Why was plymouth disabled?
i just updated system and it seems that plymouth was disabled , im having issues with sddm , it doesnt show the images i select in sddm themes ?
Plymouth was disabled because the most recent version has been causing issues on some systems, including failure to boot. You are welcome to set it back up on your own if you'd like.
Please describe your issue with SDDM in a more specific way if you need assistance. Also missing is your garuda-inxi output.
To be fair, we also thought about disabling it before the issues started. This however was the perfect time to actually make the change :grin:
i guess then i will just keep it disabled . thanks for taking time to respond
