Whenever I am changing any setting or when I woke my PC from sleep mode than the keyboard and mouse are not working properly
When I opened application launcher and type "r" to search something it directly goes to Restart the computer option. And in open office, when I am trying to write something it opens tools and anything else but not typing a thing. But when I reboot my PC it start normally and keyboard is also working fine. Please help
Becuase you may not have any “apps” which begin with “r”. Not exactly a problem. Which DE?
Do you mean that when you open LibreOffice it dosen’t respond to typing?
Does any application even detect typing?
It could be a problem with the LibreOffice program. Try updating your computer, and re-installing LibreOffice.
Post the output of
inxi -Faz
so that you can get help from more knowledgeable people.
The typing problem seems to occur with every application when it starts to happen. When it woke from sleep mode than it is misbehaving. Recently I am filling a form for competitive exam in brave than suddenly it starts to open tools before that it working fine.
I tried "inix -Faz" but no result.
Now I am typing Brave in krunner and it opens widgets.
Welcome in Garuda forum :slight_smile:
Don’t go in sleep mode, open konsole, type
inxi -Faz
post in and output as text.
Keyboard and mouse are wired or wireless?
Wired keyboard and mouse
╭─shrish_bhatt@shrish in ~
╰─λ inxi -Faz
LANGUAGE = "",
LC_ALL = (unset),
LANG = "en_IN"
perl: warning: Falling back to the standard locale ("C").
System:    Kernel: 5.13.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=837744ba-4cbd-4056-9b6d-004274fc2001
systemd.unified_cgroup_hierarchy=1 resume=UUID=d0c9195b-9f72-4e0e-b5e4-288ce1e8176b loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Portable System: Dell product: Vostro 1550 v: N/A serial: <filter> Chassis: type: 8
Mobo: Dell model: 061W4M v: A06 serial: <filter> BIOS: Dell v: A06 date: 04/08/2014
Battery:   ID-1: BAT0 charge: 31.1 Wh (84.3%) condition: 36.9/48.8 Wh (75.6%) volts: 11.7 min: 11.1
model: Samsung SDI DELL 7XFJJA2 type: Li-ion serial: <filter> status: Discharging
CPU:       Info: Dual Core model: Intel Core i3-2310M bits: 64 type: MT MCP arch: Sandy Bridge family: 6
model-id: 2A (42) stepping: 7 microcode: 2F cache: L2: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 16761
Speed: 882 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 882 2: 2095 3: 1686 4: 2095
Graphics:  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 21.2.1 compat-v: 3.0
direct render: Yes
Audio:     Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169
v: kernel port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Dell driver: wl v: kernel
modules: bcma port: e000 bus-ID: 09:00.0 chip-ID: 14e4:4727 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Bluetooth: Device-1: Broadcom BCM2070 Bluetooth 2.1 + EDR type: USB driver: btusb v: 0.8 bus-ID: 1-1.4:3
chip-ID: 0a5c:21bc class-ID: fe01 serial: <filter>
Drives:    Local Storage: total: 465.76 GiB used: 15.85 GiB (3.4%)
ID-1: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HTS547550A9E384 size: 465.76 GiB
block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: A50A scheme: MBR
Partition: ID-1: / raw-size: 457.52 GiB size: 457.52 GiB (100.00%) used: 15.85 GiB (3.5%) fs: btrfs
dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 457.52 GiB size: 457.52 GiB (100.00%) used: 15.85 GiB (3.5%) fs: btrfs
ID-3: /var/log raw-size: 457.52 GiB size: 457.52 GiB (100.00%) used: 15.85 GiB (3.5%) fs: btrfs
ID-4: /var/tmp raw-size: 457.52 GiB size: 457.52 GiB (100.00%) used: 15.85 GiB (3.5%) fs: btrfs
ID-1: swap-1 type: zram size: 3.74 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.24 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb2
maj-min: 8:18
Sensors:   System Temperatures: cpu: 63.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3396
Info:      Processes: 226 Uptime: 3m wakeups: 1 Memory: 3.74 GiB used: 1.86 GiB (49.8%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1399 lib: 345
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
i input the command.
But just after this it starts to do the same thing. Instantly it opened krunner when I was pressing back space.
Maybe you can check this thread.
The last post seems to have solved, although, if not working, I definitely think you should apply the steps at post #10.
Does your keyboard/mouse even get listed in
lsusb
Post that output also.
