It happens rarely, but sometimes after i shutdown my pc and booting it up the next day my task bar configuration is reseted, i have a different wallpaper and my keyring gets reseted. (like i said, its very rarely it happend 2x in the last 30 days)
But its not that everything from kde gets reseted, my applied window rules are still there. And last time i got logged out from everything when the keyring got reseted, this time i got logged out from my VPN and it forgott my passwort for the Wlan.
Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=040abae5-a66a-4e4e-96eb-be857e61b87b rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: B.40
date: 11/07/2019
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4124 high: 4367 min/max: 2200/4409 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4077 2: 4316
3: 4173 4: 3651 5: 4270 6: 4252 7: 4217 8: 4367 9: 3683 10: 4162 11: 4058
12: 4266 bogomips: 91197
vendor: Tul driver: amdgpu v: kernel bus-ID: 2b:00.0 chip-ID: 1002:731f
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
Monitor-2: HDMI-A-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.44.0
5.16.4-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 2b:00.1 chip-ID: 1002:ab38 class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 2d:00.4 chip-ID: 1022:1487
Device-3: C-Media CM108 Audio Controller type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:4 chip-ID: 0d8c:013c
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 25:00.0
IF: enp37s0 state: down mac: <filter>
Device-2: Realtek RTL8811AU 802.11a/b/g/n/ac WLAN Adapter type: USB
driver: rtl88XXau bus-ID: 1-3:3 chip-ID: 0bda:a811 class-ID: 0000
IF: wlp3s0f0u3 state: up mac: <filter>
IF-ID-2: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-3: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-4: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 3.18 TiB used: 531.54 GiB (16.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA300
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 750 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 98.2 GiB (21.1%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.63 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 58.0 C
Processes: 418 Uptime: 11m wakeups: 0 Memory: 15.63 GiB
used: 5.03 GiB (32.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2141 lib: 478 Shell: fish
Garuda (2.5.3-1):
System install date: 2022-01-14
Last full system update: 2022-02-01
Failed units: bluetooth-autoconnect.service```
