yash
24 March 2022 14:15
1
I recently noted that wifi hotspot app is not working. I want to share Garuda’s network with mobile devices or others via hotspot. Can I do this in some other ways? Please help me to make the app work or please give some other ways if are there!
garuda-inxi output :
Kernel: 5.16.16-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=48bcd8f8-8b3f-4880-b42a-006b8a79a3d7 rw rootflags=subvol=@
resume=UUID=7a1e7bea-7a5f-4dbe-b369-1f62294f03e1 loglevel=3
Desktop: GNOME 41.5 tk: GTK 3.24.33 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec2xxx v: N/A
serial: Chassis: type: 10 serial:
Mobo: HP model: 88DE v: 96.31 serial: UEFI: AMI v: F.15
date: 08/18/2021
ID-1: BAT0 charge: 49.9 Wh (99.8%) condition: 50.0/50.0 Wh (100.0%)
volts: 12.9 min: 11.6 model: HP Primary type: Li-ion serial:
status: N/A
Info: model: AMD Ryzen 5 5600H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1200 min/max: 1200/4280 boost: enabled
base/boost: 3300/4250 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1200 2: 1200 3: 1200 4: 1200
5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200
bogomips: 79080
STIBP: always-on, RSB filling
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:25a2
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1638
Device-3: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 3-3:2 chip-ID: 30c9:0035 class-ID: fe01
serial:
Display: server: X.Org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: modesetting,nvidia gpu: amdgpu display-ID: :1 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: AU Optronics built: 2020 res: 1920x1080 dpi: 142
gamma: 1.2 size: 344x193mm (13.5x7.6") diag: 394mm (15.5") ratio: 16:9
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.16-arch1-1 LLVM 13.0.1)
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.16.16-arch1-1 running: yes
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
IF: eno1 state: down mac:
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_pci v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8852
IF: wlo1 state: up mac:
bus-ID: 1-4:2 chip-ID: 0bda:2852 class-ID: e001 serial:
address:
Local Storage: total: 476.94 GiB used: 154.87 GiB (32.5%)
model: MTFDHBA512TDV-1AZ1AABHA size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: HPS0032 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 151.4 GiB size: 151.4 GiB (100.00%)
used: 53.39 GiB (35.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p8
maj-min: 259:8
ID-2: /boot/efi raw-size: 615 MiB size: 613.8 MiB (99.80%)
used: 580 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-3: /home raw-size: 151.4 GiB size: 151.4 GiB (100.00%)
maj-min: 259:8
ID-4: /var/log raw-size: 151.4 GiB size: 151.4 GiB (100.00%)
maj-min: 259:8
ID-5: /var/tmp raw-size: 151.4 GiB size: 151.4 GiB (100.00%)
maj-min: 259:8
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: swap-2 type: zram size: 7.18 GiB used: 115.8 MiB (1.6%)
System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 333 Uptime: 3h 51m wakeups: 1 Memory: 7.18 GiB
used: 2.67 GiB (37.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1236 lib: 323 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-13
Last full system update: 2022-03-23
Windows dual boot: Yes
Naman
24 March 2022 14:29
2
yash:
A big reason to worry.
Also, how do you recieve internet on your laptop? Wifi / Ethernet / other method?
yash
24 March 2022 14:47
4
By wifi method
Naman:
No other option. I have to do my college work with some softwares not available for linux and also not working with winehq.
That’s why I recommend people using linux (of course Garuda only because I found it best among most popular distros I tried). This Windows monopoly needs to be stopped. Linux is all way better than Windows but software and hardware providers aren’t taking it seriously, especially the NVIDIA
yash
24 March 2022 15:04
5
yash:
By wifi method
Having RTL8852AE and its driver rtw89 installed by default after kernel upgrade of 5.16 via MHWD
Naman
24 March 2022 15:14
6
I don't think you can share wifi connection using hotspot.
You either have to switch to Ethernet as incoming connection to your laptop or you have to use another device that can be used to share network. Refer the following for 2nd choice
https://wiki.archlinux.org/title/Internet_sharing
yash
24 March 2022 15:22
7
I only have wifi and not ethernet. Can I install or setup something so hotspot works like that in Windows?
