╰─λ garuda-inxi
Kernel: 6.1.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f2c0dcd5-0c63-47e8-bbfd-41c886e75d9c rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: LXQt v: 1.2.1 tk: Qt v: 5.15.8 info: cairo-dock, lxqt-panel
Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 2601 date: 05/17/2022
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3800 min/max: 800/5100 scaling: driver: intel_pstate
governor: performance cores: 1: 3800 2: 3800 3: 3800 4: 3800 5: 3800 6: 3800
7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800 13: 3800 14: 3800
15: 3800 16: 3800 bogomips: 121596
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 52.0 C
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
missing.
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound API: ALSA v: k6.1.9-zen1-1-zen running: yes
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 3.18 TiB used: 11.09 GiB (0.3%)
model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
rev: 211070WD temp: 35.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
used: 11.09 GiB (4.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1087
Processes: 370 Uptime: 20m wakeups: 0 Memory: 31.25 GiB
used: 3.07 GiB (9.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1363
libs: 335 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.0
running-in: qterminal inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-02-02
Last full system update: 2023-02-02
Your fans are running because your laptop is getting warm. Installing a distro is a pretty intensive process; there is a lot of disk activity that has to happen and the CPU will be busy.
just to double check - are your fans going crazy when you are installing (explanation as per bluish), or are they still going crazy AFTER installing and rebooting (with nothing additional opened after logging back in)?
they do this after i install
can you check which process is hogging the resources please.
how?
install htop at the terminal (sudo pacman -S htop) and run it (just type htop at a terminal) to see whats hogging cpu - at a guess, kwin_x11, but check to see (and also how many kwins too).
