hi, i am new to linux and garuda
i have installed garuda xfce
my issue is that the wifi network is showing wifi disabled by hardware switch and ethernet network (realtex rtl810xe) is showing disconnected
garuda-inxi is as follows
Kernel: 5.15.81-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b09296ae-d31e-4e23-a6e0-b09537c012c5 rw rootflags=subvol=@
resume=UUID=92fc0b6c-65e1-4032-8332-c6be73cf20a6 loglevel=3
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
v: 0884110000385910000610100 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 183F v: 56.2B serial: <superuser required>
UEFI: Insyde v: F.10 date: 08/10/2012
ID-1: BAT0 charge: 29.7 Wh (92.5%) condition: 32.1/32.1 Wh (100.0%)
volts: 12.5 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: charging
Info: model: Intel Core i3-3110M bits: 64 type: MT MCP arch: Ivy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1542 high: 2060 min/max: 1200/2400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1365 2: 1236 3: 2060
4: 1507 bogomips: 19157
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
prctl and seccomp
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Realtek HP Truevision HD type: USB driver: uvcvideo
bus-ID: 2-1.5:3 chip-ID: 0bda:58de class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: LG Display 0x02f1 built: 2011 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
missing.
Sound API: ALSA v: k5.15.81-1-lts running: yes
Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard
driver: rt2800pci v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 1814:3290 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF-ID-1: enp0s26u1u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Ralink RT3290 Bluetooth vendor: Hewlett-Packard driver: N/A pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.1 chip-ID: 1814:3298
class-ID: 0d11
Device-2: OPPO RMX3241 type: USB driver: rndis_host v: kernel
bus-ID: 1-1.2:4 chip-ID: 22d9:276a class-ID: 0a00 serial: <filter>
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 704.24 GiB used: 11.51 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 model: 256GB EVM SSD size: 238.47 GiB
serial: <filter> rev: 4A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HTS545050A7E380
type: HDD rpm: 5400 serial: <filter> rev: A7A0 scheme: GPT
ID-1: / raw-size: 229.99 GiB size: 229.99 GiB (100.00%)
used: 11.51 GiB (5.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 229.99 GiB size: 229.99 GiB (100.00%)
ID-4: /var/log raw-size: 229.99 GiB size: 229.99 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.99 GiB size: 229.99 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.72 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 8.18 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 63.0 C mobo: N/A
Processes: 221 Uptime: 7m wakeups: 1 Memory: 3.72 GiB used: 1.72 GiB (46.3%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1182 libs: 334 tools: paru
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-12-07
Last full system update: 2022-12-08
@ranjeet71
Post terminal input and output as text formatted between three ~ in first and last line.
my terminal text
my terminal text