Naman
24 March 2022 16:05
8
No idea tbh. Maybe @tbg might know about something.
yash
25 March 2022 03:15
10
Yes, maybe he would know some way. How can I invite tbg to this post or message him? I am unable to message him. Can you please invite him to the post?
tbg
25 March 2022 03:40
11
He already did.
I just never use a hotspot, so I felt I didn't have much to contribute on this subject.
Are you sure your wifi adapter even supports AP mode ?
yash
25 March 2022 14:39
12
Maybe not. Here is my iw-list output
> Wiphy phy0
> wiphy index: 0
> max # scan SSIDs: 4
> max scan IEs length: 2186 bytes
> max # sched scan SSIDs: 0
> max # match sets: 0
> Retry short limit: 7
> Retry long limit: 4
> Coverage class: 0 (up to 0m)
> Supported Ciphers:
> * WEP40 (00-0f-ac:1)
> * WEP104 (00-0f-ac:5)
> * TKIP (00-0f-ac:2)
> * CCMP-128 (00-0f-ac:4)
> * CCMP-256 (00-0f-ac:10)
> * GCMP-128 (00-0f-ac:8)
> * GCMP-256 (00-0f-ac:9)
> * CMAC (00-0f-ac:6)
> * CMAC-256 (00-0f-ac:13)
> * GMAC-128 (00-0f-ac:11)
> * GMAC-256 (00-0f-ac:12)
> Available Antennas: TX 0x3 RX 0x3
> Configured Antennas: TX 0 RX 0
> Supported interface modes:
> * managed
> * monitor
> Band 1:
> Capabilities: 0x19ef
> RX LDPC
> HT20/HT40
> SM Power Save disabled
> RX HT20 SGI
> RX HT40 SGI
> TX STBC
> RX STBC 1-stream
> Max AMSDU length: 7935 bytes
> DSSS/CCK HT40
> Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
> Minimum RX AMPDU time spacing: No restriction (0x00)
> HT Max RX data rate: 300 Mbps
> HT TX/RX MCS rate indexes supported: 0-15, 32
> HE Iftypes: managed
> HE MAC Capabilities (0x0800100a8060):
> Trigger Frame MAC Padding Duration: 2
> All Ack
> BSR
> Maximum A-MPDU Length Exponent: 2
> OPS
> A-MSDU in A-MPDU
> HE PHY Capabilities: (0x06701e1f0d00270e91bd00):
> HE40/2.4GHz
> HE40/HE80/5GHz
> Device Class: 1
> LDPC Coding in Payload
> HE SU PPDU with 1x HE-LTF and 0.8us GI
> NDP with 4x HE-LTF and 3.2us GI
> STBC Tx <= 80MHz
> STBC Rx <= 80MHz
> Doppler Tx
> DCM Max Constellation: 3
> DCM Max NSS Tx: 1
> DCM Max Constellation Rx: 3
> SU Beamformee
> Beamformee STS <= 80Mhz: 3
> Codebook Size SU Feedback
> Codebook Size MU Feedback
> Triggered SU Beamforming Feedback
> Partial Bandwidth Extended Range
> Power Boost Factor ar
> HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
> Max NC: 1
> HE ER SU PPDU 4x HE-LTF 0.8us GI
> HE ER SU PPDU 1x HE-LTF 0.8us GI
> DCM Max BW: 2
> Longer Than 16HE SIG-B OFDM Symbols
> TX 1024-QAM
> RX 1024-QAM
> RX Full BW SU Using HE MU PPDU with Compression SIGB
> RX Full BW SU Using HE MU PPDU with Non-Compression SIGB
> HE RX MCS and NSS set <= 80 MHz
> 1 streams: MCS 0-11
> 2 streams: MCS 0-11
> 3 streams: not supported
> 4 streams: not supported
> 5 streams: not supported
> 6 streams: not supported
> 7 streams: not supported
> 8 streams: not supported
> HE TX MCS and NSS set <= 80 MHz
> 1 streams: MCS 0-11
> 2 streams: MCS 0-11
> HE Iftypes: AP
> HE MAC Capabilities (0x0001120a0060):
> +HTC HE Supported
> All Ack
> BSR
> OM Control
> OPS
> A-MSDU in A-MPDU
> HE PHY Capabilities: (0x06701e580d00270e91b900):
> HE40/2.4GHz
> HE40/HE80/5GHz
