It is not a dual-boot off one partition. Each partition is a separate OS, so I see no problems due to cross-pollution of files. Here are more details though, so hopefully something jumps out as obvious as to why WIFI is suddenly DOA after working fine for many months!
Garuda INXI
  Kernel: 6.10.3-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=06acdcf4-1e32-48ce-acfb-52238c8277f1 rw rootflags=subvol=@
  Desktop: Hyprland v: 0.41.2-169-gb0a70f63 with: waybar tools: swayidle
    avail: swaylock vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0
    serial: <superuser required> Chassis: type: 9 v: Mac-E43C1C25D4880AD6
  Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1
    serial: <superuser required> uuid: <superuser required> UEFI: Apple
    v: 486.0.0.0.0 date: 08/03/2023
  ID-1: BAT0 charge: 59.6 Wh (97.2%) condition: 61.3/74.8 Wh (82.0%)
    volts: 12.4 min: 11.4 model: DP bq20z451 type: Li-ion serial: N/A
    status: discharging cycles: 236
  Info: model: Intel Core i5-5287U bits: 64 type: MT MCP arch: Broadwell
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2301 high: 2904 min/max: 500/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 500 2: 2901 3: 2900
    4: 2904 bogomips: 23201
  Device-1: Intel Iris Graphics 6100 vendor: Apple driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:162b
    compositor: Hyprland v: 0.41.2-169-gb0a70f63 driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model: Apple Color LCD built: 2013 res: 2560x1600 hz: 60
    dpi: 227 gamma: 1.2 scale: 1.597656 size: 286x179mm (11.26x7.05")
    diag: 337mm (13.3") ratio: 16:10 modes: 2560x1600
  API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
    Iris Graphics 6100 (BDW GT3) driver: mesa intel v: 24.1.5-arch1.1
    device-ID: 8086:162b surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.1.5-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
  Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
  API: ALSA v: k6.10.3-zen1-2-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
  Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
    driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
  IF: wlp3s0 state: dormant mac: <filter>
  Device-1: Apple Bluetooth Host Controller driver: btusb,hid-generic,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
    chip-ID: 05ac:8290 class-ID: fe01
  Local Storage: total: 523.22 GiB used: 96.14 GiB (18.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0512G
    size: 465.92 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: JA0Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: USB 3.2Gen1
    size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 224.27 GiB size: 224.27 GiB (100.00%)
    used: 96.14 GiB (42.9%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
    used: 900 KiB (0.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 224.27 GiB size: 224.27 GiB (100.00%)
  ID-4: /var/log raw-size: 224.27 GiB size: 224.27 GiB (100.00%)
  ID-5: /var/tmp raw-size: 224.27 GiB size: 224.27 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 47.0 C pch: 47.0 C mobo: N/A
  Memory: total: 16 GiB available: 15.52 GiB used: 1.59 GiB (10.2%)
  Processes: 248 Power: uptime: 14h 49m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 6.2 GiB Init: systemd v: 256
  Packages: 1520 pm: pacman pkgs: 1514 libs: 406 tools: pacseek,paru
    pm: flatpak pkgs: 6 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: Zsh
    v: 5.9 running-in: kitty inxi: 3.3.35
  System install date:     2024-01-31
  Last full system update: 2024-08-06
  Failed units:            NetworkManager-wait-online.service
hoping journalctl logging of NetworkManager exposes the exact issues:
systemd[1]: Starting Network Manager...
