Which kernel should I be using. My system freezes intermittently. Started using bird of prey today.
Try to post garuda-inxi, please.
The template you are missing because you posted in the wrong area.
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature)
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
You should be using whichever kernel does not freeze intermittently. ![]()
LOL which one is that ![]()
It’s just a matter of trying.
Changing kernels is extremely easy and quick, so testing should not take you too long (if freezes usually appear right away).
sudo pacman -S linux linux-headers
sudo pacman -S linux-mainline linux-mainline-headers
sudo pacman -S linux-hardened linux-hardened-headers
You can install a kernel also with Garuda Settings Manager → Kernel (remember to push Refresh button first).
There may be some problems with certain kernels if you have an Nvidia dGPU.
By-the-way, freezes are not necessarily due to the kernel in use.
After that, of course, you will have to select the desired kernel from the Grub in Advanced Options.
We could help you better if you followed the forum rules. Describe your problem exactly - how, when and what causes the system to freeze?
And post your garuda-inxi as requested by the template, please.
Apologies, I will do that when I get a chance. Thank you.
It just freezes randomlly.
And while you’re at it, describe the freezes better, for example whether they only last for a short time or whether a hard reset is necessary, etc. Freeze is not always the same ![]()
Try the sanders kernel, too, when you get a chance. ![]()
I have to do a hard reset
From where can I get the sanders kernel, Sorry quite new to Linux
I’m pretty sure he was making a joke in reference to Colonel Sanders of Kentucky Fried Chicken fast food chain lol.
Is your new install running the Zen kernel? If you run Setup assistant again, and get to the software page, installing other kernels is as easy as clicking a checkbox, then on reboot select Advanced Options for Garuda Linux, and try out other kernels. Good things have been said about CachyOS-bore kernel. Try other kernels and use them for a while, and see how each affects your system different. Choose the one that works the best for you. ![]()
- Look, we require you post the output of garuda-inxi to receive help.
- Do not post in a chat type style. You aren’t in a chat room.
