Hello everyone,
I’ve just installed Garuda Linux (dual boot with Windows) and I’m unable to get my Wi-Fi working. My Wi-Fi card is a MediaTek MT7902. The system detects the PCI device, but no Wi-Fi interface or networks appear in NetworkManager.
I have tried extensive troubleshooting for several hours. Here is a summary of everything I have already tried:
Performed a full system update via
garuda-update. -
Installed the latest firmware by replacing
linux-firmwarewithlinux-firmware-gitfrom the AUR. -
Confirmed that the
mt7921ekernel module was loaded at one point, but sometimes it is not loaded on boot. Manually loading it withmodprobe mt7921edoes not solve the issue. -
Checked
rfkill list alland confirmed there are no soft or hard blocks. -
Installed and booted into the
linux-ltskernel, but the issue persists. -
Disabled “Fast Startup” and “Hibernation” in my Windows installation.
Updated my laptop’s BIOS/UEFI to the latest version available on the manufacturer’s official website.
Checked
dmesglogs, and there are no messages (neither success nor error) related tomt79ormt7921e, even after trying to load the module manually.
Below is my full system information. Any help or guidance would be greatly appreciated.
<system:
Kernel:6.15.9-zen1-1-zenarch:x86_64bits:64compiler:gccv:15.1.1
clocksource:tscavail:acpi_pm
parameters:BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=8a150d86-2983-408b-baea-bcd5bb73be59 rw rootflags=subvol=@ quiet
loglevel=3 ibt=off
Desktop:KDE Plasmav:6.4.3tk:Qtv:N/Ainfo:frameworksv:6.16.0
wm:kwin_waylandvt:1dm:SDDMDistro:Garudabase:Arch Linux
Type:LaptopSystem:ASUSTeKproduct:Vivobook_ASUSLaptop X1404VA_A1404VA
v:1.0serial:<superuser required>
Mobo:ASUSTeKmodel:X1404VAv:1.0serial:<superuser required>
uuid:<superuser required>UEFI:American Megatrends LLC.v:X1404VA.312
date:01/21/2025
ID-1:BAT0charge:27.3 Wh (65.2%)condition:41.9/42.1 Wh (99.7%)
power:11.8 Wvolts:11.6min:11.8model:ASUSTeK ASUS Batterytype:Li-ion
serial:N/Astatus:dischargingcycles:48
Info: model:13th Gen Intel Core i5-1335Ubits:64type:MST AMCP
arch:Raptor Lakelevel:v3note:checkbuilt:2022+process:Intel 7 (10nm)
family:6model-id:0xBA (186)stepping:3microcode:0x4128
Topology: cpus:1xdies:1clusters:4cores:10threads:12mt:2tpc:2
st:8smt:enabledcache: L1:928 KiBdesc:d-8x32 KiB, 2x48 KiB; i-2x32
KiB, 8x64 KiB L2:6.5 MiBdesc:2x1.2 MiB, 2x2 MiBL3:12 MiB
desc:1x12 MiB
Speed (MHz): avg:712min/max:400/4600:3400scaling: driver:intel_pstate
governor:powersavecores: 1:7122:7123:7124:7125:7126:7127:712
8:7129:71210:71211:71212:712bogomips:59904
Flags:avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type:gather_data_samplingstatus:Not affected
Type:ghostwritestatus:Not affected
Type:indirect_target_selectionstatus:Not affected
Type:itlb_multihitstatus:Not affected
Type:l1tfstatus:Not affected
Type:mdsstatus:Not affected
Type:meltdownstatus:Not affected
Type:mmio_stale_datastatus:Not affected
Type:reg_file_data_samplingmitigation:Clear Register File
Type:retbleedstatus:Not affected
Type:spec_rstack_overflowstatus:Not affected
Type:spec_store_bypassmitigation:Speculative Store Bypass disabled via
Type:spectre_v1mitigation:usercopy/swapgs barriers and __user pointer
Type:spectre_v2mitigation:Enhanced / Automatic IBRS; IBPB: conditional;
PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Type:srbdsstatus:Not affected
Type:tsastatus:Not affected
Type:tsx_async_abortstatus:Not affected
Device-1:Intel Raptor Lake-P [UHD Graphics]vendor:ASUSTeKdriver:i915
v:kernelalternate:xearch:Xeprocess:Intel 10nmbuilt:2020-21ports:
active:eDP-1empty:HDMI-A-1bus-ID:0000:00:02.0chip-ID:8086:a721
class-ID:0300
Device-2:Sonix ASUS HD webcamdriver:uvcvideotype:USBrev:2.0
speed:480 Mb/slanes:1mode:2.0bus-ID:1-9:4chip-ID:2b7e:b868