<debug> [1723123912.7388] monotonic timestamp started counting 1.516209570 seconds ago with an offset of 53289.0 seconds to CLOCK_BOOTTIME (local time is 2024-08-08 06:31:52)
<info>  [1723123912.7389] NetworkManager (version 1.48.6-1) is starting... (after a restart, boot:f8b9ce1a-7fbf-4eeb-89ee-6c8164d05703)
<info>  [1723123912.7389] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf, unmanaged-lo.conf)
<debug> [1723123912.7389] CONFIG: config-data[0x627d914e2240]: 4 groups
<debug> [1723123912.7389] CONFIG: [main]
<debug> [1723123912.7389] CONFIG:   configure-and-quit=no
<debug> [1723123912.7389] CONFIG: [connectivity]
<debug> [1723123912.7389] CONFIG:   uri=http://ping.archlinux.org/nm-check.txt
<debug> [1723123912.7389] CONFIG: [keyfile]
<debug> [1723123912.7389] CONFIG:   unmanaged-devices=interface-name:lo
<debug> [1723123912.7389] CONFIG: [logging]
<debug> [1723123912.7389] CONFIG:   level=DEBUG
<debug> [1723123912.7389] CONFIG:   domains=all
<debug> [1723123912.7390] CONFIG:
<debug> [1723123912.7390] CONFIG: # no-auto-default file "/var/lib/NetworkManager/no-auto-default.state"
<debug> [1723123912.7390] config: state: successfully read state file "/var/lib/NetworkManager/NetworkManager.state"
<debug> [1723123912.7390] WEXT support is enabled
<debug> [1723123912.7390] create NMDBusManager singleton (727f8532206fe69b)
<debug> [1723123912.7398] bus-manager: D-Bus connection created and ObjectManager object registered
<debug> [1723123912.7399] netns[0541170d7f57eb50]: new netns (net:8, mnt:9)
<debug> [1723123912.7400] platform-linux: create (ignore netns, initial netns, use udev, no tc-cache)
<debug> [1723123912.7400] platform-linux: genl: generic netlink socket for sync operations created: port=14536, fd=11
<debug> [1723123912.7400] platform-linux: genl: generic netlink socket created: port=3505187123, fd=12
<debug> [1723123912.7400] platform-linux: rtnl: rtnetlink socket created: port=14536, fd=13
<debug> [1723123912.7401] platform-linux: populate platform cache
<debug> [1723123912.7402] platform: (lo) signal: link   added: 1: lo <UP,LOWER_UP;loopback,up,running,lowerup> mtu 65536 arp 772 loopback? not-init addrgenmode eui64 addr 00:00:00:00:00:00 brd 00:00:00:00:00:00 driver unknown tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:15210,1160208 tx:15210,1160208
<debug> [1723123912.7403] platform: kernel-support for IFLA_PERM_ADDRESS (IFLA_PERM_ADDRESS netlink attribute) detected: supported
<debug> [1723123912.7404] platform-linux: genl:ctrl: new family-id for nl80211: 0x26
<debug> [1723123912.7405] wifi-nl80211 (wlp3s0): using nl80211 for Wi-Fi device control
<debug> [1723123912.7406] platform: (wlp3s0) signal: link   added: 4: wlp3s0 <UP;broadcast,multicast,up> mtu 1500 arp 1 wifi? not-init addrgenmode eui64 addr A4:5E:60:C4:03:CD permaddr A4:5E:60:C4:03:CD brd FF:FF:FF:FF:FF:FF driver brcmfmac tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:0,0 tx:0,0
<debug> [1723123912.7406] platform: (lo) signal: address 4   added: 127.0.0.1/8 brd 0.0.0.0 lft forever pref forever lifetime 1-0[4294967295,4294967295] dev 1 flags permanent src kernel
<debug> [1723123912.7406] platform: (lo) signal: address 6   added: ::1/128 lft forever pref forever lifetime 1-0[4294967295,4294967295] dev 1 flags permanent,noprefixroute src kernel
<debug> [1723123912.7407] platform: (lo) signal: route   4   added: type local table 255 127.0.0.0/8 dev 1 metric 0 mss 0 rt-src rt-kernel scope host pref-src 127.0.0.1
<debug> [1723123912.7407] platform: (lo) signal: route   4   added: type local table 255 127.0.0.1/32 dev 1 metric 0 mss 0 rt-src rt-kernel scope host pref-src 127.0.0.1
<debug> [1723123912.7407] platform: (lo) signal: route   6   added: type local table 255 ::1/128 dev 1 metric 0 mss 0 rt-src rt-kernel
