Why do I have /opt/venv/bin/unoserver installed?
I was checking the execution of a Python application and I came across this output from the ps command:
... /opt/unoserver-venv/bin/python3 /opt/venv/bin/unoserver --interface 127.0.0.1 --port 2003 --uno-port 2004
I’ve searched for which package contains these executables, but it doesn’t seem to belong to any:
$ pacman -Qo /opt/unoserver-venv/bin/python3
error: No package owns /opt/unoserver-venv/bin/python3
$ pacman -Qo /opt/venv/bin/unoserver
error: No package owns /opt/venv/bin/unoserver
I didn’t install LibreOffice, nor did I manually install this application. Could someone tell me why it’s installed and how to remove it?
Thanks. Regards.
  Kernel: 6.18.6-arch1-1-znver2 arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver2
    root=UUID=e82c503d-1ee8-4223-8cef-ee68649b3783 rw rootflags=subvol=@
    quiet loglevel=3 mitigations=off sysrq_always_enabled=1
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
  Mobo: ASUSTeK model: PRIME TRX40-PRO v: Rev 1.xx
    Firmware: UEFI vendor: American Megatrends v: 2302 date: 05/05/2025
  Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
  Info: model: AMD Ryzen Threadripper 3970X bits: 64 type: MT MCP arch: Zen 2
    gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x31 (49) stepping: 0 microcode: 0x830107D
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 32 threads: 64 tpc: 2
    smt: enabled cache: L1: 2 MiB desc: d-32x32 KiB; i-32x32 KiB L2: 16 MiB
    desc: 32x512 KiB L3: 128 MiB desc: 8x16 MiB
  Speed (MHz): avg: 1755 min/max: 576/4551 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 1755 2: 1755 3: 1755
    4: 1755 5: 1755 6: 1755 7: 1755 8: 1755 9: 1755 10: 1755 11: 1755 12: 1755
    13: 1755 14: 1755 15: 1755 16: 1755 17: 1755 18: 1755 19: 1755 20: 1755
    21: 1755 22: 1755 23: 1755 24: 1755 25: 1755 26: 1755 27: 1755 28: 1755
    29: 1755 30: 1755 31: 1755 32: 1755 33: 1755 34: 1755 35: 1755 36: 1755
    37: 1755 38: 1755 39: 1755 40: 1755 41: 1755 42: 1755 43: 1755 44: 1755
    45: 1755 46: 1755 47: 1755 48: 1755 49: 1755 50: 1755 51: 1755 52: 1755
    53: 1755 54: 1755 55: 1755 56: 1755 57: 1755 58: 1755 59: 1755 60: 1755
    61: 1755 62: 1755 63: 1755 64: 1755 bogomips: 476451
    ssse3 svm
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: XFX Pine driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2,
    DP-3, DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 74.0 C
    compositor: kwin_wayland driver: gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: Dell S2721DS serial: <filter> built: 2020 res:
    mode: 2560x1440 hz: 75 scale: 100% (1) dpi: 110 gamma: 1.2
    size: 597x336mm (23.5x13.23") diag: 676mm (26.6") ratio: 16:9 modes:
    max: 2560x1440 min: 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.3-arch1.3.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
    polaris10 ACO DRM 3.64 6.18.6-arch1-1-znver2) device-ID: 1002:67df
    memory: 7.81 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.4.335 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv
    v: 25.3.3-arch1.3.1 device-ID: 1002:67df surfaces: N/A device: 1 type: cpu
    name: llvmpipe (LLVM 21.1.6 256 bits) driver: mesa llvmpipe
    v: 25.3.3-arch1.3.1 (LLVM 21.1.6) device-ID: 10005:0000 surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: XFX Pine driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
    vendor: ASUSTeK driver: N/A alternate: snd_hda_intel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 23:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-6:3
    chip-ID: 0b05:1918 class-ID: 0300
  API: ALSA v: k6.18.6-arch1-1-znver2 status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 44:00.0
  IF: enp68s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-46d079a22394 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-2: br-96946240fd9e state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: vethc8de171 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-5: vethe52eeb1 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Info: services: NetworkManager, nfsd, smbd, sshd, systemd-timesyncd
  Local Storage: total: 47.01 TiB used: 28.42 TiB (60.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 model: WUS4BB076D7P3E3 size: 6.99 TiB
    block-size: physical: 4096 B logical: 4096 B speed: 31.6 Gb/s lanes: 4
    tech: SSD serial: <filter> fw-rev: R1110021 temp: 57.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Seagate model: FireCuda 520 SSD
    ZP2000GM30002 size: 1.82 TiB block-size: physical: 4096 B logical: 4096 B
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: STNSC016
    temp: 52.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WUH721818ALE6L4
    size: 16.37 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: W232
    model: WUH722018CLE6L4 size: 16.37 TiB block-size: physical: 4096 B
    fw-rev: WD07
  ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD60EFRX-68L0BN1 size: 5.46 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5700 serial: <filter>
    fw-rev: 0A82
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 33.27 GiB (1.8%)
  ID-2: /boot/efi raw-size: 300 MiB size: 299.3 MiB (99.76%)
    used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
    used: 33.27 GiB (1.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 62.65 GiB used: 1.2 MiB (0.0%) priority: 100
  System Temperatures: cpu: 63.9 C mobo: N/A gpu: amdgpu temp: 74.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1140
  Memory: total: 64 GiB note: est. available: 62.65 GiB
    used: 14.45 GiB (23.1%)
  Processes: 1091 Power: uptime: 1h 11m states: freeze,mem,disk
    reboot, suspend, test_resume image: 25.03 GiB
    services: org_kde_powerdevil,upowerd Init: systemd v: 259
  Packages: pm: pacman pkgs: 1328 libs: 262 tools: octopi,paru Compilers:
    clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.3.3
    running-in: konsole inxi: 3.3.40
Garuda (2.12.3-2):
  System install date:     2026-01-18
  Garuda release:          260115
  Last full system update: 2026-01-21 ↻
25/26 checks run in 0.87 seconds ⌛
Powered by garuda-health 🦅
--- INFO ---
 - Pacman configuration file does not have the multilib repository enabled
Use pacseek and try to remove it, or check with pacman or paru -Qi python-unoserver
i do not much which python myself but i know you did something lol. This is a python environment and it didnt do it alone . So you did installed any pip packages who have this in their python script and set this dependencies for it. I even not did see this Folder on any fresh installs of Garuda-isos at all. If you installed something with python-pip and search then which pacman packages using it you will never find it thats 2 different shoes. So check the pip packages you installed :wink:
I have already found it. It is launched by a docker container that I have installed: stirling-pdf.
:face_exhaling:
