jake
11 January 2023 08:09
1
Hello Garuda users.
I am having an issue with wifi to work for my laptop. My PC is lenovo ipeapad 5.
CPU: Amd ryzen 7 5825U.
GPU Amd Radeon.
Wifi: Realtek 8852be.
I am new to garuda linux and came here looking for some help.
I have referred to all the help forum and discussions that was previously posted and tried all the solutions but it was all in vein. I looked up:
Sadly, there have been so many changes at this point that it may be impossible to figure out what needs to be done to effect a fix (if that is even possible with your adapter).
I rarely ever tell people this, but it may be that reinstalling is the only way to methodically work through what needs to be done. Immediately after reinstalling create a snapshot of your system.
Was your wifi working on the live disk before you installed?
Was the wifi working immediately after install, before you re…
but I don't have the same driver and even if I looked up my driver in associated Linux driver in Garuda network manager, I do not see any drivers there so, I can't blacklist any of them. So, I thought that I need to install new ones.
I also tried to install driver from Chaotic aur AUR (en) - rtl8852be-dkms-git and then I restarted my PC but there was no success. I used the code:
git clone https://aur.archlinux.org/packages/rtl8852be-dkms-git
and restarted my PC but in vein.
After that I tried
paru -Syu aur/rtl8852be-dkms-git
and restarted the PC but in vein.
My bluetooth works but no WiFi.
Some help would be appreciated.
Welcome to the forum
Can you provide your
as per the forum template
jake
11 January 2023 16:07
3
Hello!
My apologies, I have included my system info below.
Kernel: 6.1.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=40512647-2999-447c-944b-0956993f4f0d rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 82SG v: IdeaPad 5 15ABA7
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 15ABA7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463WIN
serial: <superuser required> UEFI: LENOVO v: KACN17WW date: 08/05/2022
ID-1: BAT0 charge: 11.6 Wh (19.8%) condition: 58.5/57.0 Wh (102.6%)
volts: 11.1 min: 11.5 model: Celxpert L19C3PF5 type: Li-poly
serial: <filter> status: discharging cycles: 22
Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1695 high: 2531 min/max: 1600/4547 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2000 2: 1600
3: 2531 4: 1600 5: 1397 6: 2000 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600
12: 1600 13: 1600 14: 1600 15: 1600 16: 1600 bogomips: 63883
Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 40.0 C
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 5986:214d class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08c2 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 22.3.2 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.4-zen2-1-zen) direct render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.4-zen2-1-zen running: yes
Device-1: Realtek vendor: Lenovo driver: N/A pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:b852 class-ID: 0280
bus-ID: 3-3:2 chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 10.24 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDKCD512TFK
lanes: 4 type: SSD serial: <filter> rev: 1003V5LN temp: 24.9 C scheme: GPT
ID-1: / raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
used: 10.21 GiB (7.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 38.6 MiB (15.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-4: /var/log raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.1 C mobo: N/A gpu: amdgpu temp: 39.0 C
Processes: 337 Uptime: 4m wakeups: 9147 Memory: 13.5 GiB
used: 2.16 GiB (16.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1326
libs: 337 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2023-01-10
Last full system update: 2023-01-11
jake
11 January 2023 16:27
4
Additionally, I am not sure if the wifi driver is rtl8852be or rtw89 for archlinux as I came across this:
rtw89
### A repo for the newest Realtek rtlwifi codes.
This branch was created from the version merged into the wireless-drivers-next
repo, which is in the 5.16 kernel. IF YOU USE DRIVERS FROM THIS REPO FOR KERNELS
5.16+, YOU MUST BLACKLIST THE KERNEL VERSIONS!!!! FAILING TO DO THIS WILL RESULT
IN ALL MANNER OF STRANGE ERRORS.
This code will build on any kernel 5.7 and newer as long as the distro has not modified
any of the kernel APIs. IF YOU RUN UBUNTU, YOU CAN BE ASSURED THAT THE APIs HAVE CHANGED.
NO, I WILL NOT MODIFY THE SOURCE FOR YOU. YOU ARE ON YOUR OWN!!!!!
I am working on fixing builds on older kernels.
This repository includes drivers for the following card:
Realtek 8852AE, 8852BE, and 8853CE
If you are looking for a driver for chips such as
This file has been truncated. show original
this says that I need to do something with my kernel.
If you know how to do it can you please add it in here as this is the new driver and may help someone who needs it later.
filo
11 January 2023 16:36
5
If you still have this, I'd try switching to the linux-lts kernel (or reinstall that driver after the lts kernel).
Otherwise, you could also go for:
Ops, I see you have already found this.
Use the dkms one:
git clone https://aur.archlinux.org/rtw89-dkms-git.git
cd rtw89-dkms-git
makepkg -sri
jake
11 January 2023 22:54
6
Hello, Thanks I was able to get my driver installed.
I did the dkms code that was provided here and restarted the PC and it started working.
system
Closed
13 January 2023 22:54
7
