purchased new laptop Levono Ryzen 5
Lenovo IdeaPad 3 2022 15ABA7
WiFi adapter is not showing how can I fix it..
Inxit
root=UUID=ce5e9dfe-8dd0-4509-9cb9-1eeffe9400ab rw [email protected]
resume=UUID=d7055f71-419e-4ce2-a037-b2adf522b7e3 loglevel=3
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Laptop System: LENOVO product: 82RN v: IdeaPad 3 15ABA7
serial: <filter> Chassis: type: 10 v: IdeaPad 3 15ABA7 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463WIN serial: <filter>
UEFI: LENOVO v: JTCN39WW date: 09/15/2022
ID-1: BAT0 charge: 34.5 Wh (88.5%) condition: 39.0/38.0 Wh (102.5%)
volts: 8.8 min: 7.7 model: BYD L20B2PF0 type: Li-poly serial: <filter>
status: charging cycles: 2
Info: model: AMD Ryzen 5 5625U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1716 high: 2300 min/max: 1600/4387 boost: enabled
base/boost: 2300/4350 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 2300 2: 1600 3: 1600 4: 1600
5: 1600 6: 1600 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600 12: 2300
bogomips: 55095
Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 36.0 C
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 174f:2465 class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x151e built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: RENOIR (renoir LLVM 14.0.6 DRM 3.48 6.0.2-zen1-1-zen)
v: 4.6 Mesa 22.2.1 direct render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
Device-1: Realtek vendor: Lenovo driver: N/A pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b852 class-ID: 0280
bus-ID: 3-4:4 chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
Local Storage: total: 506.24 GiB used: 6.25 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512GZL
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: C01C
temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 9 hrs cycles: 18 read-units: 251,912 [128
GB] written-units: 348,432 [178 GB]
ID-2: /dev/sda maj-min: 8:0 type: USB model: General size: 29.3 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 5.00 scheme: GPT
ID-1: / raw-size: 461.79 GiB size: 461.79 GiB (100.00%) used: 6.25 GiB
(1.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
(0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 461.79 GiB size: 461.79 GiB (100.00%) used: 6.25
GiB (1.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 461.79 GiB size: 461.79 GiB (100.00%) used: 6.25
maj-min: 259:2
ID-5: /var/tmp raw-size: 461.79 GiB size: 461.79 GiB (100.00%) used: 6.25
maj-min: 259:2
ID-1: swap-1 type: zram size: 13.5 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 14.85 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 40.2 C mobo: N/A gpu: amdgpu temp: 37.0 C
Processes: 290 Uptime: 3m wakeups: 2 Memory: 13.5 GiB used: 1.53 GiB
(11.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1137 libs: 301
tools: octopi,paru Shell: fish (sudo) v: 3.5.1 default: Bash v: 5.1.16
needed help
