Where does Dolphin execute scripts?
I want to execute a python script directly by clicking on it in Dolphin.
I've made it executable and added #!/usr/bin/python3 in the file, so now I'm able to execute it simply via ./script.py, but when I open it via Dolphin and choose to execute it, I don't see a terminal window, nor does the built-in terminal show anything, so i wanted to know where (if it is being executed at all) the script is being run.
Any way to make Dolphin execute scripts on konsole/fish would be nice too.
Thanks in advance
root=UUID=d4f71312-d373-4bbb-8f13-b65701e08cf0 rw rootflags=subvol=@
Type: Desktop System: HP product: HP EliteDesk 800 G4 DM 35W v: N/A
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: HP model: 83E2 v: KBC Version 07.D1.00 serial: <superuser required>
UEFI: HP v: Q21 Ver. 02.15.00 date: 12/28/2020
Info: model: Intel Core i5-8500 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
desc: 1x9 MiB
Speed (MHz): avg: 4000 high: 4001 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4001 2: 4001 3: 4001
4: 4001 5: 4001 6: 4000 bogomips: 36000
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: HDMI-A-2
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0300
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
Monitor-1: HDMI-A-2 mapped: HDMI2 model: Dell S2421HN serial: <filter>
built: 2021 res: 1920x1080 dpi: 92 gamma: 1.2
size: 530x300mm (20.87x11.81") diag: 604mm (23.8") ratio: 16:9 modes:
v: 4.6 Mesa 22.0.1 direct render: Yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-8:4 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 238.47 GiB used: 122.37 GiB (51.3%)
model: MZVLB256HAHQ-000H1 size: 238.47 GiB block-size: physical: 512 B
rev: EXD70H1Q temp: 53.9 C scheme: GPT
used: 122.37 GiB (51.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.41 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 30.0 C pch: 61.0 C mobo: N/A
Processes: 279 Uptime: 3h 45m wakeups: 1 Memory: 15.41 GiB
used: 3.56 GiB (23.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1511 lib: 348 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.8-1):
System install date:     2022-04-03
Last full system update: 2022-04-06 ↻
The terminal is more accurately referred to as a terminal emulator, and it typically only displays output for a process if you launch it from the terminal.
Why don't you launch the script from the terminal, so you can keep an eye on it and see what it is doing? You can always toss it into a different workstation if it is in the way.
Edit: another option would be to run ps and just watch while execute the script.
Why don't you try creating a desktop file for it?
Will a desktop file launch the script on a terminal emulator?
It was just an idea.
You have to try...
https://wiki.archlinux.org/title/Desktop_entries#File_example
You could try with
Terminal=true
yes just successfully ran it before your edit lol
Thanks a lot
can you please elaborate a bit on your edit, I'm a newbie to most commands for now
(I successfully did what I wanted to do and am just trying to understand that path so is low priority)
You should be able to right-click on it and select “run in konsole” as opposed to having to create a desktop file for each script.
Exactly , could be a cool feature...
If you run the command ps, it shows in real time the processes running on your machine–whether they were launched from the terminal or not. So you could run ps, then launch your script however you like and see what happens.
It is a feature already…
oh wait how did my stupid ass not find it before
