Who controls Fire dragon?
Hi, maybe a little bit of a weird question:
Coming from Apple using Firefox, now using Garuda on 2nd laptop with FireDragon I am wondering who controls the data in Firedragon? This actually came to mind when I wanted to save passwords in Firedragon.
I now use that function in Firefox. I understand that FD is a fork of… And I noticed I can login on Firedragon with a Mozilla account but I´m still curious where my data is going.
Someone care to explain to a new user?
  Kernel: 6.6.62-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=af6daf6d-0b17-45fc-9c9e-502523ec0380 rw rootflags=subvol=@
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
  Type: Laptop System: Hewlett-Packard product: HP ProBook 650 G1
    v: A3009DD10203 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 1993 v: KBC Version 16.3C
    serial: <superuser required> part-nu: D9S33AV uuid: <superuser required>
    BIOS: Hewlett-Packard v: L77 Ver. 01.43 date: 01/25/2018
  ID-1: BAT0 charge: 42.4 Wh (100.0%) condition: 42.4/42.4 Wh (100.0%)
    volts: 12.2 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: full
  Info: model: Intel Core i5-4310M bits: 64 type: MT MCP arch: Haswell
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 800 min/max: 800/3400 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 21558
  Device-1: Intel 4th Gen Core Processor Integrated Graphics
    vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-7.5
    process: Intel 22nm built: 2013 ports: active: eDP-1 empty: DP-1, DP-2,
    DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0416 class-ID: 0300
  Device-2: Chicony HP HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 04f2:b3ed
  Display: x11 server: X.Org v: 21.1.14 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: modesetting alternate: fbdev,intel,vesa dri: crocus gpu: i915
    display-ID: :0.0 screens: 1
  Monitor-1: eDP-1 model: AU Optronics 0x34ed built: 2012 res: 1920x1080
    ratio: 16:9 modes: 1920x1080
  API: Vulkan v: 1.3.295 layers: 5 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.2.7-arch1.1
    device-ID: 8086:0416 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  Device-2: Intel 8 Series/C220 Series High Definition Audio
    chip-ID: 8086:8c20 class-ID: 0403
  API: ALSA v: k6.6.62-1-lts status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I217-V vendor: Hewlett-Packard driver: e1000e
    v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
  Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:088e
  Device-1: Intel Centrino Bluetooth Wireless Transceiver driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-12:4
    chip-ID: 8087:07da class-ID: e001
    rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
  Local Storage: total: 119.24 GiB used: 16.16 GiB (13.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7LN128HAHQ-000H1
    size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3H3Q scheme: MBR
  ID-1: / raw-size: 79.47 GiB size: 79.47 GiB (100.00%)
    used: 16.16 GiB (20.3%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
  ID-2: /home raw-size: 79.47 GiB size: 79.47 GiB (100.00%)
  ID-3: /var/log raw-size: 79.47 GiB size: 79.47 GiB (100.00%)
  ID-4: /var/tmp raw-size: 79.47 GiB size: 79.47 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.67 GiB used: 1.42 GiB (18.5%)
  System Temperatures: cpu: 53.0 C mobo: N/A
  Memory: total: 8 GiB available: 7.67 GiB used: 3.18 GiB (41.4%)
  Processes: 234 Power: uptime: 2h 49m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.06 GiB services: upowerd,xfce4-power-manager
  Packages: pm: pacman pkgs: 1358 libs: 434 tools: paru Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.36
  System install date:     2024-11-14
  Last full system update: 2024-11-21
Not my place to speak, but it would be of help to you to read through:
Where you might learn things like:
Firefox accounts are enabled and profile data is synced to a custom self-hosted sync server (ffsync.garudalinux.org)
If you are curious about the safety of your data, you should know its safe.
Well I thought it was the idea of a forum that everyone can speak, unless you have nothing to add to the conversation…
So thanks for the link, hadn´t found that yet. Still trying to get around in the new world of Garuda linux.
So if I understand correctly that is a server run by the team behind Garuda Linux?
Well I suppose I have to put some trust in that then. To be honest I also don´t personally know the people behind Mozilla/Firefox… :thinking:
The fact that I use the Password function in Firefox is maybe because it is a more well-know name.
Thanks for clearing things up, -->will read the link :wink:
Keep up the good work,
Ray
Yes, it’s also located on the same server as this forum.
