When I click to Verify an ISO image, check sum verification does not come up as
I normally see with any other distro.
Is something broke or missing?
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=61559364-8d16-4ba6-99f3-cd05e28287bd rw rootflags=subvol=@
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.39 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 80R4 v: Flex 3-1580
serial: <superuser required> Chassis: type: 10 v: Flex 3-1580
Mobo: LENOVO model: Flex 3-1580 v: SDK0J40700 WIN
serial: <superuser required> UEFI: LENOVO v: D3CN39WW date: 06/26/2018
ID-1: BAT0 charge: 32.8 Wh (96.5%) condition: 34.0/45.0 Wh (75.4%)
volts: 12.1 min: 11.1 model: SMP L14M3P21 type: Li-poly serial: <filter>
status: not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
serial: <filter> charge: 5% (should be ignored) rechargeable: yes
Info: model: Intel Pentium 4405U bits: 64 type: MT MCP arch: Skylake
level: v2 built: 2015 process: Intel 14nm family: 6 model-id: 0x4E (78)
stepping: 3 microcode: 0xF0
L3: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 2100 min/max: 400/2100 scaling: driver: intel_pstate
governor: performance cores: 1: 2100 2: 2100 3: 2100 4: 2100 bogomips: 16799
Device-1: Intel HD Graphics 510 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: HDMI-A-1
empty: none bus-ID: 00:02.0 chip-ID: 8086:1906 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer KB272HL H serial: <filter>
built: 2022 res: 1920x1080 hz: 75 dpi: 82 gamma: 1.2
API: Vulkan v: 1.3.274 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 510 (SKL GT1) driver: mesa intel v: 23.3.3-arch1.1
device-ID: 8086:1906 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 128 bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 0cf3:e360
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.1 lmp-v: 7
Local Storage: total: 931.51 GiB used: 14.2 GiB (1.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
ID-1: / raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
used: 14.19 GiB (24.2%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
used: 5.7 MiB (1.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
ID-4: /var/log raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
ID-5: /var/tmp raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.56 GiB used: 256.8 MiB (3.3%)
System Temperatures: cpu: 52.0 C pch: 47.5 C mobo: N/A
Processes: 258 Uptime: 9h 26m wakeups: 0 Memory: total: 8 GiB
available: 7.56 GiB used: 3.04 GiB (40.2%) Init: systemd v: 255
pm: pacman pkgs: 1502 libs: 428 tools: pamac,paru,yay Shell: Bash v: 5.2.21
running-in: qterminal inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-04
Last full system update: 2024-01-12
