Hello I've recently installed Garuda as dualboot on my Lenovo Ideapad Gaming 3 15ACH16 (before I had Manjaro it had the same issue but I switched because other reasons)
The problem is apparrently I can only connect to wifi/bluetooth networks where I have line of sight to the Router for some reason (I tested it same router c.a. 10m no line of sight -> no connection. c.a. 20m line of sight fine connection. With bluetooth when I put my hands in front of my bluetooth headfones the audio cuts out, but without hands it is fine)
Lan works perfectly fine I have a Gigabit port and get a gigabit throughput.
The wifi works Perfectly fine on my Windows partition
I've looked into the network manager the Network cards show up there but nothing shows up under the "associated linux drivers"
Kernel: 6.0.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1d0e10bf-0ec9-4372-abb3-ad989ad1f8e4 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: LENOVO product: 82K2 v: IdeaPad Gaming 3 15ACH6
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ACH6
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
serial: <superuser required> UEFI: LENOVO v: H3CN31WW(V2.01)
date: 11/18/2021
ID-1: BAT1 charge: 36.1 Wh (59.5%) condition: 60.7/60.0 Wh (101.1%)
volts: 15.9 min: 15.4 model: 0x43 0x65 0x6C 0x78 0x70 0x 0x4C 0x32 0x30
0x43 0x34 0x50 0x6000 type: Li-ion serial: <filter> status: not charging
cycles: 29
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2218 high: 4441 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 3200
3: 3339 4: 1200 5: 3471 6: 1277 7: 1197 8: 1200 9: 1200 10: 1200 11: 3413
12: 1200 13: 3553 14: 1200 15: 4441 16: 3200 bogomips: 102207
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0302
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 43.0 C
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 13d3:56ff class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a81 built: 2021
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 22.2.2 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.48 6.0.7-zen1-1-zen) direct render: Yes
driver: snd_hda_intel bus-ID: 3-2.1:6 v: kernel pcie: chip-ID: 2e50:000b
class-ID: 0300 gen: 3 serial: <filter> speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: beyerdynamic GmbH & KG Blue Byrd (2nd generation) type: USB
Sound API: ALSA v: k6.0.7-zen1-1-zen running: yes
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-4:5 chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Local Storage: total: 1.38 TiB used: 16.68 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512GZL
lanes: 4 type: SSD serial: <filter> rev: C01C temp: 28.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 211070WD temp: 31.9 C scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
used: 16.65 GiB (17.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 26.1 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
ID-4: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 19.39 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.2 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 337 Uptime: 48m wakeups: 1 Memory: 19.39 GiB
used: 3.73 GiB (19.2%) Init: systemd v: 251 default: graphical
pkgs: 1380 libs: 350 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-08
Last full system update: 2022-11-15
rfkill list
0: ideapad_wlan: Wireless LAN
Soft blocked: yes
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
3: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
(I am currently not connected to wlan but to bluetooth
