Hello everyone,
I seem to have an issue with my wifi connection, either it be on 2.4GHz or 5GHz, at random times it starts disconnecting/connecting and from that point on it never stays connected. Sometimes when i first open my desktop, the wifi i was connected (lets say 2.4) fails to connect and if i disconnect it and connect to the 5 it connects successfully (until it starts doing the above behavior again).
I have a TP-LINK Archer TX20E v1 and from the lsmod i can see that the driver that is being used is rtw89_pci 118784 1 rtw89_8852be
I have tried to remove the wired option from the network settings (saw it as a solution somewhere), but that didnt help.
Im not sure what is should be doing here, could you please help me out?
Thank you very much for your assistance
Kernel: 6.17.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=c993e352-2dca-4c19-8934-b6716b460a87 rw rootflags=subvol=@
quiet resume=UUID=9bae97b8-bded-4490-94cc-a8ef9d3f13f7 loglevel=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: Rev X.0x
UEFI: American Megatrends v: 3611 date: 09/30/2024
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4431 min/max: 582/5086 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4431 2: 4431 3: 4431
4: 4431 5: 4431 6: 4431 7: 4431 8: 4431 9: 4431 10: 4431 11: 4431 12: 4431
13: 4431 14: 4431 15: 4431 16: 4431 17: 4431 18: 4431 19: 4431 20: 4431
21: 4431 22: 4431 23: 4431 24: 4431 25: 4431 26: 4431 27: 4431 28: 4431
29: 4431 30: 4431 31: 4431 32: 4431 bogomips: 217195
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
7800 XT] vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-3
code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-2,HDMI-A-1
empty: DP-1,DP-3,Writeback-1 bus-ID: 0c:00.0 chip-ID: 1002:747e
compositor: kwin_wayland driver: gpu: amdgpu d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-2 pos: right model: Samsung LS32CG51x serial: <filter>
built: 2022 res: mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 93 gamma: 1.2
max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 pos: primary,left model: LG (GoldStar) ULTRAGEAR
serial: <filter> built: 2022 res: mode: 2560x1440 hz: 144 scale: 100% (1)
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 21.1.5 DRM 3.64 6.17.8-zen1-1-zen) device-ID: 1002:747e
memory: 15.62 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.328 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 25.2.7-arch1.1
device-ID: 1002:747e surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.5 256 bits) driver: mesa llvmpipe v: 25.2.7-arch1.1 (LLVM
21.1.5) device-ID: 10005:0000 surfaces: N/A
bus-ID: 0c:00.1 chip-ID: 1002:ab30 class-ID: 0403
lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.17.8-zen1-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: AzureWave
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 06:00.0 chip-ID: 10ec:b852 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 09:00.0
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7.2:4
chip-ID: 13d3:3570 class-ID: e001 serial: <filter>
Local Storage: total: 2.05 TiB used: 118.6 GiB (5.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 33.9 C
model: WD10EZEX-00RKKA0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
ID-1: / raw-size: 914.19 GiB size: 914.19 GiB (100.00%)
used: 118.6 GiB (13.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 914.19 GiB size: 914.19 GiB (100.00%)
ID-4: /var/log raw-size: 914.19 GiB size: 914.19 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.19 GiB size: 914.19 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.48 GiB used: 460 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.03 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 75.0 C mobo: 31.0 C gpu: amdgpu temp: 34.0 C
mem: 29.0 C
Memory: total: 16 GiB available: 15.48 GiB used: 5.99 GiB (38.7%)
Processes: 646 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1458 libs: 377 tools: octopi,paru Compilers:
clang: 21.1.5 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.2.1
running-in: kitty inxi: 3.3.39
Garuda (2.11.1-1):
System install date: 2025-11-10
Garuda release: 251103
Last full system update: 2025-11-19
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard
25/26 checks run in 1.10 seconds ⌛
Powered by garuda-health 🦅
