i was checking my mice in xinput then i found my system has already installed something "keyboard and mouse", opened that i found the process name is lxinput.
also i fetch packages shows my wm=lg3d. why? shouldn't it be qtile?
i am a beginner trying to switch to tiling window managers. why DE is here? cz afaik DE is not needed, what happens i uninstall this?
i can see pamac tray, pavucontrol tray is gone from my bar. why? and did I done anything risky? should i re-install lxde?
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=5a1a7018-04d3-413c-8c48-65d37ccf7308 rw rootflags=subvol=@
resume=UUID=4d1231c9-2dd3-48e1-9758-f32fd70cbe97 loglevel=3
Desktop: Qtile v: 0.21.1.dev87+g2ecbb5fd wm: LG3D vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B450M S2H v: x.x
serial: <superuser required> UEFI: American Megatrends v: F50
date: 11/27/2019
Info: model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3679 high: 3848 min/max: 2200/3906 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3722 2: 3831
3: 3848 4: 3594 5: 3429 6: 3596 7: 3830 8: 3584 bogomips: 57495
protection
always-on, RSB filling
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-2 empty: DP-1, DP-2,
DVI-D-1, HDMI-A-1 bus-ID: 0a:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-c4107
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: LG (GoldStar) FULL HD
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 14.0.6 DRM
3.46 5.18.16-zen1-1-zen) v: 4.6 Mesa 22.1.4 direct render: Yes
vendor: Sapphire driver: snd_hda_intel bus-ID: 3-1:7 v: kernel
chip-ID: 0c76:16cb pcie: class-ID: 0300 gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0a:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-3: JMTek LLC. FANTECH CAPTAIN 7.1 type: USB
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-4.1:4 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: N/A
Local Storage: total: 1.14 TiB used: 88.34 GiB (7.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: ADATA SX6000PNP
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V9002s34
temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
ID-1: / raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 88.34 GiB
(40.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 88.34
GiB (40.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 88.34
ID-5: /var/tmp raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 88.34
ID-1: swap-1 type: zram size: 15.57 GiB used: 2.2 MiB (0.0%)
ID-2: swap-2 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 55.8 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 800
Processes: 262 Uptime: 20m wakeups: 0 Memory: 15.57 GiB used: 1.78 GiB
(11.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1412 lib: 357
Shell: Zsh v: 5.9 running-in: alacritty inxi: 3.3.20
Garuda (2.6.5-1):
System install date: 2022-08-04
Last full system update: 2022-08-06
Failed units: swapfile.swap
