Wifi keeps stopping
Everytime I use my laptop's wifi , after sometime it just stops
My assumption: it keeps stopping when the dl speed is high.
I have to restart everytime this happens.
Please help
I'm a beginner
Wifi keeps stopping after sometime
this is my inxi
  Kernel: 6.4.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=383bc316-ff44-4671-8210-c8a6e5f74b41 rw rootflags=subvol=@
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: Dell product: Inspiron 5567 v: N/A
  Mobo: Dell model: 06316V v: A00 serial: <superuser required> UEFI: Dell
    v: 1.2.8 date: 05/22/2019
  ID-1: BAT0 charge: 10.2 Wh (40.8%) condition: 25.0/42.0 Wh (59.6%)
    volts: 12.2 min: 11.4 model: BYD DELL FW8KR15 type: Li-ion serial: <filter>
    status: charging
  Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 875 high: 2000 min/max: 400/2000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 500 2: 500 3: 2000 4: 500
    bogomips: 15999
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: Realtek Integrated Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0bda:568a
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x06a9 built: 2015 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
  API: ALSA v: k6.4.7-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
    bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
  IF-ID-1: CloudflareWARP state: unknown speed: 10000 Mbps duplex: full
    mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 0cf3:e009
  Local Storage: total: 223.57 GiB used: 163.69 GiB (73.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: HP model: SSD S600 240GB
    tech: SSD serial: <filter> fw-rev: 1A0 scheme: GPT
    used: 163.69 GiB (73.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
    used: 592 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: zram size: 11.58 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 43.0 C pch: 41.0 C mobo: 39.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 0
  Processes: 242 Uptime: 16m wakeups: 31861 Memory: total: 12 GiB
  available: 11.58 GiB used: 3.48 GiB (30.0%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
  pm: pacman pkgs: 1495 libs: 415 tools: gnome-software,pamac,paru Shell: fish
  v: 3.6.1 running-in: gnome-terminal inxi: 3.3.28
  System install date:     2023-07-27
  Last full system update: 2023-07-31
I do not use windows.
I end up rebooting my device all the time .
Please help.
Please, follow the template and post your garuda-inxi as text, you can edit your post.
https://forum.garudalinux.org/search?context=topic&context_id=30106&q=ath10k_pci%20status%3Asolved%20%23issues-assistance%3Awifi-ethernet-bt%20order%3Alatest&skip_context=true
I'd start with the two latest solutions (the kernel boot parameter).
i will try it and get back to you soon
Sorry i am late, i have been busy .
i tried the kernel boot parameter solution from
i am not sure as to what numbers i should add.
im also facing an issue with Waydroid, its wifi does not turn on.
I think i faced the same problem back on arch.
As for DNS servers i have tested them it does not fix it.
Sorry, I'm a bit lost.
Please clarify what you have tried and the results. Let's keep waydroid off: that should be handled with a different topic and cannot be addressed before fixing the main WiFi connection.
"pcie_aspm=off" kernel boot parameter?
pcie_aspm=off ath10k_core.skip_otp=y?
Test different kernels?
Disable IPv6?
I don't see "numbers to be added" there :confused:
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=e677590f-YOUR-NUMB-BERS-HEREo449d2f pcie_aspm=off"
like the YOUR-NUMB-BERS-HERE i dont know what to put there
That was only an example, in the case the user had hibernation (and so resume) enabled...
Just add pcie_aspm=off at the end and follow the instructions. It was written "similar to"...
