Hello there. Switched to gaming on Linux for one reason. My Windows kept crashing video drivers when I’m alt+tabbing which was annoying as hell.
Now, when playing any game using GE-Proton (not sure if it happens on any other Proton/Wine versions because the issue is kind of rare.) I can catch a full system freeze after alt+tab into the game (audio looping, picture fully froze, can’t switch to another tty) and that’s it.
I’m pretty sure there are no memory leaks or something like that because I’ve kept my eyes on RAM and it’s perfectly fine.
For now I’m using Crtl+F1 and Crtl+F2 to switch between desktops, keeping my game opened on the 2nd one. It seems like I don’t encounter any issues that way, but I still hope for a potential fix for alt+tab.
Please help :d
My garuda-inxi output:
Kernel: 6.10.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=35b99d73-ff94-4fc5-ac66-9171b68685f2 rw rootflags=subvol=@
quiet resume=UUID=6150be1b-f016-4fee-8f1d-e688372a1e74 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Mobo: ASUSTeK model: PRIME B450M-K II v: Rev X.0x
UEFI: American Megatrends v: 3810 date: 11/21/2022
Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2992 high: 3160 min/max: 400/4359 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2961 2: 2977 3: 2931
4: 3160 5: 2970 6: 2994 7: 2998 8: 2971 9: 2988 10: 2998 11: 2964 12: 2997
bogomips: 86395
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: Sapphire
active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:73ef class-ID: 0300
gpu: amdgpu display-ID: 0
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6650 XT (radeonsi
navi23 LLVM 18.1.8 DRM 3.57 6.10.5-zen1-1-zen) device-ID: 1002:73ef
API: Vulkan v: 1.3.279 layers: 15 device: 0 type: discrete-gpu name: AMD
Radeon RX 6650 XT (RADV NAVI23) driver: mesa radv v: 24.1.6-arch1.1
device-ID: 1002:73ef surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.6-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
link-max: gen: 4 speed: 16 GT/s bus-ID: 0c:00.1 chip-ID: 1002:1637
link-max: gen: 4 speed: 16 GT/s bus-ID: 0c:00.6 chip-ID: 1022:15e3
Device-4: Trust GXT 258 Microphone
lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 145f:029d class-ID: 0300
API: ALSA v: k6.10.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 0a:00.0 chip-ID: 10ec:8168
IF: enp10s0 state: down mac: <filter>
IF-ID-1: enp4s0f0u3 state: unknown speed: -1 duplex: half mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd
Device-1: vivo V2111 driver: rndis_host v: kernel type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:5 chip-ID: 2d95:600b
Local Storage: total: 2.09 TiB used: 749.03 GiB (35.0%)
model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 39.9 C scheme: GPT
model: WD10EZEX-60M2NA0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A03 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Intel model: SSDSA2CW300G3
size: 279.46 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0362 scheme: GPT
ID-1: / raw-size: 262.22 GiB size: 262.22 GiB (100.00%)
used: 136.4 GiB (52.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 262.22 GiB size: 262.22 GiB (100.00%)
ID-4: /var/log raw-size: 262.22 GiB size: 262.22 GiB (100.00%)
ID-5: /var/tmp raw-size: 262.22 GiB size: 262.22 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.95 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 42.9 C mobo: N/A gpu: amdgpu temp: 52.0 C
mem: 52.0 C
Memory: total: 16 GiB note: est. available: 15.41 GiB used: 4.81 GiB (31.2%)
Processes: 358 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
Packages: 4149 pm: pacman pkgs: 2072 libs: 588 tools: octopi,paru,yay
pm: rpm pkgs: N/A note: see --rpm tools: dnf pm: flatpak pkgs: 5 Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-07-13
Last full system update: 2024-08-17