> Device Class: 1
> STBC Tx <= 80MHz
> STBC Rx <= 80MHz
> Doppler Tx
> Rx HE MU PPDU from Non-AP STA
> SU Beamformee
> Max NC: 1
> DCM Max BW: 2
> RX 1024-QAM
> 1 streams: MCS 0-11
> 2 streams: MCS 0-11
> 1 streams: MCS 0-11
> 2 streams: MCS 0-11
> Bitrates (non-HT):
> * 1.0 Mbps
> * 2.0 Mbps
> * 5.5 Mbps
> * 11.0 Mbps
> * 6.0 Mbps
> * 9.0 Mbps
> * 12.0 Mbps
> * 18.0 Mbps
> * 24.0 Mbps
> * 36.0 Mbps
> * 48.0 Mbps
> * 54.0 Mbps
> Frequencies:
> * 2412 MHz [1] (20.0 dBm)
> * 2417 MHz [2] (20.0 dBm)
> * 2422 MHz [3] (20.0 dBm)
> * 2427 MHz [4] (20.0 dBm)
> * 2432 MHz [5] (20.0 dBm)
> * 2437 MHz [6] (20.0 dBm)
> * 2442 MHz [7] (20.0 dBm)
> * 2447 MHz [8] (20.0 dBm)
> * 2452 MHz [9] (20.0 dBm)
> * 2457 MHz [10] (20.0 dBm)
> * 2462 MHz [11] (20.0 dBm)
> * 2467 MHz [12] (20.0 dBm)
> * 2472 MHz [13] (20.0 dBm)
> * 2484 MHz [14] (disabled)
> Band 2:
> RX LDPC
> HT20/HT40
> RX HT20 SGI
> RX HT40 SGI
> TX STBC
> RX STBC 1-stream
> DSSS/CCK HT40
> VHT Capabilities (0x03d071b2):
> Max MPDU length: 11454
> Supported Channel Width: neither 160 nor 80+80
> RX LDPC
> short GI (80 MHz)
> TX STBC
> SU Beamformee
> MU Beamformee
> +HTC-VHT
> VHT RX MCS set:
> 1 streams: MCS 0-9
> 2 streams: MCS 0-9
> VHT RX highest supported: 867 Mbps
> VHT TX MCS set:
> 1 streams: MCS 0-9
> 2 streams: MCS 0-9
> VHT TX highest supported: 867 Mbps
> HE Iftypes: managed
> All Ack
> BSR
> OPS
> A-MSDU in A-MPDU
> HE40/2.4GHz
> HE40/HE80/5GHz
> Device Class: 1
> STBC Tx <= 80MHz
> STBC Rx <= 80MHz
> Doppler Tx
> DCM Max NSS Tx: 1
> SU Beamformee
> Max NC: 1
> DCM Max BW: 2
> TX 1024-QAM
> RX 1024-QAM
> 1 streams: MCS 0-11
> 2 streams: MCS 0-11
> 1 streams: MCS 0-11
> 2 streams: MCS 0-11
> HE Iftypes: AP
> +HTC HE Supported
> All Ack
> BSR
> OM Control
> OPS
> A-MSDU in A-MPDU
> HE40/2.4GHz
> HE40/HE80/5GHz
> Device Class: 1
> STBC Tx <= 80MHz
> STBC Rx <= 80MHz
> Doppler Tx
> SU Beamformee
> Max NC: 1
> DCM Max BW: 2
> RX 1024-QAM
> 1 streams: MCS 0-11
> 2 streams: MCS 0-11
> 1 streams: MCS 0-11
> 2 streams: MCS 0-11
> Bitrates (non-HT):
> * 6.0 Mbps
> * 9.0 Mbps
> * 12.0 Mbps
> * 18.0 Mbps
> * 24.0 Mbps
> * 36.0 Mbps
> * 48.0 Mbps
> * 54.0 Mbps
> Frequencies:
> * 5180 MHz [36] (30.0 dBm)
> * 5200 MHz [40] (30.0 dBm)
> * 5220 MHz [44] (30.0 dBm)
> * 5240 MHz [48] (30.0 dBm)
> * 5260 MHz [52] (24.0 dBm)
> * 5280 MHz [56] (24.0 dBm)
> * 5300 MHz [60] (24.0 dBm)
> * 5320 MHz [64] (24.0 dBm)
> * 5500 MHz [100] (24.0 dBm)
> * 5520 MHz [104] (24.0 dBm)
> * 5540 MHz [108] (24.0 dBm)
> * 5560 MHz [112] (24.0 dBm)
> * 5580 MHz [116] (24.0 dBm)
> * 5600 MHz [120] (24.0 dBm)
> * 5620 MHz [124] (24.0 dBm)
> * 5640 MHz [128] (24.0 dBm)
> * 5660 MHz [132] (24.0 dBm)
> * 5680 MHz [136] (24.0 dBm)
> * 5700 MHz [140] (24.0 dBm)
> * 5720 MHz [144] (24.0 dBm)
> * 5745 MHz [149] (30.0 dBm)
> * 5765 MHz [153] (30.0 dBm)
> * 5785 MHz [157] (30.0 dBm)
> * 5805 MHz [161] (30.0 dBm)
> * 5825 MHz [165] (30.0 dBm)
> Supported commands:
> * new_interface
> * set_interface
> * new_key
> * start_ap
> * new_station
> * new_mpath
> * set_mesh_config
> * set_bss
> * authenticate
> * associate