<debug> [1723123912.7407] platform: kernel-support for FRA_PROTOCOL (FRA_PROTOCOL attribute for policy routing rules) detected: supported
<debug> [1723123912.7407] platform: kernel-support for FRA_UID_RANGE (FRA_UID_RANGE attribute for policy routing rules) not detected: assume supported
<debug> [1723123912.7407] platform: kernel-support for FRA_L3MDEV (FRA_L3MDEV attribute for policy routing rules) not detected: assume supported
<debug> [1723123912.7407] platform: kernel-support for FRA_IP_PROTO (FRA_IP_PROTO, FRA_SPORT_RANGE, FRA_DPORT_RANGE attributes for policy routing rules) not detected: assume supported
<debug> [1723123912.7407] platform: signal: rt-rule   added: [4] 0: from all lookup 255 protocol 2
<debug> [1723123912.7407] platform: signal: rt-rule   added: [4] 32766: from all lookup 254 protocol 2
<debug> [1723123912.7408] platform: signal: rt-rule   added: [4] 32767: from all lookup 253 protocol 2
<debug> [1723123912.7408] platform-linux: genl:ctrl: new family-id for ethtool: 0x16
<debug> [1723123912.7408] platform-linux: genl:ctrl: new family-id for devlink: 0x17
<debug> [1723123912.7408] platform-linux: genl:ctrl: new family-id for mptcp_pm: 0x20
<debug> [1723123912.7408] platform: signal: rt-rule   added: [6] 0: from all lookup 255 protocol 2
<debug> [1723123912.7408] platform: signal: rt-rule   added: [6] 32766: from all lookup 254 protocol 2
<debug> [1723123912.7415] platform: (wlp3s0) signal: link changed: 4: wlp3s0 <UP;broadcast,multicast,up> mtu 1500 arp 1 wifi? init addrgenmode eui64 addr A4:5E:60:C4:03:CD permaddr A4:5E:60:C4:03:CD brd FF:FF:FF:FF:FF:FF driver brcmfmac tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:0,0 tx:0,0
<debug> [1723123912.7418] platform: (lo) signal: link changed: 1: lo <UP,LOWER_UP;loopback,up,running,lowerup> mtu 65536 arp 772 loopback? init addrgenmode eui64 addr 00:00:00:00:00:00 brd 00:00:00:00:00:00 driver unknown tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:15210,1160208 tx:15210,1160208
<debug> [1723123912.7418] setup NMPlatform singleton (f1851caa2ae72911)
<debug> [1723123912.7418] global-tracker: track [a7def9812e0db586,0] routing-rule "[4] 0: from all lookup 255 protocol 2"
<debug> [1723123912.7419] global-tracker: track [a7def9812e0db586,0] routing-rule "[6] 0: from all lookup 255 protocol 2"
<debug> [1723123912.7419] global-tracker: track [a7def9812e0db586,0] routing-rule "[4] 32766: from all lookup 254 protocol 2"
<debug> [1723123912.7419] global-tracker: track [a7def9812e0db586,0] routing-rule "[4] 32767: from all lookup 253 protocol 2"
<debug> [1723123912.7419] global-tracker: track [a7def9812e0db586,0] routing-rule "[6] 32766: from all lookup 254 protocol 2"
<debug> [1723123912.7419] global-tracker: track [d8a6d4ddf87f8a9d,0] routing-rule "[4] 0: from all lookup 255 protocol 2"
<debug> [1723123912.7419] global-tracker: track [d8a6d4ddf87f8a9d,0] routing-rule "[4] 32766: from all lookup 254 protocol 2"
<debug> [1723123912.7419] global-tracker: track [d8a6d4ddf87f8a9d,0] routing-rule "[4] 32767: from all lookup 253 protocol 2"
<debug> [1723123912.7419] global-tracker: track [d8a6d4ddf87f8a9d,0] routing-rule "[6] 0: from all lookup 255 protocol 2"
<debug> [1723123912.7419] global-tracker: track [d8a6d4ddf87f8a9d,0] routing-rule "[6] 32766: from all lookup 254 protocol 2"
<debug> [1723123912.7419] create NMNetns singleton (cf79a3ea49268311)
<debug> [1723123912.7421] auth[0x627d914ffda0]: create auth-manager: polkit enabled
<debug> [1723123912.7421] auth[0x627d914ffda0]: set instance
<debug> [1723123912.7421] setup NMAuthManager singleton (6f542399293336a8)
<info>  [1723123912.7424] manager[0x627d91504640]: monitoring kernel firmware directory '/lib/firmware'.
