I have GNOME version of Garuda installed. One of the more recent updates for garuda-gnome-settings requires kvantum as a depdency, but when that’s installed, it messes with some apps’ theming
For reference, I forced dark mode onto a couple apps by following this tutorial:https://www.reddit.com/r/Ubuntu/comments/n80xdi/is_there_a_way_to_force_dark_mode_onto_apps_that/
But kvantum keeps overriding it. If possible, could I just roll back the garuda-gnome-settings update and ignore it in the future?
Kernel: 6.7.9-x64v-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=30342c7e-f5f2-4539-b072-b8c3e5701d39 rw rootflags=subvol=@
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Garuda
Type: Desktop Mobo: ASRock model: B550 Phantom Gaming 4/ac serial: <filter>
uuid: 7059a1a8-f454-0000-0000-000000000000 UEFI: American Megatrends LLC.
v: P2.20 date: 02/24/2022
Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3800 min/max: 2200/4850 boost: enabled
base/boost: 3800/4850 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3800 2: 3800 3: 3800 4: 3800
5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800
13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121365
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: Micro-Star MSI
driver: nvidia v: 550.54.14 alternate: nvidiafb,nouveau,nvidia_drm
non-free: 545.xx+ status: current (as of 2024-02; EOL~2026-12-xx)
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 06:00.0
chip-ID: 10de:2482 class-ID: 0300
Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2
chip-ID: 0c45:8006 class-ID: 0301
Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
display-ID: :1 screens: 1
Screen-1: 0 s-res: 3520x1189 s-dpi: 96 s-size: 931x315mm (36.65x12.40")
s-diag: 983mm (38.69")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,top-left
model: Sceptre K25 built: 2022 res: 1920x1080 dpi: 90 gamma: 1.2
size: 543x302mm (21.38x11.89") diag: 621mm (24.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: bottom-r
model: HP V20 serial: <filter> built: 2021 res: 1600x900 hz: 60 dpi: 94
gamma: 1.2 size: 432x240mm (17.01x9.45") diag: 501mm (19.7") ratio: 16:9
modes: max: 1600x900 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 550.54.14 device-ID: 10de:2482
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 06:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.7.9-x64v-xanmod1-1 status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: n/a (root, process) with:
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0aa7
Local Storage: total: 4.55 TiB used: 582.56 GiB (12.5%)
model: WD10EZEX-00BBHA0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 1.2 TiB size: 1.2 TiB (100.00%) used: 582.53 GiB (47.5%)
fs: btrfs block-size: 4096 B dev: /dev/sdb5 maj-min: 8:21
used: 28.7 MiB (29.9%) fs: vfat block-size: 512 B dev: /dev/sdb1
maj-min: 8:17
ID-3: /home raw-size: 1.2 TiB size: 1.2 TiB (100.00%)
used: 582.53 GiB (47.5%) fs: btrfs block-size: 4096 B dev: /dev/sdb5
maj-min: 8:21
ID-4: /var/log raw-size: 1.2 TiB size: 1.2 TiB (100.00%)
maj-min: 8:21
ID-5: /var/tmp raw-size: 1.2 TiB size: 1.2 TiB (100.00%)
maj-min: 8:21
zswap: no
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 50 C
Memory: total: 32 GiB available: 31.27 GiB used: 3.19 GiB (10.2%)
Processes: 581 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: gsd-power,
Packages: 1749 pm: pacman pkgs: 1696 libs: 521 tools: paru pm: flatpak
pkgs: 53 Compilers: gcc: 13.2.1 Shell: garuda-inxi (sudo) default: fish
v: 3.7.0 running-in: gnome-terminal inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-08
Last full system update: 2024-03-09
Windows dual boot: Yes
output of upd -- kvantum-kvantum-qt5:
garuda is up to date
core 134.0 KiB 338 KiB/s 00:00 [----------------------] 100%
extra 8.4 MiB 7.55 MiB/s 00:01 [----------------------] 100%
multilib 142.5 KiB 367 KiB/s 00:00 [----------------------] 100%
chaotic-aur 2.5 MiB 2.80 MiB/s 00:01 [----------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su kvantum kvantum-qt5
resolving dependencies...
warning: insufficient columns available for table display
Packages (20) btrfs-assistant-2.0-1
cachyos-ananicy-rules-git-20240309.r307.gcaaa9cd-1 dracut-059-6
gcr-4-4.2.1-2 gnome-disk-utility-46.0-1
gpt4all-chat-git-r1704.61d67653-1
lib32-faudio-tkg-git-24.03.r3.gcfdc4db-1
lib32-librsvg-2:2.57.2-1 lib32-xz-5.6.1-1 librsvg-2:2.57.2-1
poppler-24.03.0-1 poppler-glib-24.03.0-1 poppler-qt6-24.03.0-1
proton-ge-custom-2:GE.Proton9.1-1 qt6-5compat-6.6.2-2
wget-1.24.5-1 xz-5.6.1-1 yt-dlp-2024.03.10-1 kvantum-1.0.10-3
kvantum-qt5-1.0.10-3
Total Download Size: 261.35 MiB
Total Installed Size: 1187.28 MiB
Net Upgrade Size: -18.32 MiB