class-ID:fe01serial:<filter>
Display:waylandserver:``X.org``v:1.21.1.18with:Xwaylandv:24.1.8
compositor:kwin_waylanddriver: X: loaded:modesetting
alternate:fbdev,intel,vesadri:irisgpu:i915display-ID:0
Monitor-1:eDP-1model:AU Optronics 0x403dbuilt:2016res:
mode:1920x1080hz:60scale:100% (1)dpi:158gamma:1.2
size:309x173mm (12.17x6.81")diag:354mm (13.9")ratio:16:9
modes:1920x1080
API:EGLv:1.5hw: drv:intel irisplatforms: device:0drv:iris
device:1drv:swrastgbm: drv:irissurfaceless: drv:iriswayland:
drv:irisx11: drv:iris
API:OpenGLv:4.6compat-v:4.5vendor:intel mesav:25.1.7-arch1.1
glx-v:1.4direct-render:yesrenderer:Mesa Intel Graphics (RPL-U)
device-ID:8086:a721memory:7.22 GiBunified:yesdisplay-ID::1.0
API:Vulkanv:1.4.321layers:5device:0type:integrated-gpu
name:Intel Graphics (RPL-U)driver:mesa intelv:25.1.7-arch1.1
device-ID:8086:a721surfaces:N/Adevice:1type:cpuname:llvmpipe
(LLVM 20.1.8 256 bits) driver:mesa llvmpipev:25.1.7-arch1.1 (LLVM
20.1.8) device-ID:10005:0000surfaces:N/A
Info: Tools: api:clinfo, eglinfo, glxinfo, vulkaninfo
de:kscreen-console,kscreen-doctorwl:wayland-info
x11:xdpyinfo, xprop, xrandr
Device-1:Intel Raptor Lake-P/U/H cAVSvendor:ASUSTeKdriver:snd_hda_intel
v:kernelalternate:snd_soc_avs,snd_sof_pci_intel_tglbus-ID:0000:00:1f.3
chip-ID:8086:51caclass-ID:0403
API:ALSAv:k6.15.9-zen1-1-zenstatus:kernel-apitools:N/A
Server-1:PipeWirev:1.4.7status:activewith: 1:pipewire-pulse
status:active2:wireplumberstatus:active3:pipewire-alsatype:plugin
4:pw-jacktype:plugintools:pactl,pw-cat,pw-cli,wpctl
Device-1:MEDIATEKvendor:AzureWavedriver:N/Aport:N/A
bus-ID:0000:02:00.0chip-ID:14c3:7902class-ID:0280
IF-ID-1:enp0s20f0u3state:unknownspeed:-1duplex:halfmac:<filter>
Info: services:NetworkManager,systemd-timesyncd
Device-1:IMC Networks Wireless_Devicedriver:btusbv:0.8type:USB
rev:2.1speed:480 Mb/slanes:1mode:2.0bus-ID:1-10:5chip-ID:13d3:3579
class-ID:e001serial:<filter>
Report:btmgmtID:hci0rfk-id:0state:upaddress:N/A
Device-2:MediaTek Infinix HOT 40 Prodriver:rndis_hostv:kernel
type:USBrev:2.0speed:480 Mb/slanes:1mode:2.0bus-ID:1-3:9
chip-ID:0e8d:2005class-ID:0a00serial:<filter>
Hardware-1:Intel Volume Management Device NVMe RAID Controller Intel
driver:vmdv:0.6port:N/Abus-ID:0000:00:0e.0chip-ID:8086:a77frev:
class-ID:0104
Local Storage: total:476.94 GiBused:7.55 GiB (1.6%)
SMART Message:Unable to run smartctl. Root privileges required.
ID-1:/dev/nvme0n1maj-min:259:0vendor:Micronmodel:2400 MTFDKBA512QFM
size:476.94 GiBblock-size: physical:512 Blogical:512 Bspeed:63.2 Gb/s
lanes:4tech:SSDserial:<filter>fw-rev:V3MA003temp:31.9 C
scheme:GPT
ID-1:/raw-size:100 GiBsize:100 GiB (100.00%)used:7.45 GiB (7.4%)
fs:btrfsdev:/dev/nvme0n1p4maj-min:259:4
ID-2:/boot/efiraw-size:260 MiBsize:256 MiB (98.46%)
used:105.1 MiB (41.1%)fs:vfatdev:/dev/nvme0n1p1maj-min:259:1
ID-3:/homeraw-size:100 GiBsize:100 GiB (100.00%)used:7.45 GiB (7.4%)
ID-4:/var/lograw-size:100 GiBsize:100 GiB (100.00%)
used:7.45 GiB (7.4%)fs:btrfsdev:/dev/nvme0n1p4maj-min:259:4
ID-5:/var/tmpraw-size:100 GiBsize:100 GiB (100.00%)
Kernel: swappiness:133 (default 60)cache-pressure:100 (default)zswap:no
ID-1:swap-1type:zramsize:7.39 GiBused:15.6 MiB (0.2%)priority:100
comp:zstdavail:lzo-rle,lzo,lz4,lz4hc,deflate,842dev:/dev/zram0
System Temperatures: cpu:53.0 Cmobo:N/A
Fan Speeds (rpm): cpu:3000
Memory: total:8 GiBnote:est.available:7.39 GiBused:4.79 GiB (64.8%)
Processes:317Power: uptime:1h 40mstates:freeze,mem,disk
suspend:s2idleavail:deepwakeups:1hibernate:platformavail:shutdown,
reboot, suspend, test_resume image:2.93 GiBservices:org_kde_powerdevil,
power-profiles-daemon, upowerd Init:systemdv:257default:graphical
tool:systemctl
Packages: pm:pacmanpkgs:1192libs:305tools:octopi,paruCompilers:
gcc:15.1.1Shell:fishv:4.0.2running-in:konsoleinxi: 3.3.38/>