<debug> [1723123912.7424] session-monitor: using systemd-logind session tracking
<debug> [1723123912.7424] create NMSessionMonitor singleton (5f40facadaf672df)
<debug> [1723123912.7424] create NMAgentManager singleton (71ad3ffd4f0231df)
<info>  [1723123912.8034] hostname: hostname: using hostnamed
<info>  [1723123912.8034] hostname: static hostname changed from (none) to "david-macbookpro121"
<debug> [1723123912.8034] create NMHostnameManager singleton (456c6d8329e5942d)
<debug> [1723123912.8037] create NMFirewalldManager singleton (1b54a1691823f5db)
<info>  [1723123912.8038] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
<debug> [1723123912.8039] dns-plugin[f12d11cba9bbe882]: [systemd-resolved] update-pending changed (pending)
<debug> [1723123912.8039] dns-mgr: update-pending changed: pending
<debug> [1723123912.8039] create NMDnsManager singleton (dcf7a268845f29f1)
<debug> [1723123912.8039] policy: hostname-mode: full
<info>  [1723123912.8051] rfkill3: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.2/0000:03:00.0/ieee80211/phy2/rfkill3) (driver brcmfmac)
<debug> [1723123912.8052] Wi-Fi rfkill switch rfkill3 state now 1/unblocked
<debug> [1723123912.8052] Wi-Fi rfkill state now 'unblocked'
<info>  [1723123912.8053] manager[0x627d91504640]: rfkill: Wi-Fi hardware radio set enabled
<info>  [1723123912.8053] manager[0x627d91504640]: rfkill: WWAN hardware radio set enabled
<debug> [1723123912.8053] setup NMManager singleton (58ad11623af6f89e)
<debug> [1723123912.8063] create NMConnectivity singleton (d86522f4effbeb2f)
<debug> [1723123912.8064] Loaded device plugin: NM6LowpanDeviceFactory (internal)
<debug> [1723123912.8065] Loaded device plugin: NMBondDeviceFactory (internal)
<debug> [1723123912.8065] Loaded device plugin: NMBridgeDeviceFactory (internal)
<debug> [1723123912.8065] Loaded device plugin: NMDummyDeviceFactory (internal)
<debug> [1723123912.8065] Loaded device plugin: NMEthernetDeviceFactory (internal)
<debug> [1723123912.8065] Loaded device plugin: NMGenericDeviceFactory (internal)
<debug> [1723123912.8065] Loaded device plugin: NMHsrDeviceFactory (internal)
<debug> [1723123912.8066] Loaded device plugin: NMInfinibandDeviceFactory (internal)
<debug> [1723123912.8066] Loaded device plugin: NMIPTunnelDeviceFactory (internal)
<debug> [1723123912.8066] Loaded device plugin: NMLoopbackDeviceFactory (internal)
<debug> [1723123912.8066] Loaded device plugin: NMMacsecDeviceFactory (internal)
<debug> [1723123912.8066] Loaded device plugin: NMMacvlanDeviceFactory (internal)
<debug> [1723123912.8066] Loaded device plugin: NMPppDeviceFactory (internal)
<debug> [1723123912.8066] Loaded device plugin: NMTunDeviceFactory (internal)
<debug> [1723123912.8067] Loaded device plugin: NMVethDeviceFactory (internal)
<debug> [1723123912.8067] Loaded device plugin: NMVlanDeviceFactory (internal)
<debug> [1723123912.8067] Loaded device plugin: NMVrfDeviceFactory (internal)
<debug> [1723123912.8067] Loaded device plugin: NMVxlanDeviceFactory (internal)
<debug> [1723123912.8067] Loaded device plugin: NMWireGuardDeviceFactory (internal)
<debug> [1723123912.8067] Loaded device plugin: NMWpanDeviceFactory (internal)
<info>  [1723123912.8071] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-adsl.so)
<info>  [1723123912.8083] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-bluetooth.so)
<info>  [1723123912.8087] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-ovs.so)
<info>  [1723123912.8161] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-team.so)
<info>  [1723123912.8165] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-wifi.so)
<info>  [1723123912.8167] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-wwan.so)
<debug> [1723123912.8169] create NMModemManager singleton (ebe4fb55b557c096)
<debug> [1723123912.8170] create NMOvsdb singleton (b3b42b943146a021)
