White screens while gaming and flashes white while logging in
I noticed this after an update and then tried numerous times on steam to open 2 different games, using proton 7.0-6 and experimental. But the white screen of doom shows up and the game music plays in the background.
Kernel: 6.2.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f59d38bd-cf5e-491b-86a9-d187ced31297 rw [email protected]
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG CROSSHAIR X670E HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0805
date: 11/04/2022
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4384 high: 4500 min/max: 3000/5572 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4500 2: 4500
3: 4500 4: 4500 5: 4500 6: 4500 7: 4500 8: 4500 9: 3563 10: 4500 11: 4500
12: 4500 13: 4500 14: 3593 15: 4500 16: 4500 bogomips: 143725
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1, DP-2, DP-3,
HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-2 empty: DP-4,DP-5
bus-ID: 6e:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 39.0 C
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 676x380mm (26.61x14.96")
s-diag: 775mm (30.53")
Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: AOC U32V3 serial: <filter>
built: 2022 res: 2560x1440 hz: 60 dpi: 93 gamma: 1.2
max: 3840x2160 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon Graphics (gfx1036
LLVM 15.0.7 DRM 3.49 6.2.8-zen1-1-zen) direct-render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 8-11:3 pcie: gen: 4
chip-ID: 0b05:1a53 speed: 16 GT/s class-ID: 0300 lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:ab30 class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 6e:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: ASUSTek USB Audio type: USB
Device-4: Jieli USB-Sounbar-V18 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 9-5.1:4 chip-ID: 5943:3130
API: ALSA v: k6.2.8-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.67 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 8086:2725
IF: wlp10s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0b:00.0
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 8-6:2
chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 5.5 TiB used: 527.52 GiB (9.4%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: TeamGroup
model: T-FORCE TM8FP8002T size: 1.86 TiB block-size: physical: 512 B
rev: VC0S036I temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 38.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Samsung model: SSD 980 PRO 2TB
ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 527.49 GiB (27.7%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
used: 29.9 MiB (10.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 527.49 GiB (27.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
ID-4: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-1: swap-1 type: zram size: 61.95 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 45.2 C mobo: N/A
GPU: device: amdgpu temp: 39.0 C mem: 53.0 C fan: 0 watts: 63.00
Processes: 419 Uptime: 6m wakeups: 1 Memory: 61.95 GiB used: 4.5 GiB (7.3%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 1994 libs: 566 tools: octopi,paru
inxi: 3.3.26
System install date:     2023-01-13
Last full system update: 2023-03-31 ↻
please share the latest update log from /var/log/garuda. One of them might be empty so inspect them first.
Share the file via the text bin on the top right of this forum page
Also please encase your inxi in ~~~
Welcome :slight_smile:
Hi,
I edit your text, please use next time
then others can easily expand or copy the text.
Have you tried disabling the compositor before playing?
You can enable / disable the compositor on the fly with alt+shift+F12.
Ya kinda sorta works with flashing white screen of doom still. Still trying to figure out how to get that update log to you guys. I type /var/log/garuda into the terminal and it spits /var/log/garuda back out.
figured it out! did a full package reinstall and compositor disable to get it to work. Thx!