> * deauthenticate
> * disassociate
> * join_ibss
> * join_mesh
> * remain_on_channel
> * set_tx_bitrate_mask
> * frame
> * frame_wait_cancel
> * set_wiphy_netns
> * set_channel
> * probe_client
> * set_noack_map
> * register_beacons
> * start_p2p_device
> * set_mcast_rate
> * connect
> * disconnect
> * set_qos_map
> * set_multicast_to_unicast
> * set_sar_specs
> software interface modes (can always be added):
> * monitor
> interface combinations are not supported
> HT Capability overrides:
> * MCS: ff ff ff ff ff ff ff ff ff ff
> * maximum A-MSDU length
> * supported channel width
> * short GI for 40 MHz
> * max A-MPDU length exponent
> * min MPDU start spacing
> Device supports TX status socket option.
> Device supports HT-IBSS.
> Device supports SAE with AUTHENTICATE command
> Device supports low priority scan.
> Device supports scan flush.
> Device supports AP scan.
> Device supports per-vif TX power setting
> Driver supports full state transitions for AP/GO clients
> Driver supports a userspace MPM
> Device supports configuring vdev MAC-addr on create.
> Device supports randomizing MAC-addr in scans.
> max # scan plans: 1
> max scan plan interval: -1
> max scan plan iterations: 0
> Supported TX frame types:
> * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
> * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
> * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
> * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
> * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
> * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
> * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
> * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
> Supported RX frame types:
> * IBSS: 0x40 0xb0 0xc0 0xd0
> * managed: 0x40 0xb0 0xd0
> * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
> * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
> * mesh point: 0xb0 0xc0 0xd0
> * P2P-client: 0x40 0xd0
> * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
> * P2P-device: 0x40 0xd0
> Supported extended features:
> * [ RRM ]: RRM
> * [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
> * [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
> * [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
> * [ SCAN_RANDOM_SN ]: use random sequence numbers in scans
> * [ SCAN_MIN_PREQ_CONTENT ]: use probe request with only rate IEs in scans
> * [ CAN_REPLACE_PTK0 ]: can safely replace PTK 0 when rekeying
> * [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
> * [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
> * [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
Ankur
26 March 2022 04:08
14
According to me if AP is not supported in your pc then you will not be able to use PC for hotspot with Wi-Fi at the same time
And many PC don't support AP so you need to check it....
yash
29 March 2022 13:55
15
Is it so also in case of Windows? Because in Windows both hostspot and wifi are working at same time.
Ankur
29 March 2022 14:41
16
i can't tell about that as i don't use Windows anymore
I left it some years ago