<info>  [1723123912.8170] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
<info>  [1723123912.8170] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
<info>  [1723123912.8171] manager: Networking is disabled by state file
<debug> [1723123912.8171] dispatcher: (1) dispatching action 'hostname'
<info>  [1723123912.8173] settings: Loaded settings plugin: keyfile (internal)
<debug> [1723123912.8206] ++ connection.id             = 'WIFI602'
<debug> [1723123912.8206] ++ connection.interface-name = 'wlp3s0'
<debug> [1723123912.8206] ++ connection.permissions    = []
<debug> [1723123912.8206] ++ connection.timestamp      = 1723057825
<debug> [1723123912.8206] ++ connection.type           = '802-11-wireless'
<debug> [1723123912.8206] ++ connection.uuid           = '77c55583-f77b-4a34-bbe0-1f9d5eb49bf5'
<debug> [1723123912.8206] ++ 802-11-wireless           [ 0x627d915823a0 ]
<debug> [1723123912.8207] ++ 802-11-wireless.mac-address-blacklist = []
<debug> [1723123912.8207] ++ 802-11-wireless.mac-address-denylist = []
<debug> [1723123912.8207] ++ 802-11-wireless.mode      = 'infrastructure'
<debug> [1723123912.8207] ++ 802-11-wireless.ssid      = ((GBytes*) 0x627d91569c10)
<debug> [1723123912.8207] ++ 802-11-wireless-security  [ 0x627d915824e0 ]
<debug> [1723123912.8207] ++ 802-11-wireless-security.key-mgmt = 'wpa-psk'
<debug> [1723123912.8207] ++ 802-11-wireless-security.psk = ****
<debug> [1723123912.8207] ++ ipv4                      [ 0x627d91582680 ]
<debug> [1723123912.8207] ++ ipv4.addresses            = ((GPtrArray*) 0x627d914db010)
<debug> [1723123912.8207] ++ ipv4.dns                  = []
<debug> [1723123912.8208] ++ ipv4.method               = 'auto'
<debug> [1723123912.8208] ++ ipv4.routes               = ((GPtrArray*) 0x627d914db010)
<debug> [1723123912.8208] ++ ipv4.routing-rules        = <unknown>
<debug> [1723123912.8208] ++ ipv6                      [ 0x627d91582890 ]
<debug> [1723123912.8208] ++ ipv6.addr-gen-mode        = 1
<debug> [1723123912.8208] ++ ipv6.addresses            = ((GPtrArray*) 0x627d914db010)
<debug> [1723123912.8208] ++ ipv6.dns                  = []
<debug> [1723123912.8208] ++ ipv6.method               = 'auto'
<debug> [1723123912.8208] ++ ipv6.routes               = ((GPtrArray*) 0x627d914db010)
<debug> [1723123912.8208] ++ ipv6.routing-rules        = <unknown>
<debug> [1723123912.8213] device[90ff88f711337733] (lo): ifindex: set ifindex 1 (l3cfg: 7dddebeef72c29e5)
<debug> [1723123912.8217] device[90ff88f711337733] (lo): constructed (NMDeviceLoopback)
<debug> [1723123912.8217] device[90ff88f711337733] (lo): start setup of NMDeviceLoopback, kernel ifindex 1
<debug> [1723123912.8217] device[90ff88f711337733] (lo): hw-addr: hardware address now 00:00:00:00:00:00
<debug> [1723123912.8218] device[90ff88f711337733] (lo): hw-addr: update initial MAC address 00:00:00:00:00:00
<debug> [1723123912.8218] device[90ff88f711337733] (lo): hw-addr: unable to read permanent MAC address (use current: 00:00:00:00:00:00)
<debug> [1723123912.8218] platform-linux: error reading net:/sys/class/net/lo/phys_port_id: error reading 4096 bytes from file descriptor: Operation not supported
<debug> [1723123912.8219] platform-linux: sysctl: reading 'net:/sys/class/net/lo/dev_id': '0x0'
<debug> [1723123912.8220] platform-linux: error reading net:/sys/class/net/lo/device/sriov_numvfs: Failed to open file "device/sriov_numvfs" with openat: No such file or directory
<debug> [1723123912.8220] dhcp: init: enabled DHCP client 'dhcpcanon' (not available)
<debug> [1723123912.8221] dhcp: init: enabled DHCP client 'dhclient' (not available)
<debug> [1723123912.8221] dhcp: init: enabled DHCP client 'dhcpcd' (not available)
<debug> [1723123912.8221] dhcp: init: enabled DHCP client 'internal'
<debug> [1723123912.8221] dhcp: init: enabled DHCP client 'systemd' (undocumented internal plugin)
