Windows 11 dual boot with garuda hyprland no wifi card available.
Has tries reboot, disabled fast-startup and safe boot . try to find windows devices management wifi but nothing todo. Im stuck with a no wifi system.
Note : wifi in windows 11 work fine
Windows 11. Cpu intel i7 gen 12th
Disk 512gb. 90gb for linux.
Same on live ISO?
You can post the garuda-inxi from there.
Dual boot with M$ works fine but is not supported by Garuda Linux.
I take the iso on the download pages and do installed normally
If wifi works on live ISO, post from there, you can also use garuda-assistant (system-infos) as helper.
I don’t know what is a live ISO or thing?. But I somehow got copies from the garuda-inxi here
root=UUID=3c393380-6bfb-4094-95d5-d33178e862b6 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop X1505VA_A1505VA
Mobo: ASUSTeK model: X1505VA v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: X1505VA.300 date: 02/13/2023
ID-1: BAT0 charge: 47.8 Wh (100.0%) condition: 47.8/50.0 Wh (95.5%)
volts: 13.1 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: full cycles: 70
Info: model: 13th Gen Intel Core i7-13700H bits: 64 type: MST AMCP
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4119
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 425 high: 678 min/max: 400/4800:5000:3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 635 7: 400 8: 400 9: 400 10: 400 11: 678 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 116736
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:a7a0 class-ID: 0300
Device-2: IMC Networks [] driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:4 chip-ID: 13d3:5463
compositor: Hyprland driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 scale: 1 size: 344x194mm (13.54x7.64")
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-P) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:a7a0 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51ca class-ID: 0403
Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK vendor: AzureWave driver: N/A port: N/A
bus-ID: 0000:02:00.0 chip-ID: 14c3:7902 class-ID: 0280
Device-1: IMC Networks [] driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:5 chip-ID: 13d3:3579
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 476.94 GiB used: 291.91 GiB (61.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA512QFM
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA003 temp: 34.9 C
ID-1: / raw-size: 90 GiB size: 90 GiB (100.00%) used: 3.73 GiB (4.1%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 65.8 MiB (25.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 90 GiB size: 90 GiB (100.00%) used: 3.73 GiB (4.1%)
ID-4: /var/log raw-size: 90 GiB size: 90 GiB (100.00%)
used: 3.73 GiB (4.1%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-5: /var/tmp raw-size: 90 GiB size: 90 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.25 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 335 Uptime: 3m wakeups: 573 Memory: total: 16 GiB note: est.
available: 15.25 GiB used: 1.33 GiB (8.7%) Init: systemd v: 254
pm: pacman pkgs: 1189 libs: 354 tools: paru Shell: fish v: 3.6.1
running-in: foot inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-12-18
Last full system update: 2023-12-18
Also wifi doesn’t work on live OS (The bootable USB one) Too?
THe one you use for install Garuda, and work wifi on live ISO?
Nope.
So, I move it to Networking Support
That what you marked / is root.
Check in https://wiki.archlinux.org/ if your PC is compatible with Linux.
The reply system is a little broke. But I mean what is this lol.
N/A is not avaible from your garuda-inxi, you can search about too.
Hard or Software problem, IDK.
Do you have the MediaTek Wi-Fi 6E MT7902 Wireless Network Adapter? This one has no drivers available, according to Hardware for Linux.
I wasn’t able to find your specific model on there, but if you can find a Vivobook on this list similar to yours (or has the same network card), I think you will get your answer as to whether this is a software or hardware problem.
Yes I have that exact name. So I can’t use linux?
And That exact my computer. An asus vivobook
Unfortunately, that’s what it looks like. Realtek (or whoever should be writing those drivers) hasn’t done it for that card for Linux, most likely because it’s too new.
It’s a real shame ![]()
edit: Ah yes sorry, you can use Linux as long as you use your phone or some other means to get internet.
Can I plug the cable in an without the wireless thing?
Yes.
Just try
and wait for the wifi driver.
RAID?
Ewhat that
