff
I am confused RN and have to go get some food. Try this meanwhile
https://wiki.archlinux.org/title/Network_configuration/Wireless#Device_driver
Ok Bro
I hope i can solve this wifi thing
Try to install this driver
This topic was automatically closed after 11 days. New replies are no longer allowed.