<debug> [1723123912.8221] dhcp: init: enabled DHCP client 'nettools' (undocumented internal plugin)
<info>  [1723123912.8221] dhcp: init: Using DHCP client 'internal'
<debug> [1723123912.8221] create NMDhcpManager singleton (df9c5850909d7e22)
<debug> [1723123912.8221] device[90ff88f711337733] (lo): unmanaged: flags set to [platform-init,!external-down=0x4/0x104/unmanaged/unrealized], set-managed [external-down=0x100])
<debug> [1723123912.8222] device[90ff88f711337733] (lo): unmanaged: flags set to [platform-init,user-settings,!external-down=0x14/0x114/unmanaged/unrealized], set-unmanaged [user-settings=0x10])
<debug> [1723123912.8222] device[90ff88f711337733] (lo): unmanaged: flags set to [user-settings,!platform-init,!external-down=0x10/0x114/unmanaged/unrealized], set-managed [platform-init=0x4])
<debug> [1723123912.8222] device[90ff88f711337733] (lo): unmanaged: flags set to [sleeping,user-settings,!platform-init,!external-down=0x11/0x115/unmanaged/unrealized], set-unmanaged [sleeping=0x1])
<info>  [1723123912.8225] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
<debug> [1723123912.8241] (wlp3s0) config: backend is "wpa_supplicant" (iwd support enabled)
<debug> [1723123912.8242] device[bae48e9914987d57] (wlp3s0): ifindex: set ifindex 4 (l3cfg: e57f5fcb758f3d61)
<debug> [1723123912.8244] device[bae48e9914987d57] (wlp3s0): constructed (NMDeviceWifi)
<info>  [1723123912.8244] device (wlp3s0): driver supports Access Point (AP) mode
<debug> [1723123912.8245] create NMSupplicantManager singleton (b1a25ed729b43dcf)
<debug> [1723123912.8246] device[bae48e9914987d57] (wlp3s0): start setup of NMDeviceWifi, kernel ifindex 4
<debug> [1723123912.8246] device[bae48e9914987d57] (wlp3s0): hw-addr: hardware address now A4:5E:60:C4:03:CD
<debug> [1723123912.8246] device[bae48e9914987d57] (wlp3s0): hw-addr: update initial MAC address A4:5E:60:C4:03:CD
<debug> [1723123912.8246] device[bae48e9914987d57] (wlp3s0): hw-addr: read permanent MAC address 'A4:5E:60:C4:03:CD'
<debug> [1723123912.8247] platform-linux: error reading net:/sys/class/net/wlp3s0/phys_port_id: error reading 4096 bytes from file descriptor: Operation not supported
<debug> [1723123912.8248] platform-linux: sysctl: reading 'net:/sys/class/net/wlp3s0/dev_id': '0x0'
<debug> [1723123912.8249] platform-linux: error reading net:/sys/class/net/wlp3s0/device/sriov_numvfs: Failed to open file "device/sriov_numvfs" with openat: No such file or directory
<debug> [1723123912.8249] device[bae48e9914987d57] (wlp3s0): unmanaged: flags set to [platform-init,!user-settings=0x4/0x14/unmanaged/unrealized], set-managed [user-settings=0x10])
<debug> [1723123912.8249] device[bae48e9914987d57] (wlp3s0): unmanaged: flags set to [!platform-init,!user-settings=0x0/0x14/managed/unrealized], set-managed [platform-init=0x4])
<debug> [1723123912.8249] manager: rfkill: Wi-Fi available 1 hw-enabled 1 sw-enabled 1
<debug> [1723123912.8250] device[bae48e9914987d57] (wlp3s0): device now enabled
<debug> [1723123912.8250] device[bae48e9914987d57] (wlp3s0): (enable): device blocked by UNMANAGED state
<debug> [1723123912.8250] device[bae48e9914987d57] (wlp3s0): unmanaged: flags set to [sleeping,!platform-init,!user-settings=0x1/0x15/unmanaged/unrealized], set-unmanaged [sleeping=0x1])
<info>  [1723123912.8253] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/2)
<debug> [1723123912.8259] create NMVpnManager singleton (f6fffe7b61c74cdf)
<debug> [1723123912.8259] manager: creating virtual devices...
<debug> [1723123912.8259] setting up local loopback
<debug> [1723123912.8259] platform-linux: link: change 1: flags: set 0x1/0x1 ([up] / [up])
<debug> [1723123912.8260] platform-linux: do-request-link: 1
<debug> [1723123912.8261] platform-linux: do-change-link[1]: success
systemd[1]: Started Network Manager.
