Startup finished in 4.632s (firmware) + 7.612s (loader) + 437ms (kernel) + 12.812s (initrd) + 3min 9.028s (userspace) = 3min 34.523s
graphical.target reached after 2min 19.323s in userspace.
First, no garuda-inxi (why?)
Maybe a solution (WAIT for others suggestions too) is changing kernels can help. Try changing to linux-cachyos-bore or linux-xanmod.
Edit your post with inxi (or no one is likely to help and also the thread will be moved)
Hmm did someone suggest kernel.
Lately Norbert (someone I know on telegram) found nitrous kernel it’s really good too. ![]()
sudo pacman -S linux-nitrous-headers linux-nitrous
Choose it from grub → advanced settings and see if you like it? If it’s something you like and would like to be default go to garuda boot options and do the needful.
Btw, look at
systemd-analyze blame
And
systemd-analyze critical-chain
To take a look at what’s taking up so much time and disable it as per your discretion (be careful here !!)
don’t be lazyfollow template provide garuda-inxi
here’s garuda-inxi
Kernel: 6.7.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6dfa7961-f821-48b4-aaa1-22588228c2be rw rootflags=subvol=@
loglevel=3 splash sysrq_always_enabled=1
systemd.unified_cgroup_hierarchy=1 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 82H8 v: IdeaPad 3 15ITL6
serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15ITL6
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: GGCN32WW date: 01/15/2022
ID-1: BAT0 charge: 15.8 Wh (48.9%) condition: 32.3/38.0 Wh (84.9%)
power: 23.8 W volts: 8.3 min: 7.7 model: Celxpert L20C2PF0 type: Li-poly
serial: <filter> status: charging cycles: 338
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xB4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 528 high: 1046 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 784 7: 400 8: 1046 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2 chip-ID: 5986:2137
class-ID: 0e02
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 7.38 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 8 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 23.3.4-arch1.2
device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.4-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.7.2-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 931.51 GiB used: 824.3 GiB (88.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 2E scheme: GPT
ID-1: / raw-size: 921.45 GiB size: 921.45 GiB (100.00%)
used: 824.3 GiB (89.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 921.45 GiB size: 921.45 GiB (100.00%)
ID-4: /var/log raw-size: 921.45 GiB size: 921.45 GiB (100.00%)
ID-5: /var/tmp raw-size: 921.45 GiB size: 921.45 GiB (100.00%)
ID-1: swap-1 type: partition size: 9.77 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.56 GiB used: 1.12 GiB (14.8%)
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 338 Uptime: 4h 48m wakeups: 1 Memory: total: 8 GiB
available: 7.56 GiB used: 4.58 GiB (60.6%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 4100
pm: dpkg pkgs: 1 tools: apt,apt-get,gnome-software pm: pacman pkgs: 2034
libs: 546 tools: octopi,pamac,paru,yay pm: rpm pkgs: N/A note: see --rpm
tools: dnf pm: snap pkgs: 31 Shell: fish v: 3.7.0 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-11-21
Last full system update: 2024-02-08
Failed units: nmb.service
What should I disable?
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @2min 19.323s
└─multi-user.target @2min 19.323s
└─smb.service @2min 18.406s +916ms
└─network-online.target @48.195s
└─NetworkManager-wait-online.service @43.955s +4.238s
└─NetworkManager.service @40.759s +3.184s
└─network-pre.target @40.746s
└─firewalld.service @33.495s +7.251s
└─polkit.service @25.065s +8.416s
└─basic.target @25.049s
└─dbus-broker.service @24.329s +717ms
└─dbus.socket @24.280s
└─sysinit.target @23.785s
└─systemd-timesyncd.service @23.610s +174ms
└─systemd-tmpfiles-setup.service @21.742s +1.858s
└─systemd-journal-flush.service @15.271s +6.456s
└─var-log.mount @14.946s +314ms
└─dev-sda2.device @584542y 2w 2d 20h 1min 38.131s +26.355s
The first thing I’d try is to change this, also because it’s for NVMe but you have
(which is slower, but shouldn’t be that much slow).
Change in your BIOS the SATA controller from vmd to AHCI (or something like that).
Have you fixed this yet?
the garuda-inxi indicates that your cpu is only hitting 1046mhz. try doing something heavy(play a game, there are plenty of free games available through pacman/pamac/octopi/etc… or run a heavy application like blender or something you use for work) and then run garuda-inxi(and post here) again. if your cpu isn’t turboing up to what it says it can(4200mhz according to your garuda-inxi) the problem may lay elsewhere.
No ![]()
