Cannot load drivers for wifi card.
Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Lenovo
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 08:00.0 chip-ID: 1969:10a1 class-ID: 0200
Device-2: Broadcom BCM4352 802.11ac Dual Band Wireless Network Adapter
vendor: Lenovo driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 14e4:43b1 class-ID: 0280
Garuda-inxi:
╰─λ garuda-inxi
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e38ee0d4-0c6f-4526-9adf-c7cf1a1f23b5 rw rootflags=subvol=@
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: VIQYx v: INVALID
serial: <superuser required> Chassis: type: 10 v: INVALID
Mobo: LENOVO model: VIQY0Y1 v: 31900006WIN8 STD MBR IPG
serial: <superuser required> part-nu: LENOVO_BI_IDEAPAD
uuid: <superuser required> UEFI: LENOVO v: 74CN26WW(107T22)
date: 05/09/2013
ID-1: BAT1 charge: 42.4 Wh (100.0%) condition: 42.4/56.4 Wh (75.2%)
power: 655.4 W volts: 12.2 min: 10.8 model: LENOVO PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-4700MQ bits: 64 type: MT MCP arch: Haswell
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2813 high: 3400 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3400 2: 3400 3: 3400
4: 2110 5: 2259 6: 3400 7: 2144 8: 2398 bogomips: 38308
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: VGA-1,eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0416
Device-2: NVIDIA GK107M [GeForce GT 750M] vendor: Lenovo driver: nvidia
v: 470.239.06 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:0fe4 class-ID: 0300
Device-3: Realtek Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0bda:58b9
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa
dri: crocus gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2966x900 s-dpi: 96 s-size: 784x238mm (30.87x9.37")
s-diag: 819mm (32.26")
Monitor-1: VGA-1 pos: left model: LG (GoldStar) 20EN33 serial: <filter>
built: 2013 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes:
max: 1600x900 min: 720x400
Monitor-2: eDP-1 pos: primary,right model: LG Display 0x033a built: 2011
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia platforms: device: 0
drv: nvidia device: 2 drv: crocus device: 3 drv: swrast surfaceless:
drv: swrast x11: drv: crocus inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.0.4-arch1.1
device-ID: 8086:0416 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GT 750M driver: nvidia v: 470.239.06
device-ID: 10de:0fe4 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.4-arch1.1 (LLVM
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Lenovo 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Lite-On BCM20702A0 driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:5 chip-ID: 04ca:200b
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 2.27 TiB used: 1.31 TiB (57.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: <unknown> tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: <unknown>
ID-1: / raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
used: 23.36 GiB (23.3%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-2: /boot/efi raw-size: 1.86 GiB size: 1.86 GiB (99.80%)
used: 584 KiB (0.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 309.96 GiB size: 309.96 GiB (100.00%)
used: 95.12 GiB (30.7%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-4: /var/log raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 20.12 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 66.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.35 GiB used: 3.54 GiB (23.1%)
Processes: 278 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.11 GiB services: csd-power,upowerd
Packages: pm: pacman pkgs: 1430 libs: 412 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: gnome-terminal inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-04
Last full system update: 2024-04-01
