Wifi issue
I cant connect tl my wifi, also i am not able to open network assistant from icon nor konsole., when i do it it says usr bin sudo must be owned by uid 0 and have the setup bit set, also another problem, when laptop goes to sleep my password doesnt work. I dont know if these issues are linked or not.
Kernel: 6.4.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=87af4bbc-ad12-465b-bc0a-4120f2d55dae rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 80XL v: Lenovo ideapad 320-15IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 320-15IKB
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI-[Legacy]: LENOVO v: 4WCN25WW date: 05/23/2017
ID-1: BAT0 charge: 20.2 Wh (87.1%) condition: 23.2/30.6 Wh (75.6%)
power: 2.1 W volts: 8.2 min: 7.6 model: CPT-COS L16C2PB2 type: Li-poly
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF4
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1750 high: 2700 min/max: 400/3100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 2700
4: 2700 bogomips: 21599
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:5916
Device-2: NVIDIA GM108M [GeForce 920MX] vendor: Lenovo driver: nvidia
v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134f
class-ID: 0302
Device-3: Syntek EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 174f:116a
Screen-1: 0 s-res: 3200x1080 s-dpi: 96 s-size: 846x285mm (33.31x11.22")
s-diag: 893mm (35.15")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: Lenovo LEN L171p
serial: <filter> built: 2008 res: 1280x1024 hz: 60 dpi: 96 gamma: 1.2
size: 338x270mm (13.31x10.63") diag: 469mm (18.4") ratio: 5:4 modes:
max: 1280x1024 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: ChiMei InnoLux 0x15d5
built: 2015 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: Mesa Intel HD Graphics 620 (KBL
GT2) direct-render: Yes
API: ALSA v: k6.4.10-zen1-1-zen status: kernel-api with: aoss
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 0cf3:e500
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 13.89 GiB (1.5%)
tech: HDD rpm: 5400 serial: <filter> fw-rev: LVM1 scheme: MBR
ID-1: / raw-size: 125 GiB size: 125 GiB (100.00%) used: 4.74 GiB (3.8%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot raw-size: 122.07 GiB size: 122.07 GiB (100.00%)
used: 320 MiB (0.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 122.07 GiB size: 122.07 GiB (100.00%)
used: 1.69 GiB (1.4%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /usr raw-size: 562.37 GiB size: 562.37 GiB (100.00%)
used: 7.15 GiB (1.3%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-5: /var/log raw-size: 125 GiB size: 125 GiB (100.00%)
used: 4.74 GiB (3.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-6: /var/tmp raw-size: 125 GiB size: 125 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.55 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 52.0 C pch: 54.5 C mobo: N/A
Processes: 257 Uptime: 1m wakeups: 1 Memory: total: 8 GiB note: est.
available: 7.55 GiB used: 1.77 GiB (23.4%) Init: systemd v: 254
pm: pacman pkgs: 1820 libs: 522 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date:     2023-08-12
Last full system update: 2023-08-12
This is well known to be a problematic wifi adapter which often requires kernel parameters to function correctly.
There are many threads on this topic:
https://forum.garudalinux.org/search?q=QCA9377%20%23issues-assistance%3Awifi-ethernet-bt%20
Welcome to the Garuda community. :wave:
PS
I edited your OP to correct the formatting of your inxi output.
I trying using
sudo sed '/^GRUB_CMDLINE_LINUX_DEFAULT=/s/"$/ pcie_aspm=off "/g' -i /etc/default/grub
But i still get the.... Must be owned by uid 0...
It sounds like sudo isn't configured properly for some reason. I'm sorry, but I don't have the time available to troubleshoot your sudo issu ATM. Perhaps someone else has the time available to assist you with that issue.
You can can open a root terminal using the su command rather than using sudo. However, you must be careful if operating as root, as dragons lurk in root land and you can get burnt if you're not careful.
You can use kate or garuda-boot-options to edit this line
and add
in
If it fails I would start fresh, IDK what break your fresh install.
